Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23425
Not Freezing, but cold
I have an upright that is about 7yrs, old, that recently just stopped freezing. Inside is cold, but not cold enough.
Checked:
Outside door Gasket - fine, no cracks, clean and seems to seal well
Defrost timer - ohms out just fine
Fan - works fine
Therostat ? - measure open ckt - not having any frost issues, so even if
it's back not sure it could be culprit
> should it ohm as OPEN?
Heater - ohms short (or at least low resistance)
I'm guess compressor has lost it's charge, or otherwise?
I have gauges, and Freon for that matter - can you walk me through the charge.or debug process?
Kenmore Upright 13ish Cu ft : Model: 253.9287212
  • AlabamaRed Nov 11, 2007
    I purchased my freezer in 8/00 and have had no problems. yesterday I opened it and everything was defrosting. i moved everything out, put a thermometer in and it is staying at 30 degrees. the door gasket is good but I don't know what else to do except call a repairman. Any suggestions??
  • marvsh Feb 12, 2008
    doesn't get cold enough - 20 degrees
  • Kenmore Master
  • 4,655 Answers
The thermostat should be a close circuit when requesting cold temps. or when asking the compressor to come on. The exterior surface on some freezers warm when asking for cold inside. Yours has a condenser coil on the back and that should warm when cooling. If compressor is runningit should be wrm if no freon has leaked from freezer somewhere.
The defrost timer should rotate clockwise during the day and give approx. 3 defrost daily or about every 8 hours. Until the thermostat is resolved and asks for a closed circuit the compressor will not come on. Unplug freezer from outlet,remove thermostat wires, then turn the thermostat to its coldest setting and check again. If no closed circuit the thermostat will need replaced first. Hope this has helped you, Sea Breeze
Posted on Nov 02, 2007
16 years old. cold inside, but not freezing food. making small rattling noise
check the RepairClinic site, as they indicate what may be wrong when there is a 'rattling' noise in a freezer
Jan 13, 2016 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have a Superior heavy duty commercial upright freezer that has stopped freezing. It gets cold but doesn't freeze. Is there a reset button on it? The compressor comes on but it's not getting cold enough...
Check if the condensing coil(the one by the compressor) is clog with dirt or grease ,if yes unplugged and clean it real good with a degreaser , also make sure the fan works , if all this is ok and you see the coil inside is partially frozed up ,could be that is low in refrigerant what means there's a leak that has to be fixed before recharge the unit.
Oct 06, 2009 | Freezers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Its not freezing!! keeping things cool, but not freezing
I would definitely start by checking if the fan is working. Note that the fan is switched off when you open the door, so you need to press the door switch and then check if it is working. If not, that will be the problem.
Apr 15, 2009 | Electrolux 3.53 cu. ft. / 100 liter...
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Not Freezing
Check the door seal all the way around. We purchased one recently that was slightly dented (not noticeably and the seal was not tight.) You need to get in touch with whomever you purchased it from immediately so that it can be repaired or replaced.
Aug 18, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
FRIGIDAIRE UPRIGHT FREEZER ONLY 2 BOTTOM SHELFS FREEZING
someone suggested to me the other day to put weter foods closer to the top the ones with dripin water and more solids down at bottom they said this changes the climate inside to be more economical
im just passing this info cause ive never had or been in contact with a upright freezer
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23425 Logo
758 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
