Question about Haier L39B2180 39" 1080p LCD TV - 16:9 - HDTV 1080p
L39b2 will not turn on
Checked fuses ok
No power to fuel pump
What engine?
you say everything is ok but have you checked for power at any of these components to see where you are losing power. Check for power at the fuse. The fuel pump fuse should have two pins with power and two pins with ground. Check each pin while turning the key to the run position. There will only be power/ground on some of the wires for 3-5 seconds when the key is turned to the run position. It may be helpful to have a helper in the drivers seat turning the key while you test.
Sep 05, 2014 | 2000 Dodge Durango
No brake lights or turn signals
If all fuses check OK, the multifunction switch may be the source of the turn signal problem. A defective brake light switch could be the cause of the brake light non-function.
Apr 12, 2014 | 1990 Ford F250
Toyota 4 Runner park lights won't turn off
faulty connection ,or check all your fuses from box,check fog lights fuse 1st,
Oct 29, 2012 | Toyota Cars & Trucks
Van will not crank over, seems to have no power to the starter
Battery? If OK, turn the ignition switch to START and listen for a click indicating the starter relay is closing. If it clicks, the starter may have failed. If no click, check 10A CRANK fuse 8 in the instrument panel fuse block. If OK, check 40A IGN-A fuse in the underhood fuse/relay center. If OK, check for 12V at the top of the IGN-A fuse. If OK, the ignition switch, the park/neutral position switch (shift quadrant), or the starter itself are the only other possibilities
Sep 28, 2012 | 2002 Chevrolet Express
Turn signal not working
Press the Hazard switch on and check the turn indicator lamps. Replace the faulty lamps.
If the hazard lights do not work then the trafficator flash can is faulty provided the trafficator fuse is OK.
Check the fuse for the turn indicators, if it is blown the replace the fuse.
Dec 11, 2011 | 2002 Kia Rio
Tail lights inoperatrive
Could be one of three things;
1. Check the fuses in the fuse box.
2. If all fuses are OK, check the headlight switch.
3. If this car has 'delay turn off lights' feature, the lighting control module should be checked.
Nov 12, 2011 | 1993 Lincoln Town Car
Low beams dont turn on........... bulbs check ok...................fuses under hood ok.............need help
{: ) I wonder how you checked the fuses and the bulbs. Did you check also the HDM fuse 15amp and the HDM relay both at the underhood fuseblock? Turn on the low beam and check for 12v at the LO beam fuses. If there is voltage at the fuses but the low beam ok bulbs won't light, then there's a wiring issue from your fuseblock going to the bulbs.
But if no voltages on the LO fuses when the low beam is switched on, then the problem could be on the HDM fuse or relay, the headlamp switch, the BCM, or even the fuseblock.
Jul 02, 2011 | 2006 GMC Envoy
Dryer will not run...checked fuses ok.....240v ok....what else could it be?
if it won't turn or anything its probably the neutral wire on the terminal block in the rear of the unit,they carry a high amount of current and can get brittle and break off or burn off in time check the incoming power connections first,if it turns but doesn't heat,then it may be your thermal fuse located in the vent duct housing inside the dryer if this opens you will not get any heat from either a gas or electrically heated dryer
May 18, 2010 | Dryers
Receiver will not turn on , it comes on for a few seconds and turns off
Just open the unit and then check the fuses,if the fuses ok. Then check the filter capacitor in power supply if its ok ,then check the regulator,if its ok. Then check the four transistors output stage of the amplifier. Maybe there is the problem there.
Good luck..
Dont forget to rate:
Jun 29, 2009 | Yamaha HTR-5650 Receiver
Error Message C3451
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Oct 02, 2007 | Konica Minolta bizhub C250 All-In-One...
Haier L39B2180 39" 1080p LCD TV - 16:9 - HDTV 1080p Logo
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
