Question about Pride Mobility Products Pride Jazzy 600
All lights come on solid mod 1100,but won't move forward or back.wheels are locked tried unlock procedule on controller
The right rear wheel intermittently locks up on my lawnmower when going forward stopping forward movement temporarily, until I move it backwards to "unlock" it. Any ideas?
There is an excellent 3 part video that may help you to fix this problem. Please see the 2nd and 3rd videos:
https://youtu.be/Vk_tpjKlbjM
https://youtu.be/DdiewLxTQDc
Things you can try:
(1) Remove casing over rear wheel drive assembly and perform a test run to assure all parts are moving as expected
(2) Lubricate the shafts with lightweight motor oil where the shaft penetrates into the gear box of each wheel
(3) Remove each rear wheel, inspect gears for damage and free movement. Grease up each drive gear and the shaft.
(4) Inspect gears on each wheel for damage.
(5) If none of the above fixes the problem, try swapping out the front wheels to the rear wheels provided the front wheels can accommodate the gearing on the rear wheels
(6) If this doesn't work try replacing the small gear assembly on the right rear wheel
These steps are illustrated in the videos.
Good luck and hope this helps.
Oct 11, 2016 | John Deere JA65 Self Propelled Mower
Lights run back and forth from red to green, no power
sounds like it might be in lock mode or the free-wheel is on. if i remember correctly to unlock push the joy stick forward and hold, turn on the power hold in forwared for about 10 seconds then release turn of and on and should be unlocked. if you are in free wheel push the scooter forward or backward if it is easy to move then the free wheel is on put it to off. and power on and you should be sorted.
Aug 15, 2013 | Health & Beauty
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
My key won't turn and my steering wheel is locked.
push your foot on the brake pedal and try to put it into park, then turn steering wheel at same time as you try to turn key
Apr 02, 2013 | Cars & Trucks
Won't move when drive leaver pushed
go to my group page on facebook wac mobility scooter and i will message you.many thanks billy
Mar 19, 2013 | Pride Victory 4 Wheel Mid-Size Electric...
Won't drive in reverse
Failed Transmission Again
Part with it
Get something else
Maybe American (Rear Wheel Drive Only)
Dec 12, 2012 | 2001 Mazda Tribute
Pride jazzy 600 power wheelchair controller lights flash
make sure the motors are not disengaged, turn off chair, can you move it by pushing it? if so lock the wheels and try again. next is the controller in lockout. press and hold the on button till it beeps push joystick forward til it beeps pull it back til it beeps turn off try again. you can call 1-800-800-8586 for tech support
Sep 28, 2012 | Pride Mobility Products Pride Jazzy 600
Steering wheel is locked on my 95 ford f150 xl..it starts and goes into gear but the steering wheel won't move..it is locked
you can break the lock by pulling down on the steering whell very hard. or if your ignitons swith is bad you have to get a new one
Nov 13, 2011 | 1995 Ford F150 Styleside Regular Cab
Gear shift is locked in park on2008chevrolet impala LTZ Istopped the car put it in park with car running went to take it out of park and it will not come out of park tried moving steering wheel back and...
Check that the brake sensor is alright. Try putting a new one in at the pedal if you don't have a test light or continuity meter to test it. If the brake being applied is not being sensed by the computer, then it will not allow the shifter to unlock. Possible solenoid problem with shifter, as well, if the brake sensor checks out ok.
Nov 05, 2011 | 2008 Chevrolet Impala
How do I lock up my Hoveround MPV5? The tech that delivered my chair shown me a way to lock up the joy stick & wheels, I don't remember how he did it and can't find my manual.
1. Turn the controller on.
2. To lock the chair, depress and hold the ON/OFF button. After one second the controller will beep. Release the ON/OFF button. Move the joystick forward until the control beeps. Move the joystick in reverse until the control beeps. Release the joystick. There will be a long beep that indicates the controller is locked.
3. To unlock, turn the control system on. The speed/response indicator will be rippling up and down. Move the joystick forward until the control beeps. Then move the joystick in reverse until the control beeps. Release the joystick. There will be a long beep that indicates the controller is unlocked.
This is from the manual, I hope it helps you.
May 06, 2009 | NRS Hoveround MPV 5 - Used Power...
Pride Mobility Products Pride Jazzy 600 Logo
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
