Question about Celestron Optics
Repair focus wheel - Celestron Optics
I have a pair of pentax 10x42 DCF HRc binoculars that will not focus properly througn the right eyepiece. Just wondering if this is a common problem and is it worhtwhile getting repaired
The binos will rack focus both at the same distance, you need to rack focus left side to distant image with left eye only, then turn diopter focus to focus right eyepiece. Diopter focus is thinner wheel behind focus wheel
Aug 15, 2015 | Pentax DCF HRc (10x42) Binocular
Why has focusing wheel stopped turning?
Perhaps only a screw got lose, or perhaps something broke. Don't try to repair this yourself. Goto a certified Swarofski crevice centre, or go back to your dealer.
Jun 10, 2014 | Swarovski Optik Swarovski El 8.5x42...
I have a leak of clear liquid coming from passenger side near wheel of my W reg ford focus can you tell me what it could be
yes, brake fluid. If you need repair instructions, please let me know which wheel and I will see if I have them.
Apr 03, 2011 | 2000 Ford Focus
Cost to repair the front wheel bearing
about $46 if you do it yourself but you will need to rent a puller
Jan 13, 2010 | 2003 Ford Focus
Stiff focus wheel
The number one rule is to never use oil on a binocular!!
I suspect that the multistart thread on the focus arm carrier, which is internal, has become gunged up. This is not an easy repair for a beginner. The rubber has to be removed from the body of the binocular before you can even start to take them apart to determine the fault.
Like any bearing or gear system, the part would have to be cleaned with a degreaser, then reassembled with new lubricant.
Jan 04, 2010 | Pentax PCF WP II (8x40) Binocular
Husband dropped camera.Little lens with the focusing square now flopping. Takes pics the image in view finder not focused but picture is
There is a wheel small wheel next to the viewfinder to allow you to focus it but it sounds like you need to take this to be professionally repaired or check your Canon warranty
Aug 16, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
How to focus my Zeiss 10x40B TP binoculars
Your binoculars are known as the Zeiss Classic or what was once known as the Dialyt. They focus differently from the usual binoculars like those mentioned. The rear wheel is to focus both binocular barrels while using them. The front focus wheel is adjust the right eyepiece to suit your right eye. Binocular manufacturers take into account each eye is slightly different. To focus the Dialyt...First close your right eye and turn the rear wheel until the image is sharp in the left barrel. Leave the focus wheel alone. Now close left eye and adjust the front wheel until the image is sharp for your right eye. The image should now be clear and in focus for both eyes. It should not be needed to use the front wheel from now on. The rear wheel is what you will use to change the focus from near to far objects.
May 31, 2009 | Zeiss Classic B/GA 524013 Binocular
Center focus wheel will not move
i have repaired them before..if you want give me a call 5088331232
Mar 19, 2009 | Optics
Optics Logo
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
