Question about Asseenontvguys Wristech Blood Pressure Monitor As Seen On Tv Wristech and Improved Model. Fda Approved
Error wristechreads err - Asseenontvguys Wristech Blood Pressure Monitor As Seen On Tv Wristech and Improved Model. Fda Approved
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
What does error code Err 09 for a Wolf oven mean?
Hello Joni;
My name is Peter. I am a retired field service appliance technician.
The error coded means: Short circuit in PT sensor or in its wiring.
Feb 03, 2015 | Wolf Range Kitchen Ranges
My Electrolux time manager washing machine wont start jus flashes red with Err
Hey Beverley, thanks for your post!
I see that your Electrolux washer is displaying the error code "ERR". Typically a number follows the "ERR" but if no number followed the "ERR" error code then your washer has detected an error. I would perform a reset on your washer which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not help correct the issue it could be a problem with your control panel or wiring harness. I would recommend seeking out assistance from a professional in order to properly diagnosis and repair your washer. I hope this is helpful to some degree. -Matt
Oct 04, 2014 | Washing Machines
Why do i get 'err on display and buttons do nothing
err is error......should be a number or code after err.......
cheers
Jun 19, 2014 | Zanussi Washing Machines
I'm getting a error message that says, "ERR 99".
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks
Apr 18, 2011 | Canon EOS 30D Digital Camera with 18-55mm...
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
Walgreens HD303 Blood Pressure Monitor error 3
measurement.
Error Codes
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
Want to workaround Shrinker.err to be able to download programs. Can it be disabled in any way?
I found that "shrinker.err" is an error
that you get if the product PowerZip 4.50
is installed and fails to start. PowerZip is a Windows utility, a compression tool.
The shrinker.err error is corrected in the PowerZip 5.2 release, the newest version
and that should fix your problem.
This program has nothing to do with any virus.
Hope this helps, Please leave rating...
May 02, 2009 | Computers & Internet
Shrinker.err prevents me from installing a program. Want to get rid of it.
Good morning! "shrinker.err" is an error that will occur if the product PowerZip 4.50 is installed and fails to start. PowerZip is a Windows utility, a compression tool much like WinZip -- not virus-related. The shrinker.err error is corrected in the PowerZip 4.51 release. If you use this program, just get the newest version (they're up to release version 5.2) and that should fix your problem.. or, just uninstall the PowerZip program altogether if you don't use it. best regards.
Asseenontvguys Wristech Blood Pressure Monitor As Seen On Tv Wristech and Improved Model. Fda Approved Logo
50 people viewed this question
Top Asseenontvguys Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Asseenontvguys Health and Beauty Expert? Answer questions, earn points and help others
