Question about Philips GOGEAR SA6045 MP3 Player
Headphone audio jack loose - Philips GOGEAR SA6045 MP3 Player
    Habit-Forming:
    New Friend:
  • 32 Answers
You can try this...
?If you can open the player, find the audio port and arrange the metal contact of the audio jack.
If you still having problem, reply me.
Posted on Oct 30, 2015
2 Suggested Answers
mileso
  • 3320 Answers
SOURCE: headphone audio jack
Try some crazy glue
Posted on Apr 14, 2014
Loose audio plug
thing is headphone jack seems gone unable to fix that try to buy new headphone or else try to use the port at the backside of cpu.
Feb 16, 2014 | HP Pavilion Computers & Internet
Hi! I have a brand new Coby headphones (haven't been a month). I've been keeping good care, but today I found that left ear works perfectly while right one is loose. As I turn the jack at the end around...
try cleaning the connecter
10 Headphone Repair Hacks - Sustainablog
https://sustainablog.org/2015/10/10-headphone-repair-hacks/Oct 19, 2015 - For instance, here's a file for a new jack cover. Reconnect a wire to the lead. If audio is only playing through one side of your headphones, then a loose or disconnected wire is the culprit. Repair the ear cushion. If the cushion wears out or comes off of your headphones, don't worry-that's fixable! Replace the ...
Jan 21, 2018 | Coby CV-190 Consumer Headphones
I have an Acer Aspire Notebook. When I plug headphones into the audio jack there is no sound, however, the sound works fine from the notebook speakers. Can anyone help me?
Hi, May I know if have tried alternate headphones and if they are the same?Does the headphone work when wiggled within the port if yes then the issue is with the headphone jack being loose and you would need to send the computer for a repair if covered by the manufacturers warranty as the headphone jack needs to be replaced. Thank you for your time.
Nov 23, 2010 | Acer Aspire One A150-1006 Notebook
My nuvi 760 doesn't play sounds anymore - through the speaker or through the earphone jack. I deleted some mp3 files a while back and I wonder if I accidentaly delted a audio driver file. I'd like to check...
No, there ar no audio drivers. If you use the headphone jack a lot, it coul dbe that the headphone jack has broken loose from the board. The headphone jack also controls audio to the speaker. The headphone jack must either be resoldered to the board or replaced. Please see this link:
http://www.sharc.net/gps_audio_repair.htm
- Jim
May 20, 2010 | Garmin Nuvi 660 GPS Receiver
Sennheiser RS126 headphones/base stopped working
Broken audio cable entering the transmitter or audio jack plug.
Power supply plug loose / faulty power supply.
Nov 10, 2017 | Sennheiser RS 120 Consumer Headphones
My sony 771 won t play any sound -- not the speakers because doesn't come through headphones either. Just cleaned the lens for CDs last night, then this problem developed. Can see the amp bars moving, so...
The lit indication ("amp bars") proves that the aduio signal is getting through the unit's circuitry @ least to that point; lack of sound @ the spkr & headphones indicates the amplifier portion of the circuitry is either inoperative or disconnected from the load (i.e., either the speakers, or the headphones). A common cause of this type of problem cropping up unexpectedly is the headphone jack itself; in most products of this type, the audio path from the amplifier output to the speaker connection runs through the headphone jack, so the the speakers may be "turned off" when the headphones' plug is inserted into the jack. If the unit's owner uses headphones regularly, the most common problem to be found with the jack is loose solder connections to the printed circuit board's traces from the jacks' lead(s); in units with this problem whose owner's irregularly use the headphones, it's more common to find oxidization of the electrical contacts within the jack itself.
Dec 10, 2009 | Sony Audio Players & Recorders
Can't get my laptop speakers to work through headphone jack
the reason for this is that the audio thru this jack is attenuated to a level where you don't loose quality and to prevent ear damage. You better try the audio out or audio monitor output jacks located in the back of the tv(if this model comes with them). you'll probably need an audio amp to get the speakers to work properly though.
Sep 09, 2009 | Insignia LCDTV26 26 in. Television
I have problem with audio port. sometimes it does not work with headphone.
In this scenario we never blame first the port of the laptop. have you tried different headphones? normally the audio ports dont go wrong that often. but after trying different headphones if it still doesnot works then you will need to take the laptop to the service station. try different headphones before spending a penny after laptop's audio port.
Aug 12, 2009 | Acer TravelMate 3270-6569 Notebook
Sound Problem with Headphone
First try the headphones in a different machine, such as an mp3 player or cd player to make sure the headphones still work.
Try going to the start button, then settings and control panel. Then select "Sounds and Audio devices" Down at the bottom you should see "Speaker settings." Click the "Advanced" button and then select stereo headphones.
Then, place the headphones into the green audio jack (or the headphone jack up front if you have them), play some music, and then gently wiggle the jack to see if some of the sound makes it into the headphones. If not, try slowly pulling the headphones out of the jack while the music is plaaying. you might find that the jack has slipped a little and may play only if your connector is slightly pulled out or more firmly pushed in. If his helps, then your audio connector is loose and you should replce the sound card. If the card is on the motherboard, you can disabled it when you put a new card in.
Jul 09, 2008 | Compaq Presario 700 470024-192 Notebook
Nano shows song playing but nothing happens
Make sure your headphones are working properly by testing with your computer headphone jack.
Is the headphone port on the Nano loose?
Connect the Nano to your iPod dock and see if you can head audio through the docks headphone jack.
If the headphones work, and you can get audio out of the dock headphone port, then there is a problem with your Nanos headphone jack.
Apr 07, 2008 | Apple iPod nano 3rd Generation
Philips GOGEAR SA6045 MP3 Player Logo
60 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
