Hi and welcome to FixYa, I am Kelly.
Here is a manual that will assist you in troubleshooting:
KSSC48Q
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/507220676c24d02d85256b5800675172/$FILE/4317326A.pdf
I suspect you either have a problem with the switch for the ice in door actuator or the auger motor.
Access to the switch is on page 49 and 50 of the manual.
Ice maker auger motor access is on page 42 and 43 of the manual.
Crush/cube solenoid testing AND the auger motor testing are on page 60.
The schematic is on page 68 of the manual. The basic circuit is power from the disperser lock switch to the Ice lever switch to the motor. If the auger motor has the proper resistance then the Ice Lever Switch is the most probable failure. Listen for a CLICK as you depress and let go of the Ice Lever switch. No click = bad ice lever switch.
The micro-switches in the dispenser panel should be the same part number. The parts break down does a lousy job of identifying the exact switch. However, it should be the same part number as item 16 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5132417&diagram_id=28245505#d28245505
This manual may also be of help:
http://applianceassistant.com/pdf/inDoorIceSystem.pdf I think there are some differences from the manual above so it may or may not be helpful. Take a look. For some reason I am thinking about the switch pack but do not see it on the parts list.
Let me know if you need more assistance. Thanks for choosing FixYa,
Kelly
