Question about Ice Cube Maker
KUIS18PNJB5 kichensaid icemaker won't make ice
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Icemaker is slow in producing ice
If your icemaker is producing ice, but it is slow, there are 2 likely explanations.
1. Temperature. Water freezes at 32 deg, but the icemaker won't eject the ice until it gets below 10 degrees. If you always had good ice output and all of a sudden it has slowed down, you're temperature is a little higher than ideal. Check for a door seal not making good contact or try dropping the temp in the FREEZER side a couple degrees
2. New model. Most new refrigerators make ice much slower than older models to meet energy efficiency guidelines. This is not a repairable issue.
May 25, 2012 | GE Refrigerators
Amana ars2464 won't make ice
first check that the icemaker is getting water
second, check the temperature in the freezer. the freezer needs to be below 10 degrees to work.
if both check out, then you need a new icemaker
May 06, 2012 | Amana Refrigerators
Icemaker wont harvest
if you press the arm that slides out to feel the ice all the way in three times within a few seconds, this should start a harvest cycle. If it does, then you know it can cycle and you have a temperature issue.
your ice can freeze even at 25 degrees, but it won't harvest unless it is getting to about 8 degrees or colder, so check the temps in the freezer
Apr 17, 2012 | GE WR30X10093 Refrigerator Icemaker Kit
Ice cube tray won't stop making ice.
This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
Thank you
Rick
Mar 12, 2012 | Refrigerators
Ice maker not making ice.
Hi
There are various reasons as to why an icemaker won't make ice. A faulty water inlet valve or defrost thermostat.Please check this link to view the site to have an in-depth idea related to your issue:-
http://www.partselect.com/refrigerator+icemaker-no-ice+repair.htm
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
Icemaker quit working
Hello.
First of all you need make sure that your freezer is freezing enough. Sometimes everything will seem to be freezing ok, but it won’t be cold enough to make the icemaker work. The best way is to squeeze your ice cream, if you have any that is.
Then you need to make sure that the ice level sensing arm is in the down/on position.
If all of this checks out ok, then you need to make sure that nobody turned off the water supply that is sometimes located under the kitchen sink. Also make sure that the ice bucket is positioned properly so as to trigger the ice bucket sensing switch.
If all of this checks out ok, let me know and I can guide you through an icemaker diagnosis by forcing it into a harvest mode.
Nov 20, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Icemaker won´t work
if you got 110 volts to ice maker. try jumping out the T & H ( a small insulated copperwire) . this will cause the ice maker cycle, if this does nothing replace the ice maker.(entire assy cheaper then the parts). remeber you might have to shut the door switch to get the 110v. some machines run the power through light switch
Mar 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Cube Maker Logo
21 people viewed this question
Top Ice Kitchen Appliances - Others Experts
jasbo
jasbo
mike cooper
JoyEd Stevenson
JoyEd Stevenson
Level 1 Expert
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
