Question about Dell Dimension E310 PC Desktop
Dimension 310 keeps switching from wireless to not connected
Hooked up old dimension e310 to wireless icon keeps switching from connected to not connected.
linktriscuit
  • 89 Answers
SOURCE: dell dimension e310
What you need to do is install your ethernet card first. The card usually comes with a disc with the drivers and utility. Make sure you get that done to get it out of the way. Next you need to make sure the router is connected properly. If you have the installation guide for the router, check the lights. If it's properly connected, there should at least two green lights and one amber. The amber light should indicate theat you have no internet connection yet. You may want to check the proceedure about accessing the router. Usually typing the homeportal in the address bar on Internet Explorer. If you don't have the installlation guide for the router, download it under support at the manufacturer's website. The important thing to keep in mind is to make sure the ethernet card is installed properly meaning the drivers and utility(if any) are installed, and all it is is that it just has a red X on it telling me i don't have internet connection. From there, all you need to focus on is the router installation(physical), then follow the proceedure to access your router. Well i hope you fix it.
Posted on Jun 14, 2008
SOURCE: floppy diskette seek failure
try to go to bios set up..then change the boot order..in the boot tab,,change the "first boot" label with hard disk..then it wont seek for floppy again..
Posted on Jan 05, 2009
  • 15 Answers
SOURCE: wireless router with dimension 3000
It seems that you have Dell Desktop computer, unless you requested a wireless card to be put into the computer, it would not come with one. Just like stang_1 mentioned, you should check your network adapters to see if your wireless card is listed. Also since it is a desktop, you can check the back of it to see if you have an Antenna sticking out of it. That would indicate that you have a wireless card on the PCI slot. And if that is the case and you do not see it listed in the network connections, check the Device Manager and make sure that the drivers are installed properly.
Posted on Apr 14, 2009
  • 1019 Answers
SOURCE: my dell dimension e310 doesn't come on the orange
here are a few things to try.
remove the power lead from the computer, for 5-10 minutes then reconnect.
press and hold the power button, for more than 3-5 seconds, incase the system has gone into hibernation/standby mode.
Remove any un-necessary connected devices ( usb powered Printers-cameras et,c )
Mike @ Compurepair.
Posted on Jun 11, 2009
dante777
  • 623 Answers
SOURCE: I have a dell dimension e310 and I have locked the
Dell describes an easy way how to clear the CMOS settings in their manual for the E310. You can download it here. Look at page 110 (page 112 in the pdf-file) and follow the instructions.
!!! Turn off the power and unplug it from the wall. Wait a minute or two before you open the cover (page 63, pdf page 64), so all transistors and capacitors have the time to get rid of any electricity.
If the jumper method does not work, remove the CMOS battery for 5 minutes and put it back in (page 95/96, pdf page 96/97). That will clear the settings as well.
...and remember: ESD (Electrostatic discharge) is your enemy No.1 here! Make sure not to touch any parts of the motherboard or wear an antistatic wrist strap.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Oct 18, 2009
Wireless connection for e310
http://www.ebay.com/itm/100-TESTED-GUARANTEED-DELL-DIMENSION-3100-E310-MOTHERBOARD-JC474-WJ770-FAST-S-H-/321044602266?pt=Motherboards&hash=item4abfbfdd9a
The two long White expansion slots on the motherboard, are PCI Slots.
http://en.wikipedia.org/wiki/PCI_local_bus
If you have one available you can use a PCI Wireless adapter card,
(PCI Wireless Card);
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4389486&CatId=2701
OR,
A USB wireless adapter,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=357235&CatId=2704
Make sure your router is a wireless router, AND either it has a built-in modem, or your internet provider has provided you with one.
There are different setups, and different types of wireless.
Most common are DSL and Cable.
You can also go the satellite route IF available.
Regards,
joecoolvette
(A wireless N capability; wireless adapter card, or USB wireless adapter, has a range of 150 feet )
Regards,
joecoolvette
Jan 06, 2013 | Dell Dimension E310 PC Desktop
Frequent wireless connection loss using usb port
since it is a USB device try this:
http://www.fixya.com/support/r3567552-resolving_intermittent_windows_usb_devic
other things you can do, update the:
BIOS Wireless Driver Video Driver (Effects power management)
May 20, 2010 | Dell Dimension E310 PC Desktop
Where is the usb port located on the Dell Dimension E-310 computer?
4 ports on back, 2 on the front, 1 usb header on the motherboard
http://support.dell.com/support/edocs/systems/dim3100/en/index.htm#printed_documentation
May 13, 2010 | Dell Dimension E310 PC Desktop
Can I replace a USB port on a Dell E-310?
No, however if it is still under warranty Dell can replace the board. If its not under warranty you can buy a USB add-in card.
Nov 15, 2009 | Dell Dimension E310 PC Desktop
I need a ethernet controller for dell dimension e 310
please visit DELL SUPPORT.COM .....enter your machine model and wow................. you get what you want
May 18, 2009 | Dell Dimension E310 PC Desktop
Working on System
Hi!
You can find the service manual on this site:
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Jan 09, 2009 | Dell Dimension E310 PC Desktop
Floppy diskette seek failure
Jan 03, 2009 | Dell Dimension E310 PC Desktop
Dell Dimension E310 PC Desktop Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
