Question about Mopar Performance Dodge van/wagon - full size belt, lap buckle half. 1992-93-94, 1994
Volvo 740 fuel pump relay location - Mopar Performance Dodge van/wagon - full size belt, lap buckle half. 1992-93-94, 1994
Were is fuel pump relay in 1990 740 volvo
FUEL PUMP RELAY IS AT THE CENTER CONSOLE UNDER RADIO BY ASHTRY
Sep 02, 2014 | 1990 Volvo 740
Where are the fuel pump relays located on a 1989 gle 740 volvo
Behind central console, under the stereo near the floor
Nov 21, 2011 | 1985 Volvo 740
How many fuel pumps and relays are on a '90 volvo 740 GL
  • You have two fuel pumps. A main fuel pump and an in tank fuel pump and one fuel injection/pump relay that turns the fuel on for the both of them at the same time and each fuel pump has a dedicated fuse.
  • So your vehicle has 1- relay, 2 pumps, 2 fuel pump fuses [1 for each pump ]
  • The relay and both fuses are located under the drivers side of the dash in a little fuse/relay panel.
  • Hope this helps and thank you for using FixYa
Regards, Tony
Jul 23, 2011 | 1990 Volvo 740
Where is the fuel pump relay on an 87 740 gle?
The fuel pump relay is located, just behind the ashtray, above the fuses.
But in order to remove the relay, you must first unscrew the cigar lighter to remove the housing.
The fuel pump relay, is the one on the right of the two.
Et voila.
Jul 07, 2009 | 1987 Volvo 740
1990 volvo 740 GL no fire or fuel
Try replacing your fuel pump relay,this controls this.The fuelpump relay is two relays in one unit.
Jun 29, 2009 | 1990 Volvo 740
88 740 volvo cranks but shuts off within minutes, has new fuel pump filter and relay
You may have to bend the conections on the fuel pump relay, so they fit tightly. Try gently twisting it l/r, while turning the engine over.
Hope that's it.
Jun 17, 2009 | 1990 Volvo 740
Volvo 740 not starting
Fuel pump is located on drivers side below rear driver door area near rear axle. Fuel filter is located next to pump.
Mar 31, 2009 | 1989 Volvo 740
Fuel pump
Have you checked the fuel pump relay and fuse? That lives in the relay/fuse panel under the radio, behind the ash tray. I always carry a spare relay and fuse. The pump might have taken out both of these, The fuel pump relay is located in the third row, toward the firewall, next to the last relay on the right. The first in that row is a big relay for the headlights. The fulk pump relay is located between that and the one on the right. There are only three relays in the last row.
Oct 21, 2008 | 1988 Volvo 740
Mopar Performance Dodge van/wagon - full size belt, lap buckle half. 1992-93-94, 1994 Logo
Top Mopar Performance Clothing Accessories Experts
Da Doc
ray gallant
Are you a Mopar Performance Clothing Accessory Expert? Answer questions, earn points and help others
