Question about Whirlpool RBS245PDS Electric Single Oven
How to reset a whirlpool oven after it locks - Whirlpool RBS245PDS Electric Single Oven
My whirlpool RBD305PRS00 double oven wont heat up and is locked
The door and controls lock when the oven temp is very high or when on pyrolitic cooking if that is available on your oven. If the controls wont reset or the door wont open try turning the power off for about 30 minutes and then try again. reset the clock and hopefully the oven will return to normal..
Aug 26, 2014 | Ovens
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    WHIRLPOOL ACCUBAKE OVEN DOOR LOCKED. NOT CLEANING IT AND CONTROL PANEL DOES NOT SHOW LOCKED OR AN ERROR
    Disconnect the power from the appliance for about 5 minutes and then turn back on. This will reset the system. If this doesn't work, you may have a control board issue.
    Aug 27, 2011 | Ovens
    Double oven no model number Whirlpool 14 years old Door is locked after self clean and display is blank
    Your oven has resetable high limit thermostat that tripped off on the self clean cycle,im not sure if you have free standing,or a wall oven if freestanding the t-stat is on back panel if wall oven its behind control panel on upper oven and for lower oven its behind the grill between bottom of upper oven and top of lower oven. In either case it has a small red button that can be pushed in to reset it
    Hope this helps and if it does please give me 4 thumbs up
    Gene
    Jul 28, 2011 | Whirlpool Ovens
    The oven locks automatically when the auto clean tab is pressed . it takes too long to open . I need it to open now , How? My Whirlpool oven is superpower 465
    THE DOOR LOCKS TO PREVENT SOMEONE GETTING BURNED DURING THE EXTREME HEAT PRODUCED DURING THE SELF CLEANING PROCESS.UNPLUG THE OVEN, IT SHOULD RESET ITSELF. BE CAREFUL
    Jan 06, 2011 | Whirlpool Ovens
    Still locked from self cleaning
    Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
    Also check out this tip...
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    May 10, 2010 | Whirlpool GBD307PD Electric Double Oven
    Whirlpool Oven Died During Cleaning Cycle No Display Now Locked
    Had same problem with my KitchenAid. 10 years old. Ran self cleaning cycle, oven died!!!! Called repair. Appears to be thermal fuse. Part on order. Microcomputer had some brown spots on it. Tey wanted us to replace it too. But will wait to see if fuse is problem. Repair - $150 vs. $570. If it's the higher price, we'll buy a new oven before putting that kind of money into it. Will NEVER run a clean cycle again even if I have to buy a new oven.
    Jul 16, 2009 | Whirlpool RBS275PD Electric Single Oven
    Display is in LOC but door is not locked. Can't set temp. to bake
    check if u can find any reset procedure.
    alsio u can let it with no power for 30mi that will reset it Int.Memory.
    Feb 16, 2009 | Whirlpool RBS275PD Electric Single Oven
    EO F2 Lock message on oven panel
    The solution was to hold down the "start" button for five seconds, which reset the system. I figured out that I had entered the model number of my oven wrong (mistaking a "Z" for a "2"). When I re-entered the correct model number in the "search for manual" section of the Whirlpool site, I was able to access the user manual and find the section that walked me through the correction.
    Dec 29, 2008 | Ovens
    Oven won't work - its a timer problem how do I reset the timer?
    I believe the control's child lock function is enabled. To disable it, press and hold the cancel key (will have small padlock icon under the word "cancel"). That should clear the condition.
    Dec 24, 2008 | Whirlpool RBS305PDS Electric Single Oven
    Whirlpool RBS245PDS Electric Single Oven Logo
    24 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
