Compaq c-series 2010c unlock utility code
Ive entered a code for security reason, so that no one can be able to see my files, then after use i turn it off, when i open it again and entered the same password, and i am very certain that it is the password, 3 times ive entered the said password and eventually it appeared on the screen that ive entered a wrong password and asking me to enter the unlock utility code, i tried also to re-set the H/PC many times but still it does'nt work. please help me to solve this problem with my H/PC Compaq C-Series 2010c
    President:
  • 1,383 Answers
Here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Posted on Jun 18, 2009
After replacing my hard drive my laptop hp compaq 6720 is asking for a power on password Ive never put one in
Using Computer Setup to Reset CMOS
To reset CMOS through Computer Setup, you must first access the
Computer Setup Utilities menu.
When the Computer Setup message appears in the lower-right corner
of the screen, press the F10 key. Press Enter to bypass the title
screen, if necessary.
-- If you do not press the F10 key while the message is displayed, you
must turn the computer off, then on again, to access the utility.
A choice of five headings appears in the Computer Setup Utilities
menu: File, Storage, Security, Power, and Advanced.
To reset CMOS to the factory default settings first set time and date,
then use the arrow keys or the Tab key to select File > Set Defaults
and Exit. This resets the soft settings that include boot sequence
order and other factory settings. It will not, however, force hardware
rediscovery.
See the Desktop Management Guide on the Documentation CD for
further instructions on reestablishing passwords. For instructions on
Computer Setup, see the Computer Setup (F10) Utility Guide on the
Documentation CD.
For more details and pictures see the help pdf:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00189283/c00189283.pdf
--under 2 B for the procedure to clear the BIOS password.
Mar 06, 2011 | HP Computers & Internet
Wifi problem, please help me and my daughter.
Hello Lan, the best way to connect to your network would be using WZC utility right in windows, to make sure this is turned on follow the link below http://tech.ifelix.net/2007.html
After its turned on go Start>Control Panel>Network and Internet>Network and Sharing Center. After entering here choose your network, if your modem has a security key (WPA, WEP, ETC..) make sure to enter that correctly. If all is well it should connect without a problem.
Hope this helps, if this doesnt work comment and i will give further assistance
Mar 20, 2010 | Compaq Armada E500 Notebook
How do i set password to access my phone (V9)?? I want to set a password on my phone so that no one else could just open it and start fiddling with my personal stuff. I can easilydo that on a nokia but i...
usually your able to go into the menu and the either options or settings and click on security! but some phones are so dang complicated. lol here is what ive found its a razr 2 v9 right?its from the motorola website
codes & passwords
Your phone’s four-digit unlock code is originally set to
1234. The six-digit security code is originally set to
000000. If your service provider didn’t change these
codes, you should change them:
Find it: s >wSettings > Security > New Passwords
You can also change your SIM PIN or call barring
passwords.
If you forget your unlock code: At the Enter Unlock Code
prompt, try entering 1234 or the last four digits of your
phone number. If that doesn’t work, press s and
enter your six-digit security code instead.
If you forget other codes: If you forget your security
code, SIM PIN code, PIN2 code, or call barring
password, contact your service provider.
lock & unlock phone
You can lock your phone to keep others from using it.
To lock or unlock your phone, you need the four-digit
unlock code.
To manually lock your phone: Presss>
wSettings > Security > Phone Lock > Lock Now, then enter
your four-digit unlock code.
To automatically lock your phone whenever you
turn it off: Presss>wSettings > Security > Phone Lock >
Automatic Lock > On, then enter your four-digit unlock
code.
Oct 02, 2009 | Cell Phones
My Sony Ericsson T630 asks Phone Unlock code when I switch it on
If you have forgot the lock code then in turn enter the security code. If you have never chenged the security code then its on default. You can get the default security code in the manual.
Aug 30, 2009 | Samsung Blackjack SGH-I607 Smartphone
I have an code to unlock my lg kp170, but i do not now how to enter this code to unlock it, ive tryed typing in 2945#*170# however this bought up eng data not a security menu like i was told it would
I'd be interested where you got ur code from - I need one. As to how you enter the code - try
Menu - Settings (#) - Security (6) - Sim Locks (5) - Network (1) - Deactivate (1) and then enter the code that you have. (mapc@live.co.uk)
Jul 08, 2009 | Cell Phones
How to break security code of nokia 1600
1. Go to the site http://unlockme.co.uk and enter your phone’s IMIE number and press Enter then u’ll get the master code of your phone.
2. This master code can be used as lock code when we are asked for the security code.
3.But always we can’t remember master code and we want to use an easier lock-code then we can set a new security code of our own wish by giving the Master-code as our old security code when asked for old code while resetting security code.
Tools -> Settings ->(scroll down) security -> Phone and SIM ->(scroll down) Lock Code
Then it asks for old code where u can type the master code and then set the new code as you wish.
When during formatting u are asked for lock code you can also enter Master code.
To know the security code of nokia phones you can also download a software for nokia series
Jul 05, 2009 | Nokia 6600
Ive lost the code to unlock my stereo can u help?
3. Simple way to clear the security code (K type only)
1) During code request mode, press the Track UP key for at
least 3 seconds while holding down the AUTO key. (– – – –
will disappear)
2) Enter, “KCAR” with the remote controller as described below.
• Press the remote controller 5 key twice, and press the
Track Up key. (Enters a “K” )
• Press the remote controller 2 key three times, and press
the Track Up key. (Enters a “C” )
• Press the remote controller 2 key once, and press the
Track Up key. (Enters an “A” )
• Press the remote controller 7 key twice, and press the
Track Up key. (Enters an “R” )
3) Security function is canceled and unit sets to All-Off mode.
4) Code request mode appears if a mistake was made in entering
the numbers.
This is the only way to clear the code, please give me a "fixya" if it helps
Jun 15, 2008 | Kenwood KDC-M7024 CD Player
Unlocking the phone
yes there is but its complicated, are you ready? here we go------
1st. turn on phone
2nd quickly enter #073887* it will get you the programming menu, security code should be 000000 to continue.
3rd scroll down to extended NAM, click ok.
4th highlight NAM 1, press ok.
5th scroll down and it will display "SECURITY CODE" oooooo and unlock code "what ever unlock code is" and now you have it. goodluck Paul
Dec 06, 2007 | Motorola Mobility RAZR V3
How to unlock my security code
ranjithnairv + hardknox - press the menu key in the middle of the keypad, scroll to initial setup then select either master clear or reset and enter the 000000 as the security default codes.
all others take the phone to a mobile service center and have them reset the phone codes back to the originals for you.
Nov 20, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Locked Compaq 2010c
I\'ve bought this on e-bay but I can\'t run it as it requires a password. is the any way I can reset the computer and run it or a "back-door" password? it says administrator loutout mode is in force and thta i have to use a c-series unlock utility to gain access.
Oct 25, 2007 | Compaq C-Series 2010C Pocket PC
Computers & Internet Logo
419 people viewed this question
Alun Cox
David Payne
David Payne
