Mac book pro 3.1. 2.66hz. Model A1151. Screen black when start with boot sound
  • 25 Answers
Try the standard start the laptop holding option and command and p and r (and hear that boot sound twice or three times; note that it gets louder)--this clears any info the laptop might be holding onto, like "I'm suspended with a blank screen". You can also unscrew the bottom plate and disconnect the battery, hit the power button to clear any residual power, reconnect the battery and screw back the plate (or maybe you just have a battery door to simplify!); then, maybe it boots, but I suspect...
...you screen is bad (since your hear the boot sound); to test: assuming your TV has an HDMI port, get a miniDP to HDMI cable (e.g. under $15 via Amazon slash dp slash B00APLKGA8); then physically connect, then change the input on your TV and hope there's a picture (e.g. your desktop background)--if you can't see anything, unplug and replug the thunderbolt/miniDP connector (or borrow any good laptop and verify you can see it on your TV)...
Assuming it's out of warranty (otherwise, you should be at the store already!), so pay $ to your nearest Apple store, or (for the brave) buy the part (hoping LCD panel; i.e. your TV saw a signal), and see repair guides via ifixit dot com (just note the super fine print on the bottom of your laptop; you'll need your Model No; A1286 or to do some searching).
Posted on Jun 13, 2014
  • 4 Answers
SOURCE: Dell projector, Mac book Pro display problem
Hi smithmollie,
There should be a "displays" icon 67f8081.png in the top right portion of the menu bar where you can change the display mode to "Mirror Display" whenever you connect the projector.
If it's not there go to "System Preferences" > "Displays" > "Display" tab and put a checkmark next to "Show displays in menu bar".
Also you can go to "System Preferences" > "Displays" and leave it open while connecting the projector and change the settings to "Mirror Display" there.
Best regards,
Thomas
Posted on Feb 24, 2009
  • 739 Answers
SOURCE: what courses the hard drive to file on a mac book pro laptop.
Hi Stephanie
This is one of those questions that's virtually impossible to answer, it could be anything.
Your best option is to take to a mac specialist (the dealer where you bought it) or to an Apple Store if you have one near by.
It may not need a new hard drive, it may just be corrupted and need sorting out. On the other hand it could have failed mechanically and will need to be replaced - check your warranty. There have been a number of reports of HDs failing in some models and Apple have replaced them free of charge as there was a manufacturing fault at the HD factory that didn't come to light until the drives had been running for about a year.
You have been using Time Machine to back up your work haven't you?
Posted on Jul 28, 2009
smartr10U
  • 1305 Answers
SOURCE: WHAT TO DO WHEN YOUR MAC BOOK PRO FROZEN AT THE START UP SCREEN
Get your Mac OS DVD out, restart the machine with the disk in your optical drive, and after you hear the famous mac chime, press and hold the C key while it starts. When you reach the install window, don't install but rather open the Disk Utilities App and run a verify of your hard disk, also repair permissions. Then restart as normal. This should get you back to operation.
Posted on Dec 14, 2009
news775
  • 699 Answers
SOURCE: My Apple mac book pro
The grey screen is the bios of your laptop is booting, this is freezing for some reason.
Do 3 things.
Try holding power button down for longer at least 10-20 seconds.
do a PRAM reset, apple symbol, alt P & R keys all held on boot up.
Do a smc reset.
  1. Shut down the computer.
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 15, 2011
  • 9 Answers
SOURCE: Lost install disk for Mac book pro My 13" Mac book
You will need some install disks to even begin working on your issue.
Your options:
  • Find someone with the same model MacBook Pro and borrow the disks.
  • Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
  • Check eBay for install disks but make sure they are for the same model MacBook Pro.
  • Contact an Apple service center and purchase a replacement set of install disks.
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
Posted on Apr 24, 2011
How to fix the LG LCD LM270WQ1 (SD) (B3)?
Rarely, a Mac may encounter some peculiar issue during system boot that can cause quite a bit of panic, like booting to a completely black screen. It would be easy to interpret that as a potential hardware problem, and in some particularly rare situations that may be the case, but it's more often a software issue that can be resolved with some simple troubleshooting steps.
Case in point; one of our readers experience with his MacBook Pro, which out of the blue rebooted to a completely dark screen. Though it's rare, we figured this would be a good opportunity to share three potential solutions to this problem, and similar issues, should you encounter a dark screen on system start.
First, Reset the System Management Controller to Fix the Black Display on Boot
The first thing you'll want to do resolve nearly every power related issue on a Mac is to reset the SMC, or System Management Controller. This will dump and reset settings for anything power management related, and is long known to resolve problems with things like fans, heat, sleeping problems, and of course, display issues.
On any modern MacBook Pro or MacBook Air with a built-in battery, which is just a bout all of them nowadays, this is how you do that:
  1. Shut down the Mac and connect it to your MagSafe adapter and a wall outlet as usual
  2. Hold down the Shift+Control+Option+Power button at the same time for a few seconds
  3. Release all keys at the same time, then boot the Mac as usual
Older Macs can find directions here for the same process on their machines, it's slightly different if you can take out the battery.
