Question about Cooper Lighting ACE TRADE - COOPER LIGHTING PHL300 "REGENT" PAINTER'S HALOGEN
Changing lamp regent phl300 - Cooper Lighting ACE TRADE - COOPER LIGHTING PHL300 "REGENT" PAINTER'S HALOGEN
How do you change the arbor bearings on an simplicity regent with a 50 inch cut?
You must take the blades and belt off and the well as pulley, the arbor is replaced as a unit and it unbolts with several bolts.
Jul 28, 2014 | Simplicity Regent Riding Mower 23 HP...
How do i get a Regents HT-391 surround sound system to play sound from my Logitech Revue with Google TV?
More than likely the regent system is needing and alternate audio source, via- analog, digital coax, optical ect... HAs it always been this way, or use to work?
May 22, 2014 | Logitech Revue with Google TV Refurbished
Will a schlage b60 fit in the same holes as a schlage regent deadbolt
I'm not sure what the regent deadbolt is, but if you look at the attached Factorylocks.com youtube video it will show you how to resize a Schalge B60 deadbolt.
Dec 18, 2012 | Locks & Locksmithing
Simplicity Regent Starting Problem
The wrong seat switch was installed. There are black ones and gray ones. I believe you need the gray one for open circuits.
Aug 10, 2012 | Simplicity Regent 19.5/38
I have a Regent digital electronic safe model MOT SFN37E. I still know my code, but after changing the batteries I can't open it any more with my code. I also lost my key.
If you can get the door open (which I've seen several procedures for), you can reset the panel with the red reset button on the inside of the door on the hinge side. It will beep and the orange LED will light up solid. Now you can type your 4 digit code, press B, confirm code, press B again et voila!
Jul 19, 2012 | Safe International Digital Electronic Safe...
Code for HT-391 regent home theater remote
my name is travis i have a regent home theater system model ht-391 i just bought a universal remote is there a code for the system
Jan 25, 2012 | Audio Players & Recorders
Help with install
Go here to download a copy of the manual.
The straps that are in the area where you'd thread the seatbelt to install are for LATCH installation if you have LATCH anchors in your car - but you can only use seatbelt OR LATCH to install, never both. The strap at the top, with the same hook, is the top tether.
Instructions for using both are in that copy of the manual - the installation instructions for the Regent vary depending on your child's weight, so read it carefully.
Feb 11, 2009 | Britax Regent
Where in Sydney can I purchase a replacement lamp for a Daewoo KOC 984 Microwave oven.
Normally a grocer or department store or hardware store will sell replacement bulbs of this type.
You can take the old one with you.
Otherwise, try:
Daewoo Electronics Australia PTY. Limited. (DEA)
Unit Q5, Regents Park Estate Princes Road East, Regents Park NSW 2143, Australia
Tel: 61-2-9738-5111
Fax: 61-2-9738-5511
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 25, 2008 | Microwave Ovens
Cooper Lighting ACE TRADE - COOPER LIGHTING PHL300 "REGENT" PAINTER'S HALOGEN Logo
Top Cooper Lighting Electrical Supplies Experts
Craig Butler
Craig Butler
john h
Ottoniel
Are you a Cooper Lighting Electrical Supply Expert? Answer questions, earn points and help others
