Question about Bissell 2X Proheat 9200 rug cleaner
Bissel proheat 2x Model 9200 won't spray but will **** up water. How fix it?
Checked all screens. Checked to see if there was anything clogging , couldn't find anything. It won't spray, but will **** up water.
  • 29 Answers
SOURCE: Cleaner Solution Not Dispensing On Bissell 9200 Pro Heat Cleaner
I haven't had this particular issue (yet... knock on wood!) with my Bissell, but remember that the shampoo will not dispense with no water in the tank (the most common cause of this issue because sometimes you think it has water but it doesn't) or water not flowing through the machine due to clogged sprayers-- another issue-- but since you're getting water on the floor that is not your issue-- or with the handle locked in position. If none of that fixes it, try removing the shampoo container, stand over a sink, and push your finger up inside the grommet where the shampoo container mates with the Bissell. Shampoo should dribble out. If it doesn't, unscrew the grommet (holding the container upside down of course so the shampoo doesn't gush out) and use your finger and running water to try and the grommet cleaned out.
If this isn't helping, it may be that your soap pump or soap dispensing trigger switch are defective.
Posted on May 29, 2009
  • 17 Answers
SOURCE: My Bissell ProHeat 2X model 9400 won't spray from
Here is what to do
Posted on Feb 08, 2010
  • 9 Answers
SOURCE: I have a bissell proheat
I Had the same problem with my model 79011...take the upright handle apart & you will see a pot-metal rectangular box midway down the lower section of the handle with wires on it & 2 hoses attached. This is the water heater unit. LET IT COOL IF YOU JUST HAD THE UNIT ON AS IT WILL BE HOT!!! Take the hoses off & carefully **** the inlets out ( do NOT probe more than about an inch in) with a piece of coathanger wire. Flush heater unit out by hooking a peice of hose up to the heater unit & blow into it to flush the loosened crud out. Hook it all back up & it should work like new! What happens, is the alkalis in the cleaning solutions react with the pot-metal & cause corrosion to build up, eventually clogging the unit, thus not allowing waterflow thru it. Built to fail just like all modern junk! ;) Hope this helps! Ross
Posted on Sep 13, 2010
heatman101
  • 43501 Answers
SOURCE: 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum: I have a Bissell proheat 2x deepcleaner 9200 model...
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fkj
Posted on Sep 30, 2010
SOURCE: Bissel proheat is not sucking up water
How do I get Bissell to **** up water have no instructions
Posted on Jul 31, 2011
Can't get the water to spray and the red star is not turning
DIY - Fix your bissell if it doesn't spray solution any longer ...
? 5:33
https://www.youtube.com/watch?v=SLyDeM10k9k
Feb 6, 2010 - Uploaded by kronomarine
Common problem with most Bissell Carpet Cleaners is that it stops ... to no one repeats my mistake, this is NOT the Bissel Proheat 2x Turbo Model .... water go back to use 8 months later and now it only sprays water ... I can't understand ANYTHING said to me by the Bissell reps in India or .... Get video URL.
All comments on DIY - Fix your bissell if it doesn't spray ...
Nov 28, 2015 | Bissell 7920 ProHeat Pro-Tech Upright...
My bissell proheat 2x dual dirtlifter is not succioning very well then the carpet smells
We have several parts here for the Proheat 2X,
Proheat 2X Shampooer Shampooer Parts
It may be a clog in your tank, preventing the water being sucked back up. Check your tank and tubes for clogs or damage. Make sure the brush is still rotating and the belt is not broken too.
800-775-6586
GoodVac com
Feb 26, 2015 | Bissell 2X Proheat 9200 rug cleaner
Bissel pro2 carpet cleaner stopped sraying how to fix
Hey Diane! Sorry you're having difficulty with the spray on your ProHeat 2X. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Bissell 2X Proheat 9200 rug cleaner
Have a model 9200 that is not dispensing fluid,
heatman101
bnv,nm
Jul 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissel Proheat Pro-tech. When turn ON the motor running but not work. The belt still good but tho rotor not turn. Please help me to fix.Thanks
Is this the carpet cleaner Proheat?
I have a Proheat 2X and it wouldn't disperse water unless I used the Water Rinse setting. I found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 23, 2010 | Bissell 9200 Upright Vacuum
The water will spray but it doesn't get sucked back up
Something is probably clogging up the suction.
Try to snake it out with a coat hanger or similar tool.
Often, especially with shedding pets hair will clog the suction pipes
Hope this is helpful.
Good Luck!
Jan 12, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Won't spray
I have the red Bissell Proheat CleanShot 2x 9500 and it would not spray water or solution from either the floor or the hand tool. I followed a tip on here and checked the red gaskets. There is one on the bottom of the water tank and one on the solution tank. My red gasket had come off the solution tank and was lodged inside where the solution tank sits. I pulled it out and reattached it to the solution tank. Now everything is working perfectly again. I hope someone else will be as lucky as me!
Aug 02, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
22 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