When the Mac boots, hopefully the black screen has gone away and you're back to normal, but if it doesn't... reader Nathan D. wrote in with the next tip.
Second, Try a Keypress Sequence to Ditch the Black Screen
Regular readers may recall that we covered some OS X keyboard shortcuts for the Shutdown, Sleep, and Restart controls of just about every Mac, and this little key press sequence takes advantage of those. Oddly enough, it seems to work to resolve some of the mystery Mac booting into black screen issues. Here's the precise sequence to follow:
  1. Press the Power / OFF button once - this will bring up the dialog box which you can't see
  2. Press the "S" button - this is the shortcut to sleep the Mac
  3. Hold down the Power button until a hard shut down is forced
  4. Wait about 15 seconds, then hit the Power button again to turn it back on
This key press solution was discovered by reader Nathan D., who found it tucked away on MacRumors Forums, and it has worked for several other commenters there as well. Some other users on the MR forums suggest that resetting PRAM helped them too, but most power issues are resolved by the SMC reset.
Try a PRAM Reset to Resolve the Black Boot Display
If the above two tricks failed, a PRAM reset can often do the trick, as many of the commenters on this article can attest to. As a potential solution to the black screen on boot, this is done upon restarting the Mac similar to an SMC reset:
  1. Reboot the Mac and as soon as you hear the boot chime, hold down the Command+Option+P+R keys together
  2. When you hear the boot sound again, the PRAM has been reset so let the Mac boot again as usual
At this point your Mac should boot again as usual and no longer have the black display, loading Mac OS or Mac OS X as usual.
Finally; Enter Password, Hit Return
Some users in our comments report an interesting alternative finding if they hit the black screen on boot; if they enter their regular login password and hit the Enter/Return key, the Mac boots up as usual and they're good to go. Try this out, it might work for you:
  1. When the Mac boots into the black screen, enter the password you'd use to login to the Mac as usual
  2. Hit the Return key
If this works, you'll know rather quickly because the black screen will give way to the regular Mac OS desktop.
Did one of these solutions work to get past the black screen on Mac boot for you? If you happen to run into this unusual issue with your Mac, let us know how you resolved it, and if the above tips worked for your MacBook, MacBook Pro, MacBook Air, and whichever Pro or Air model it may be. If you still need any assistance call me on +1(518)348-9393 i will be glad to assist you
Aug 14, 2017 | Apple Computers & Internet
Mbp 17" A1151 will not boot up. But with its sound
You have the same problem, when you connect the power connector?
Make sure you see the light go on, before you try to start the mac.
I sometimes have to start twice or even three times, because my battery is getting old. but till now it always started.
Apr 15, 2014 | Computers & Internet
Your video chip may need to be reworked by a pro so it is getting power this is a problem with older mac book pros
Apr 14, 2014 | Computers & Internet
Mac book pro. Black screen cannot start but with boot sound
Have you tried connecting an external monitor.
A boot chime means the Mac has passed POST, that the screen remains black initially suggests there is a problem getting image to screen which could mean a bad cable to the LCD or the LCD display its self is having problems.
By connecting to an external display you verify the graphics on the logic board is functional, and it could get you up and running till the display problem is fixed.
Also try powering up and when you hear the chime, hold down the COMMAND+OPTION+P+R keys, and keep holding them till the machine has chimed 3 times, this will reset the 'BIOS' in case there is a glitch there stopping the display from showing up.
Apr 14, 2014 | Apple Computers & Internet
I want to restore my Mac book pro and I don't have the cd and I forgot the administrator password and username
Hi, can you borrow one from a friend ?
insert cd/dvd into drive then boot Mac when you hear the startup sound press and hold the "C" key until you see the os startup screen.
Oct 25, 2013 | Apple MacBook Pro Laptop Computer with...
MacBook Pro took a drop, boots up but nothing on the screen.
The screen, the cable that connects to the screen or something internal has taken a hit. You'll need to get it serviced to find out which. Sorry, but there's not much diagnosis we can do from a distance.
Apr 03, 2013 | Apple MacBook Pro Notebook
Broken mac book pro screen
Check your user manual for a start. These models the early 2011 models of MacBook Pros work in TDM. See OS X Lion: Use another Mac as a display.
Jul 27, 2012 | Apple Mac Book Pro 13 In Laptop Computers
My mac book pro model late 2007 15,4" not starting up
Try to reset the PRAM and SMC follow the Process in Apple webpage.If still the issue persist try removing the Ram and check with a good one if you have any.this should solve the isue.If still the issue arise then it can be a logic board problem
Feb 28, 2010 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Macbook pro frezze at start up screen.what do i do to slove this problem ?????
you have to go to savemode on your start up to slove this problem try running it on save mode went you start up your computer it will ask you where you what to boot up in make 100% there is no cd in side the cd write before you do it
Dec 14, 2009 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
MacBook Pro Black screen and shining sleep indicator
is the battery fully charged? try plugging it in then press the power button again.
Jan 10, 2008 | Apple MacBook Pro PC Notebook
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
