Question about Xerox Office Equipment & Supplies
Xerox 3050 adding email address - Xerox Office Equipment & Supplies
How do I set up network scanning?
Hi Kenneth,
I saw your name on a previous query.
This best ting with this one is to follow any information on the www.Xerox.com website.
Good Luck.
May 22, 2015 | Xerox Phaser 3635MFP/X Multifunction...
How do I change my facebook email address back to what it was?
  1. Click > at the top right of Facebook and select Settings
  2. Click Email
  3. Click Add another email to add a new email to your account or click Remove to delete an email from your account
  4. Enter your password
  5. Click Save Changes
  • When you add a new email address to your account, we'll send you a confirmation email. Click the link in the email to confirm you want this email address added to your Facebook account.
  • One way to keep your account safe is to make sure the email addresses listed on your account are accurate. We also recommend adding an extra email address to your account in case you ever lose access to your main email address.
Feb 13, 2015 | Facebook Computers & Internet
Xerox 3050 fuser replacement
Assuming you are talking about the Xerox 3030/3050 wide format printer, you don't replace the fuser, only the individual components eg. fuser roll
May 11, 2012 | Xerox Office Equipment & Supplies
I can't configure the email. I enter the SMTP address but wet I try to connect tell me Conn. Failed , I don't now how to configure it and where if is i have to put the information about my internet...
SMTP2Go has an SMTP server that works with Xerox WorkCentres:
http://www.smtp2go.com/blog/smtp-server-for-xerox-workcentres/
You can also test their service for free.
Sep 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Xerox 3050 service manual
sir,
i want get solution for my 3050 xerox machine. while taking the copy the background coming black, idon't know the reason, i changed explosure lamp, primary corona end block, tonner, but till the problem is background black, if one copy comes clear another copy will be black. if know the solution kindly pass the message to my cell no.7760191629.
thankyou,
regards,
prabhu
Sep 11, 2010 | Xerox Office Equipment & Supplies
How do I find the path to a network printer in order to install it? I had to reinstall the driver but my boss can't find the disk so I downloaded it from the Xerox website. The add printer wizard wants me...
It sounds like whoever set up your network added an administrator code to access.
That driver is pretty much plug and play and sets itself up very easily.
That user name and pass word is not part of the driver setup.
Feb 16, 2010 | Xerox Phaser 8560MFP Laser Printer
I have a Xerox WorkCentre 5638. How do I save
You cannot save the e-mail addresses on this unit except by creating a .CSV file and uploading it via CWIS under Properties>Services>E-Mail>Public Address Book. A link to the instructions is below:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=195,E=0000000001733361539,K=3118,Sxi=11,Case=obj(10395)
Sep 15, 2009 | Xerox Office Equipment & Supplies
Can't import address book into Xerox Workcentre 7345.
The CSV format is below
"*",1,1,2,,
MFDN,MFADDRT,MFCN,MFIKEY,MFVDN,MFLINE,MFFAX,MFRBC,MFCMODE,MFSRESO,MFSHEET,MFSHEETC1,MFSHEETC2,MFPMAX,MFTMSND,MFTMSNDH,MFTMSNDM,MFMBOX,MFMBOXPS,MFMBOXID,MFRLY,MFRLYID,MFRLYPRN,MFRLYNUM,MFCHRGT1,MFCHRGT2,MFCHRGT3,MFFCODE,MFPCODE,MFSG3FRBT,MFMDMSPD,MFECMFRBT,MFEJBIGFRBT,MFIFAX,MFTIFF,MFIFAXCMODE,MFIFAXSRESO,MFIFAXPMAX,MFIFAXTMSND,MFIFAXTMSNDH,MFIFAXTMSNDM,MFSN,MFGN,MFMAIL,MFAUX1,MFAUX2,MFAUX3,MFSVRT,MFSVRADDR,MFPORT1,MFPORT2,MFUSER,MFPASSWD,MFVOLUME,MFPATH,MFUSETLS
0001,MAIL,Glenn,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,Marsden,,glenn@*************.co.uk,,MAIN OFFICE,,,,,,,,,,
Mar 26, 2009 | Office Equipment & Supplies
Xerox 6180 MFP port set up problem
I have the solution. I own a Xerox 6180 MFP, and I could not send over port 25. My ISP said they weren't blocking port 25, and my web server wasn't supposed to be blocking port 25, but something in EXIM (that has something to do with email) was blocking it, WHICH CAUSED THE PROBLEM. The solution is:
For your SMTP login name and password don't enter your email address's u/p. Instead enter your website's cPanel (or whatever) u/p. For me it's the same u/p I use to log into www.yadayada.com/controlpanel to control my website. THEN choose "SMTP AUTH (Login)" as the 'email send authentication' type.
I'm still using ports 25 and 110. And I still am entering my SMTP server address as whatever I use (mail.yadayada.com). The only thing I'm really changing is the above. Other than that, follow Xerox's instructions to do it over port 25.
Oh. And for your POP3 server address, in case you don't know, don't enter mail.yadayada.com. For some reason you gotta just enter yadayada.com here (where 'yada' is your domain).
Jan 23, 2009 | Xerox Office Equipment & Supplies
Xerox Phaser Networking
Have you tried just reinstalling from original Xerox CD. This worked for us in a similiar situation.
Oct 12, 2007 | Xerox Phaser 8400 Laser Printer
15 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
