Water fill in my ac.
I just have a query.
do i have to provide water to my ac.
  • 109 Answers
Most airconditioners are gas filled, so the answer is "no". Don't add water to the unit.
Posted on Jun 18, 2009
Hi there. My Maytag MSE 760 FARS dishwasher is not filling, but the heating element is working. I suspect the pump has failed. What do I do?
what you can check,
  1. the float in the tub.their may be something caught under it
  2. the water valve,use a meter set to check ac voltage and check for 120 volts ac at the plug to it,if has 120 when supposed to fill valve is bad so long at it has water supply to it
  3. the float switch,use meter set to lowest ohms setting and remove the 2 wires on float switch and check for continunity(zero ohms) if meter reads OL replace float switch
  4. the control,check for 120 volts ac to float switch when supposed to fill, if 120 at fill portion yet no fill ,replace control
  5. water supply,if uses flex tube something in cabinet under sink may have pinched water line
Good luck,i hope this helps
Gene
Aug 02, 2011 | Maytag Dishwashers
The low refrigerant light comes on and a/c doesn't work. The heaters and defrosters work fine however.
If the refrigerant is low /the coolant is low then AC will not work. But the heater will work.In this case the refrigerant needs to be refilled from car ac service center.Its not advisable to fill the refrigerant manually.So getting it done by a professional is very much advisable. But refilling the refrigerant should solve the problem.If there is no refrigerant leak.At the ac service center,they will confirm this before refilling refrigerant. ---------- Keep updated for any more queries.Thanks.
Oct 21, 2010 | 2000 Cadillac Eldorado
Water does not stop filling with water
The possibility is faulty water inlet valve.The valve lets the water to enter the machine.But if this valve is got weak/faulty then it will not stop the water from entering.If the water fill vale is checked ok then other possibility is faulty water fill valve switch.The switch detects the required water in the washing machine and shuts the fill valve off,but if the switch is faulty then it will not shut the water fill valve off and this will not stop the water from filling and this overfills the water.So most cases the water fill valve is faulty and it has to be replaced.But if the fill valve is checked ok then other possibility is faulty water fill valve switch. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. To get required parts ,you can get it from www.repairclinic.com . Keep updated if any more queries.Thanks.
Oct 14, 2010 | Kenmore 24032\24036 Top Load Washer
Machine does not let the water go out
If its not filling with water then its a fill valve problem.But if the machine is filling but not draining then its a drain pump problem.Either the drain pump is clogged or faulty.Remove the drain and check both the drain pump and hose to which drain pump is connected.If both checks out ok then its faulty drain pump causing this problem.Replace the pump. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Washing Machines
My sanyo washing machine does not fill in water, its director drain out. model asw 40sit.
If the washer is not filling with water then the water inlet valve needs to be checked.The water inlet valve is also called water fill valve.If the fill valve is faulty then it will not the water to get filled in the machine. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. You can get required parts from www.repairclinic.com
Machine seems to fill with water when not in use
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.If drain hose is checked ok then its confirmed problem of faulty water fill valve.
the fill valve is leaking. When they go bad they can leak water without being told to by the timer. I would replace the fill valve after pulling the hose off the fill end and watching to see if water drips out.
For getting parts you can get it from www.repairclinic.com
Aug 10, 2010 | Bosch Axxis WFL2090UC
Washing maching not filling with water
The problem is most likely the water fill sensor switch. If it is telling the machine that it is full, it will go right to agitate.
Apr 25, 2009 | Roper RAB2121KW Top Load Washer
AC Question
It will definately work in the wall,,,, all you need to make sure about the correct size if you can buy one because it will need the gaps to be filled so its gona be better if you can get a correct wall sized AC windows type.
Please post me for further queries.
Regards
Jun 22, 2008 | Heating & Cooling
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
