Question about HP Office Equipment & Supplies
Hp deskjet 1513 all in one
The above printer has a problem of blinking the amber light through out even after changing the toner cartridges. please assist.
  • 72 Answers
Great you changed the toner cartridges but you may also need to do the following as well.
Imaging drum is low Light pattern Hp deskjet 1513 all in one - c00189128.jpg Description The imaging-drum light is on. The printer continues to print without any action required until the imaging drum is empty. Action Order a new imaging drum. Have a good day
Posted on Jun 19, 2009
Yellow light is blinking?
If the bottom amber colored light is blinking, the imaging drum needs replaced.
If the yellow print cartridge light is blinking, then replace the print cartridge (yellow toner).
Mar 24, 2014 | HP c9705a - Color Laser Jet 2500l Printer
Toner light keeps blinking
The inkjet uses ink, not toner. When the light is blinking it indicates something is wrong with one of the cartridges, such as can't find it, not installed, out of ink, improperly installed, printer has died. First thing to try is to disconnect the power (not just power off) for 5 - 10 minutes and reconnect. If that does not resolve it, inspect the cartridges and reinstall them. If you have another printer that uses the same cartridges, try the cartridge in it. if not, get another set of cartridges and install them. If none of these steps resolve the problem, chances are that the printer is the problem and is probably not worth spending additional time on it.
May 03, 2010 | HP DeskJet 810c InkJet Printer
My Printer HP DeskJet 4180 is printing but keeps blinking continuously on the power button and the other three red lights on the toner sighns what could be the problem? - Please help me.
turn on/off, unplug, plug in2_bing.gif, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome web site for trouble shooting if all else fails
hope this helps and good luck
Apr 29, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Replace ink cart and amber light still blinks
Usually if the Amber light is blinking with a new cartridge, that cartridge has bad electronics.
Try replacing the cartridge with another or the old one, if the light goes out it was just a bad cartridge.
Sep 10, 2009 | HP DeskJet 932c InkJet Printer
Printer hp deskjet1513 all in one
Use this link for the User Guide
http://h10032.www1.hp.com/ctg/Manual/c00366227.pdf
The print-carriage access / front cleanout
door is open, the print cartridges are
missing or not installed properly, the
protective tape is still on a print
cartridge, or a print cartridge is defective
Jun 18, 2009 | HP Office Equipment & Supplies
Amber light!
Clean the contacts in the cartridge holder (Iso alcohol & cotton swab work well).
Dec 23, 2008 | HP DeskJet 920c InkJet Printer
I've just installed my HP deskjet 920c printer, but the amber light seems to not stop blinking. I've installed only the black ink (c6615d) 'cause I have no use for the color ink.
You can't operate the printer without the color cartridge, even if you don't need it. You can always keep an empty one in, but you must have both in.
Black ink(56) cartridge
please take out the cartridge and look at the ribbon circuits behind that. does it look like there a hole poked in it?
Sep 05, 2007 | HP DeskJet 5150 InkJet Printer
Canon Bubble Jet iP1600
Hi meemee, If ink comes out of the ink nozzles on the cartridge then you probably just need to reset the printer page counter. Each time the cartridge is removed from the printer an empty cartridge message appears and a blinking amber light will display on the printer. Hold the paper feed button down for 3-5 seconds, and that should override the counter. If ink isn?t coming out of the ink nozzles then you may have an air pocket preventing the flow of ink. Try running your printer cleaning cycle a couple of times to see if that helps. Lastly you might try letting the cartridge site for 24 hours to let gravity try to fix it. As a last resort you can try unplugging your refill hole in the cartridge. If your cartridge ink is going to flow it will now, just be ready to re-plug the fill hole. Let us know how it goes and don?t forget to rate the post.
Jan 03, 2007 | HP DeskJet 3325 InkJet Printer
145 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
