Question about Frigidaire Affinity ATF7000ES Front Load Washer
Water intake valve rubber hose
Where is it located
  • Frigidaire Master
  • 5,323 Answers
NOT SURE i UNDERSTAND UR QUESTION?
Posted on Mar 31, 2015
Why doesn't it fill?
Check you water intake hose and filtre
Dec 01, 2015 | Dishwashers
High idle, after driving a bit when stop idle lopes then high
It is usually caused by the air leakage in the intake manifold. Check the following:
1. Check all the vacuum hoses from around the throttle body.
2. Under the throttle body there are three rubber hoses. Two pipes are of the same size and are used for the coolant circulation through the idle air control valve and the third one is a bit thicker than the two. It is used as the air release tube for the idle air control valve, (if the valve is separate from the throttle body). If the idle air control valve is separate type, it is attached to the side of the surge tank, other wise it is fixed to under the throttle body with Philips type screws (4 mm) as a single unit.
3. To locate the intake air leaking source, take a vacant mineral water bottle, fill it with tap water, make a small hole on the cap with a bag sewing needle, invert it and spray water by pressing the bottle with little pressure and pointing it towards a suspected area. If there is any air leaking from around the intake manifold it will produce an audible suction noise. Locate the area and fix it.
4. Remove the idle air control valve, clean and free it up and install it back.
Dec 10, 2013 | 1991 Toyota Corolla
WHERE IS THE PCV VALVE LOCATED,I'VE SEARCHED AND STILL CANT FIND IT
PCV Valve is located in front of the engine on valve cover gasket under the rubber hose that goes from valve cover to intake manifold
Oct 08, 2013 | 1998 Ford Windstar
Where is pcv valve located on 1989 honda accord lxi
Locate the air box on the top center of the engine towards the back. The PCV valve is located on the rear, underside of the air box. Although on some Accord models, a small air box bracket may be present, which will block view and access to the PCV valve plugged into the intake manifold. If by chance the bracket is there, then remove the retaining nuts, holding it to the air box side with the ratchet and a socket. Reach onto the intake manifold with a pair of needle nose pliers, and gently pull the PCV hose and valve out of the grommet of the intake manifold. Hope this helps!!!
Oct 20, 2011 | 1989 Honda Accord 4 Door
Oil in the intake plenum and exhaust smells rich. What could my problem be?
check the pcv valve its located on top of the valve cover it has a rubber hose that goes from the valve cover to the intake common problem
Apr 24, 2011 | 1993 Dodge Dakota
No water entering dishwasher electrolux 602
First is water coming into the location and is the valve to the dishwasher open? Next check if the intake hose is bent or squashed. Release the kink blocking water flow.
There is a filter in the intake hose that can get blocked by debris. Turn off the water (at the supply valve) then disconnect the intake hose. Clean the filter. Reconnect the hose and turn the water back on. Check for leaks.
The manual for the unit is available here: http://kitchen.manualsonline.com/manuals/mfg/electrolux/esi_602.html .
I hope this helps.
Feb 21, 2011 | Electrolux 23 in. ESI602 Free-standing...
Where is pcv valve located on 2005 taurus
It is below the egr valve close to the intake manifold below the intake air sensor, there is a tube running to it from the engine to recirculate exhaust air with fresh air, there is a clamp holding it to the air intake that you need pliers to remove, then you need to turn counter-clockwise 90 degrees to remove, do the reverse to install. to make it easier to access remove the upper intake. The pcv valve is not visible, however, you can identify it by the 3" inch long rubber hose that connects to the steel line running into the bottom of the intake. I have the part and am going to replace it soon, although Ford really makes it difficult to remove it -
pcv valve is located just under the throttle body. remove air cleaner assembly from throttle body and you will see a u shaped hose running horizontally.
Jan 27, 2010 | 2004 Ford Taurus
Where is the pcv valve located on a 2003 ford ranger
  • The PCV valve can be located in several places. The most common location is in a rubber grommet in the valve cover. It can be installed in the middle of the hose connections, as well as installed directly in the intake manifold.
  • Once the PCV valve is located, make sure all the PCV system hoses are properly connected and that they have no breaks or cracks.
  • Remove the air cleaner and inspect the air and crankcase filters. Crankcase blowby can clog these with oil. Clean or replace such filters.
  • Oil in the air cleaner assembly indicates that the PCV valve or hoses are plugged.
  • Make sure you check these and replace the valve and clean the hoses and air cleaner assembly.
  • When the PCV valve and hose are in satisfactory condition and there is oil in the air cleaner assembly, perform a cylinder compression test to check for worn cylinders and piston rings.
  • Feb 27, 2009 | 2003 Ford Ranger Regular Cab
    Where is pc valve located on 2000 oldsmobile intrigue
  • Feb 16, 2009 | 2000 Oldsmobile Intrigue
    Washing Machines Logo
    14 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Jason Harris
    Jason Harris
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
