Question about Dell 966 All-In-One InkJet Printer
Dell Photo 966 Ink Cartridge Keeps Gumming up. Cleaning Cartridges doesn't help. Wipe cartridge off and maybe it works for one or two pages before quality goes down. Replaced cartridges but still have same problem.
  • 143 Answers
Since you already replaced the cartridges there is a problem with the printer.The cartridge must have made the pinter bad.Now you have to take it to the Service Center.
Regards
Posted on Jun 18, 2009
My dell v313w printer gives the message that I need to replace cartridges even after I have put in new cartridges
Are you using Dell Series 21,22 ink cartridges?
Try Cleaning the Printhead on Dell AIO V313w, V515w, V715w, P513w, and P713W Printers
Troubleshooting Printhead Problems on the Dell AIO V313w, V515w, V715w, P513w, and P713W Printers
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 21, 22 black cartridge and then reseat it. I would then take out the color Dell Series 21, 22 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 21, 22 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 21. 22 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to get a Dell Series 21, 22 ink cartridge with a bad sensor. I would take these back to the place of purchase for a replacement or a refund.
Rick
Apr 19, 2011 | Dell V313w AllInOne InkJet Printer
Dell 944 instruction to install new ink cartridge
Replacing Ink Cartridges
CAUTION: Before performing any of the procedures listed in this section, read and
follow the safety information in "CAUTION: SAFETY INSTRUCTIONS" on page 9.
Dell ink cartridges are only available through Dell. You can order more ink online at
www.dell.com/supplies or by phone. To order by phone, see "Ordering Supplies" on page 2.
Dell recommends Dell ink cartridges for your printer. Dell does not provide warranty coverage
for problems caused by using accessories, parts, or components not supplied by Dell.
1 Turn on your printer.
2 Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
3 Press down on the ink cartridge lever to raise each ink cartridge lid.
4 Remove the old ink cartridges.
5 Store the cartridges in an air-tight container, such as the storage unit you received with
your photo cartridge, or dispose of them properly.
6 If you are installing new ink cartridges, remove the sticker and transparent tape from the
back and bottom of each ink cartridge.
7 Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the
left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge
carrier.
8 Snap each lid closed.
9 Lift the printer unit, and hold the scanner support up while lowering the printer unit until
it is completely closed.
See page 71, section 7 in the user guide:
http://support.dell.com/support/edocs/systems/944/en/om/om_en.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 01, 2011 | Dell Photo 964 All-In-One InkJet Printer
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
Photo black ink runs out b4 black on HP Photosmart C6380 printer
The black ink cartridge is larger than the photo black cartridge and black is used in photos to make the darker colors. Black text takes much less ink per page.
Jul 17, 2010 | HP Photosmart C6380 All-In-One InkJet...
Cartridge error 1203
First of all, please verify each cartridge carrier has an ink cartridge :
  1. Check to make sure the left cartridge carrier contains a black or photo ink cartridge.
  2. Check to make sure the right carrier contains a color ink cartridge.
  3. Remove each cartridge and examine it to make sure the protective tape has been removed from the contacts and the print head.
  4. Replace each cartridge in the proper carrier.
Step 2 :
Wicking the cartridges and cleaning the contacts on the back of the cartridge should be performed if the nozzle clean was performed and the quality was not satisfactory.
Wicking the Cartridge
  1. Ensure the printer is powered on.
  2. Lift the scanner unit.
  3. Open the cartridge latches and remove the cartridges from the carrier (Figure 1).
    Figure 1: Removing the Cartridges from the Printer
  5. Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back (Figure 2).
    Figure 2: Proper Cleaning Direction
    new_note.jpg Note: Never wipe the cartridges from side to side, as this causes cross-contamination in color cartridges.
Cleaning the Contacts
  1. Turn the cartridge so that you are looking at the contacts on the back side of the cartridge (Figure 3).
    Figure 3: Turning the Cartridge To View the Back Contacts
  3. Using a clean dry cloth, wipe the contacts in the direction shown (Figure 4), so that no dust or other contaminants are visible.
  4. new_note.jpg Note: Do not use the same cloth that was used to clean the cartridge nozzles. This may cause more contamination on the cartridge.
    Figure 4: Cleaning the Contacts on the Back of the Cartridge
  5. Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
  6. Replace the cartridges in the carrier and close the scanner unit.
  7. Print the document again.
  8. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times as needed.
Dec 19, 2009 | Dell 924 All-in-One InkJet Printer
Full black ink cartridge - but says there is no black ink
To run a nozzle clean, perform the following steps:
  1. Verify the All-In-One Printer 924 is powered on and connected to a computer.
  2. Verify that the paper support (input tray) has clean, plain white paper loaded.
  3. Press the Menu button.
  4. Press the Down button until Mode: Maintenance appears on the LCD screen.
  5. Press the Menu button.
    The Dell 924 Maintenance Menu appears on the LCD screen.
  6. Press the Down button until Clean Cartridges appears on the LCD screen.
  7. Press the Start button.
    The AIO 924 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
  4. Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back
  2. Using a clean dry cloth, wipe the contacts in the direction, so that no dust or other contaminants are visible.
  3. Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
  4. Replace the cartridges in the carrier and close the scanner unit.
  5. Print the document again.
  6. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times as needed.
Verify the Ink Cartridges Are Installed in the Proper Slot
  1. Remove the ink cartridges from the printer.
  2. Read the label on the side of both cartridges to identify which is color and which is black.
  3. Install the black cartridge in the slot on the left and the color cartridge in the slot on the right
  4. Close the ink cartridge lids and make sure they lock in place.
I hope it helps!!!
Nov 18, 2008 | Dell 924 All-in-One InkJet Printer
Changing ink cartridge in dell photo 966
It's probably located under the scanning bed.
Look for another section break below the scanning bed.
Lift it up. The print cartridges should be inside.
Mar 25, 2008 | Dell 966 All-In-One InkJet Printer
Dell 966 All in one printer
make sure sticker off ink as u put it in go download new drivers from dell.com for it they have big updates to fix that
Feb 21, 2008 | Dell 966 All-In-One InkJet Printer
Dell 966 All-In-One InkJet Printer Logo
141 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
