Question about Nerf N-Strike Longshot CS-6 Blaster
Nerf longshot not working
Sucks doesnt **** right and it is colored pink and mi musslle broke doesnt work it sucks its bull./;[
Installed new black cartridge in Deskjet 810C printer and after doing this it will only print in pink color. Please help.
Make certain that the cover is off the jets - if you forgot to pull the strip off or it broke leaving part of the tape on the cartridge, it won't work. Try to do a clean process on the cartridge. If that doesn't work, and you don't have another printer to try the cartridge in, return it to the place you bought it and get another new one. If the printer is printing pink, the color cartridge is probably empty also so that it cannot make black from the other colors. These sound like refilled cartridges - OEMs would have failed with some form of error code or warning.
Apr 11, 2011 | HP DeskJet 810c InkJet Printer
We have a pink aser any way mi friend?s nice drop
I believe the hard drive is in a state of shock which can be cause by the fall. The disk the system is reffering to is the windows operating system disk which some how you aquire will only format you hard drive which mean new installed operating system.
By the way is it Acer Laptop if so please state your model number for refference
Nov 18, 2009 | Acer Aspire One Netbook 8.9" Notebook
Color printing not working
It sounds like the repair shop did not repair the cartridge holder properly, or they did not align it properly. If you can it would be best to take it back to the repair center and have them fix it correctly.
Aug 10, 2009 | Office Equipment & Supplies
The sifter wont move form park.
I have the same car and problem..if you take apart the cup holder, and the silver plates around the shifter, you'll see bright pink parts. There is pink on the left side and the right side, its probably the right side pink part that broke. If you push that pink part towards the cup holders you can move it out of park. That piece broke and will need to be replaced.
Jul 27, 2009 | 2008 Dodge Avenger
Charger won't shift out of park ...park lock
http://www.custombilletstore.com/product_p/1028.htm I know this is late but I had the same problem. The release wouldn't work either. I had to remove the shifter and take the cover off. A spring broke off the pink lever in the front of the shifter. The shifter would move side to side but couldn't be pulled back. The above link sells a replacement part that might work. Thanks to petevpi.
Jun 26, 2009 | 2006 Dodge Charger
Need color code diagram for sterio
I'm not sure what year you have but this color code works for 87-93 mustangs.
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Hope this helps.
Jun 19, 2009 | Ford Escort Cars & Trucks
Power tilt in my 97 mazda millenia does not work
the tilt motor broke and it sucks because you can not adjust it manually , mazda sucks big time on Millenia .
Mar 14, 2009 | 1997 Mazda Millenia
Screen Turns Pink-Mitsubishi 57'' Wd-Y57
since dlps use a color wheel to make the color the color wheel may be going out. get it serviced
Nov 15, 2008 | Mitsubishi WD-Y57 57" Projection HDTV
1988 mark 7 color code for sound system
1986-89 Lincoln Mark VII Stereo Wiring Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Red Illumination Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) Pink/Blue Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Green Left Rear (-) Blue/Orange Right Rear (+) Pink/Blue Right Rear (-) Green/Orange
Aug 17, 2008 | 1988 Lincoln Mark VII
Nerf N-Strike Longshot CS-6 Blaster Logo
35 people viewed this question
Top Nerf Toys Experts
ray gallant
Are you a Nerf Toy Expert? Answer questions, earn points and help others
