Question about LG dlg5002w 7.3 cu. ft. gas dryer factory refurbished for usa-19753
How do I remove the front panel of an LG DLG5002W Dryer (so I can check for excess lint build-up)?
MNTECH
  • 1543 Answers
SOURCE: LG DLG2524W DRYER WORKS FINE EXCEPT DOESN'T HEAT UP
1. Open dryer door and remove the phillips head screws at the 5 and 7 O'Clock positions. 2. Remove three screws at very back, allowing top cover to be moved back about an inch and lifted off. 3. remove screw at top left and top right from front top panel. 4. pull plastic front panel along top edge to release front top panel. (watch for sharp edges) 5. Swing top up and over onto top of dryer. 6. Unplug light and door switch. 7. remove four screws at top of large lower panel. 8. lift panel up a bit and off. 9. unplug sensor plug at bottom allowing panel with door to be set aside. 10. gas dryer has dime sized high limit thermostat on left front side of burner chamber. Has two wires on it, with a small pin in the center. Push the pin in. Reassemble and clean out vent, eliminating flexible venting, replacing with rigid aluminum piping and elbows. Outside vent should have a four inch vent flap opening, not just a two inch if it is that style.
Posted on Jan 03, 2009
Testimonial: "YOU HIT THE NAIL ON THE HEAD WITH THIS SOLUTION. THANKS"
  • 3 Answers
SOURCE: dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Posted on Jun 23, 2009
  • 17 Answers
SOURCE: electric lg front loading dryer not drying well.
make sure the exhaust tube to the outside is not blocked with anything.
Posted on Nov 07, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have an lg dryer model DLG5966W and the check
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Posted on Jun 17, 2010
  • 615 Answers
SOURCE: My LG front loading dryer doesn't dry well
Check the exhaust vent when running and be sure there is a good flow of air. You may have to clean the exhaust pipes all the way through. Dryers require a good flow of air for proper operation.
Posted on Jan 10, 2012
Dryer is not heating and it says check filter. What does that mean?
there is a lint filter that needs cleaned . usually every time you use the machine check this link LG D1102W Owner Manual Page 35
Apr 06, 2015 | LG DLG5002W 27" Gas Dryer
How to remove the back panel
remove top, then front control panel, then front of dryer. then you will have full access.
Jul 03, 2014 | LG 7.3 cu. ft. Gas Dryer, White Model...
How do I take the cabinet off a GE gas dryer model # DHDSR46GE1WW to check inside?
The following website may be helpful:
https://www.partselect.ca/Models/DHDSR46GE1WW/Instructions/?InstructionID=21302
This was extracted from the website:
Remove the two screws at the front above the drum opening (with the dryer door open). The top panel then lifts off. I removed the screw at each side that holds the front panel to the side panels, tilted the front panel forward, which disengages the front of the drum from the front drum glide bearing. I then lifted the front panel slightly, unhooking the bottom of the panel from the dryer base, and swung the front panel aside.
Oct 10, 2017 | Dryers
DRYER GENERAL ELECTRIC SUPER CAPACITY. APPARENTLY IT IS WORKING BECAUSE IT HEAT BUT THE CLOTHES ARE WET
A leading cause of poor drying results in that type of dryer is lint build up in the blower/lint filter housing. That build up will restrict air flow through the dryer causing very long dry times. To repair that the front panel would need to be removed and clean all the lint build up from that housing and blower wheel area.
To remove the front panel DISCONNECT POWER TO THE DRYER, on the bottom of the dryer inside of the door rim will be 2 phillips headed screws,remove those and lift off the top. At the top corners where the front panel connects to the cabinet will be 2 more phillips headed screws remove those and the front panel will pull off and out of the way. With the front panel off the blower housing will be in the lower left side clean lint from it and also the sure to clean all the lint from the lint filter housing which will be attached to the back side of the front panel. In addation to cleaning that area be sure to check and clean the exhaust duct tube as well.
GENE
Oct 13, 2011 | General Electric Dryers
I have a lg tromm dle2514 dryer and the check filter light is on. I am willing to clean it (I've already cleaned the front filter area) I just have no idea where there is another filter
There is no other filter to clean other then the one lint filter.
I would check the dryer vent to make sure it's not restricted with lint build up or has any kinks in it. Also check the outside flapper at the end of the dryer vent to make sure it's clear of lint and able to open all the way.
If your dryer vent is ok and the lint screen is clean then I would remove the front of the dryer and check the blower/fan housing for lint build up.
Aug 04, 2011 | Dryers
How do I remove odors from this dryer?
Probably build up of dust and lint inside cabinet. You need to unplug dryer, remove back panel and vacuum out lint. If excessive lint found, would indicate insufficient cleaning of lint filter or restricted outflow vent or hose. If odour is electrical smell or burning plastic check all electrical connections and insulators for signs of browning or overheating. Strong pungent smell could be motor winding overloading or burning out. Will need electrician.
Apr 02, 2011 | Dryers
How do I remove the front panel? I need to vacuum out the lint build up inside the dryer. Also, something has fallen down in the dryer and the drum is hitting it when it rotates.
Hi, to clean all of the lint build up, you have to get behind it and remove the back panel to expose all electrical, motor, and lint. As far as something getting into the drum, it would have to get inside from inside the unit only, as the drum is solid on the side you can't see. You have air holes for the heat to come in and a button may have went into the drum and has no way out. At the back of the dryer where the vent connects to the drum, well it is a chute that the heat is blown into, you may be able to pull this back and get in side at the bottom of the drum to see if you can feel around, but unless there is a panel built into the drum on this model, it will have to get lucky and fall out inside the drum again. I would look the drum over good when you are back there cleaning and rotate the drum by hand to see what might be there to excess that part of the drum. Please keep me posted and let me know if you need more help as I would be happy to help you.
Sincerely,
Shastalaker7
PS, Please be careful as it is very high voltage, so make sure the breaker is off and the unit is unplugged. Thanks.
Mar 13, 2010 | LG DLE2532W Electric Dryer
Drain hose
This hose can be removed from the rear by removing the access panel. Look to the left and you will see the drain coming down from the condensate duct. Follow it down to the drain assy. While you have it off, check in the opening for lint build up which can block the drain
Jan 21, 2010 | LG WM3431 Front Load Washer / Dryer
LG FRont Load Washer Dryer WD-1256RD filling up with lint
If you have not done it already, replace the lint filter. Follow instructions on manual. The lint filter access should be on front side of machine.
Other users had same problem on this model, I quote:
"I've only had it 2 weeks so far. It seems to be collecting lint/fluff all around the rubber door lining"
Source here.
Sometimes there may be too much lint if you use excessive softener and detergent.
Feb 08, 2009 | LG WD-12124RD Front Load Washer
Burning smell and no manual
dont have a service manual for it but i can tell you thta in order to acess the inner workings heres what to do. First remove the filter assy and then the 2 phillips screws under the filter. the top should the pop up and you need to remove 2 5/16 screws holding the front panel on the front panel will then lift off allowing you acess to the belt and motor asy, belt part number 341241, and a 691366 for the idler/tension pulley assy. the burning lint smell is probalby form an excess of lint within the cavity of uint, if you find excessive lint build up checl your venting!!!!!
Nov 02, 2008 | Estate TEDX640JQ Electric Dryer
LG dlg5002w 7.3 cu. ft. gas dryer factory refurbished for usa-19753 Logo
62 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
