Question about Canon PIXMA iP4000 InkJet Photo Printer
Lines through the print..
Hi, I had inks fading and replaced the inks done the normal tests .. now getting a 2lines down the right side of the page..???
  • 21 Answers
It sounds like either one the print cartridges is faulty or the printer needs cleaning. If you installed refurfurbished cartridges, they would be highly suspect. There are utilities available with most printers these days that can test these things for you. They are usually installed with your printer's software.
I recommend changing the printer cartidges one at a time and see if this fixes it. I also recommend loading the most current printer drivers and utilities from the printer manufacturer's website and running the cleaning utilities found under the the printer's utility icon after you install the software.
Let us know how it goes.
Posted on Jun 18, 2009
How to check the ink level onC4480 printer
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Puts a black ink line down the back side of the paper when printing fades after it prints about 5 sheets
This is usually a piece of paper stuck in the machine after a paper has gotten jammed. look carefully around the area where the printing is done and near the exit slot.
Mar 21, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I have a ip4200 and when printing in black it is faded and stripe
The print head is clogged.Make sure black ink cartridge have ink and then try unclogging with cleaning tests in maintenance mode.If not help try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If
this not help you need to replace the print head.
Nov 20, 2009 | Canon Office Equipment & Supplies
Printing won't work.
Good day sir/maam, hi, when you test print it usually prints letters and no lines are printed. try first if the printer is setup to economy/draft or pictures, if lines are faded, the ink cartridges maybe dirty. manual cleaning is needed, the ink path starts from the ink cartridge to the cradle or carrier then to paper. so any dried ink that blocks the path can affect the printout. you can use warm water to loosen dried ink. remove the cartridges and cradle from the printer as you clean them.
Oct 27, 2009 | Office Equipment & Supplies
I have fading on the right hand side. Printer Dell 3100CN
Dell printers are junk. But you have put a lot of money into this thing. Check the alignment of the black drum, could be that something is keeping if off track a little bit.
May 26, 2009 | Dell 3100cn Laser Printer
Faded printing on left and right
Hello sir; Believe or not , you need to replace imaging unit.
May 14, 2009 | Ricoh Aficio CL3500N Laser Printer
OkiC5200 has an inch wide faded print line down the left side
It might be a dirty led assembly. The leds hang down from the top when it is opened.
May 03, 2009 | OKI C5200n Laser Printer
Black ink is faded
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.
Mar 29, 2009 | Kodak ESP 5 Printer
Mac leopard -epson tx400 - printer grabs paper - printer very noisy, desk shakes with vibration - now the print on paper is faded help!!
Hello, sorry to hear you are having trouble,
So, are we to understand that your printer did not shake with vibrations and make a lot of noise before ?
Most of these ink jet printers have heads that travel very quickly and abruptly from side to side causing shaking and vibrations, especially if it is on a light weight desk or table, sometimes to the point of almost throwing itself right off the table. This is a normal state for the printer to be in.
Then, you say the paper is printed on, it goes right through to the end, no paper jam, but the colors are faded...
How often do you print on this printer ? Sometimes, the Epson print head dry up and only small amounts of ink get through even though the system indicates that the ink is full...
You can certainly perform a head cleaning operation, I recommend doing it several (3) times to be sure, unfortunately, it's a terrible wast of ink.
Finally, have you replace the ink cartridges? If you get a faded output with new cartridges, you may have inadvertently activated the ink saving or draft mode, go through you page set-up or printer option thoroughly.
I'm pretty sure something here will get you out of this mess.
Mar 27, 2009 | Apple iMac 17" Desktop
When printing some lines don't print properly-appears to be just the top half or less of the line will print. It seems it happens every 3rd or 4th line, but has done it on the second line also, so is not...
Try printing out the test page from the printer, this will show you if any of the inkjet holes are getting plugged. If you can't print a test page without the skipping try changing the ink cartridge(s), the test page will show you which one is clogging.
Carl
Dec 10, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Canon PIXMA iP4000 InkJet Photo Printer Logo
49 people viewed this question
old marine
old marine
