Question about LG LW1010ER 10,000 BTU Window Air Conditioner - Refurbished
Lg ls120cp no fan - LG LW1010ER 10,000 BTU Window Air Conditioner - Refurbished
What is code 67 on a LG PTAC
Hi Jason, The link below is a web page, Click the 4th down for an LG Ductless HVAC & PTAC Error Codes manual.....
https://www.google.com.au/search?q=LG+PTAC&oq=LG+PTAC&aqs=chrome..69i57j69i61&sourceid=chrome&ie=UTF-8#q=LG+PTAC+error+codes
Code 67 ODU fan motor not rotating or proving rotation. Verify fan motor plugged in correctly & fan rotates freely. This can be a failed motor, failed board or motor could have failed and caused board failure as well. Verify 310V DC on motor wires separated by empty terminals on plug with motor plugged in, 0V DC = failed PCB, 310V DC = likely failed motor. Next step: Unplug motor and manually spin the fan (keep it spinning): on same wires you just tested, 0V DC indicates motor failed and caused board failure. 14-30V DC indicates a good motor
Mar 31, 2016 | LG Heating & Cooling
Lg LBUL6080BL exterior fans cut off soon after starting.
LG offers free Tech. support on all of their products. They have helped me many times.Go online to get their toll free number! LG has problems with the fans.Have changed many of them. The fans are built very cheap! You can save a lot of time and trouble using Tech.support!
Jan 14, 2014 | LG Heating & Cooling
My LG Remote control AKB35551201 STOPPED WORKING
I have lg ac with fan control in remote. Model no. LSA5NF5VFC1.AN48DV1(ll) so i want new remote of my lg ac along fan control.
Jul 31, 2013 | LG Heating & Cooling
I have an LG desktop computer model MT-Intel serial number 104067 and I need to purchase new fans but I can't seem to find anyone who sells LG components ....
you shouldn't need to buy lg specific fans, pc fans in general are interchangeable. Measure your faulty fans from side to side and search for fans of that size instead. Just check the amount of wires you have coming from your fans and make sure the replacements are the same amount.(not necessary but just to be on the safe side, it will make sure all of your sensors work correctly)
Hope this helps.
May 09, 2011 | LG Computers & Internet
I have a lg lfx25960sb,it is showing ER IF code on the panel above ice /water door,also not making ice?
ER IF indicates that the ice maker fan is not working. The fan is probably frozen. Remove the fan duct and housing at the back of the freezer and you may be able to defrost the ice in the fan enclosure. It will not defrost sufficiently by turning the freezer off for 2 to 4 hours as LG suggests. The fan may have frozen because of high humidity or because the defrost cycle is not working. If your unit is still under warranty LG should fix it by replacing the fan, duct panel and control board with new ones that have been re-engineered to prevent this problem.
Dec 16, 2009 | LG LFX25960 Bottom Freezer French Door...
LG FRIDGE,, fan not working or is thermostat faulty?
fan bad or not defrosting look for ice build up behind panel by fan
Oct 26, 2009 | LG Refrigerators
Error message on LG Refrigerator
The message is ERROR ICE FAN. You can order a new one from LG for around $65 and if you know someone handy they can probably put it in by just eyeballing the old one. WARNING>>>>this must be someone with common sense and some degree of problem solving skills as it does not come with the fan blades and that must be switched. This is a common problem with this model and usually the ice fan goes out in about 12-20 months. Use your owners manual to figure out how to get the door off and access the fan. Also, Lg employees are confused and may try to tell you there is just one fan......they did tell me that!
The ER IF is part # 46811B1029E---The ER FF (freezer fan) is part # 4681JK1004E and only a skilled repairman can modify them to be interchanged.
Dec 07, 2008 | LG LFX25960 Bottom Freezer French Door...
There is an error code on my fridge it says ER IF on the water dispensor.
This is an error code related to the ice maker fan. What is happening according to LG is that the defrost heater is staying on too long and is causing moister to build up in the fan assembly preventing the fan from operating normally. They have a fix out that includes a new fan with a drain at the bottom and a new control board. LG should be able to get you the parts for your specific model.
Nov 03, 2008 | LG Refrigerators
IR Codes for LG ductless air conditioner
I, have a LS120cp lg ductless.The only way I,can get the unit to run is by pressing the test button on outdoor board.
Jun 04, 2008 | LG Heating & Cooling
LG LWHD 1200 HR Air/Heater fan will not start.
may be a bad fan motor or loose wire, however some units have dip switch settings on the circuit board preventing the fan from coming on.
Dec 19, 2007 | LG BG8000ER Air Conditioner
LG LW1010ER 10,000 BTU Window Air Conditioner - Refurbished Logo
16 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
