Question about IBM 300PL (PC 300 PL 733) PC Desktop
How to boot via CD-ROM in IBM PC 300
I want to install Windows XP in IBM PC 300 Pentium III 733 MHz but the bios coudn't support. How can I fix this problem ? Does upgraded BIOS help this problem ? thQ
  • 1 more comment
  • JUNAID AZEEM
    JUNAID AZEEM May 11, 2010
    Dear download the Bios of IBM 300 from the internet web site www-307.ibm.com/pc/support/site.wss/MIGR-4PXNTP.html or www.retrevo.com/s/IBM-PC300-Desktops-review-manual/id/23186bh242/t/1-2/ - and install it.
  • sivaprasadarao Oct 07, 2011
    You can change the boot up device order in the BIOS, make the CD as the first boot device. You can change it back after you have installed XP.
    how can detect the bios changing in setup
My IBM flat desktop is not booting from CD ROM, Please help me.
Posted on Aug 10, 2009
  • IBM Master
  • 32,281 Answers
Posted on Jun 18, 2009
Change boot cd rom bios300
Your IBM 300 series desktop computer is normally set to boot its operating system directly from the installed hard disk drive.
There are some cases where you may want to boot from a different device, such as loading from the floppy drive to install a new operating system.
In order to change the boot order on the IBM computer you need to access the Basic Input Output System (BIOS) menu.
Close any applications that are still running.
Turn off the IBM 300PI computer and then turn it back on again.
Tap the "F1" key when the "Configuration/Setup Utility" prompt appears at the bottom of the screen.
Tap the down arrow key four times to highlight the "Start Options" entry.
Press the Enter key.
Highlight the "Startup Sequence" entry and then press Enter again.
Scroll down and highlight "First Startup Device."
Press Enter. Scroll through the list of available boot order devices.
Highlight the device you want to use, such as "CD Drive" or "Floppy Drive," and press Enter.
Press the "Escape" key twice.
Highlight "Save Settings" and then tap Enter.
Power off the IBM computer and then power it back on.
May 06, 2013 | IBM 300PL (PC 300 PL 733) PC Desktop
Can you install windows xp on a ibm 380ed laptop
You need to make sure your laptop meet the minimum hardware requirements for windows XP . (see below)
I believe your system has a Pentium MMX 166 MHZ processor which will not be able to run XP properly.
But that's not all, You also need to make sure IBM Lenovo provides drivers for all the hardware on your 380ED, which I don't believe it does.
Minimum hardware requirements
  • Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended)
  • At least 64 megabytes (MB) of RAM (128 MB is recommended)
  • At least 1.5 gigabytes (GB) of available space on the hard disk
  • CD-ROM or DVD-ROM drive
  • Keyboard and a Microsoft Mouse or some other compatible pointing device
  • Video adapter and monitor with Super VGA (800 x 600) or higher resolution
  • Sound card
  • Speakers or headphones
Mar 21, 2013 | IBM ThinkPad 380ED
IBM NETVISTA PENTIUM 4 1,8 GhZ. error 00CE. How udate bios?
Please supply the model number of your netvista desktop. That is necessary to find the matching Bios update.
Thank You,
Brian
Jan 29, 2011 | IBM Netvista Intel Pentium 4 1.8GHz /...
Can't instal xp
You can try and tap on the F8 key when the computer is booting up and see if an optional boot menu pops up and if it does then select the CD-Rom Drive to boot from the CD, and if not then you will have to go into your BIOS setup and change the boot sequence to boot from the CD-Rom Drive first. Also, if you already have windows on the hard drive and you are using a modified boot screen you might get an error when you try to install XP.
Jun 10, 2010 | IBM (25P3294) Motherboard
Computer runs slow on some games HELP!!!!
In order to play RollerCoaster Tycoon® 3, you will need a PC running Windows with the following minimum requirements.
Minimum and recommended computer specifications are as follows:
Operating System: Windows® 98/Me/2000/XP (Windows® XP recommended)
Processor: Pentium® III 733 MHz or compatible (Pentium® 4 1.2 GHz or compatible recommended)
Memory: 128 MB RAM; 256 MB for XP (256 MB; 384 MB for XP recommended)
Hard Disk Space: 600 MB free CD-ROM Drive: 4X CD-ROM or faster (8X or faster recommended)
Video: Any ATI Radeon™ or GeForce™ 2 with 32MB or higher; or other video card with 32MB and hardware T&L (ATI Radeon™ 64 MB SDR or GeForce™ 2 Pro or other video card with 64 MB or more memory and hardware T&L recommended)*
Sound: Windows® 98/Me/2000/XP-compatible 16-bit sound card*
DirectX®: DirectX® version 9 (included) or higher
Apr 06, 2010 | Computers & Internet
I have an IBM 300PL Pentium III. Yesterday after being on for a while it went to standby. I then tried to get it going again but it cam up with an error. I resent the computer but now it comes on with the...
Did you try to press ctrl+S for set up then go to the boot menu change the start up drive to you C drive if it wont boot you can go into the setup and boot from your cd rom then follow the instructions you can repair your operating system from the cd rom when the computer asks you witch partition you would like to install the operating system on then you just choose the primary partition and when the computer ask you would u like to format the partion using NTFS do not choose this option choose the keep current file system intacted make no changes this sould get your machine to start up but you will loose most of you programmes and you wil not loose any documents.
Oct 12, 2009 | IBM 300PL (PC 300 PL 733) PC Desktop
Pentium III 500 mhz will support windows XP
Here is Windows Xp requirements:
PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
1.5 gigabytes (GB) of available hard disk space*
Super VGA (800 x 600) or higher-resolution video adapter and monitor
CD-ROM or DVD drive
Keyboard and Microsoft Mouse or compatible pointing device
Jul 28, 2009 | Intel Pentium III Xeon , 500Mhz...
WINDOWS XP
Windows xp can run on any PC that has a 233 mhz processor and 64mb of ram. Here is a list of hardware requirements for windows xp taken from microsofts website : These are the minimum requirements for basic functionality. Actual requirements vary, depending on the system configuration and the programs and features that you choose to install. If you are installing Windows XP over a network, you may need additional available hard-disk space. The minimum hardware requirements for Windows XP Home Edition are: ? Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended) ? At least 64 megabytes (MB) of RAM (128 MB is recommended) ? At least 1.5 gigabytes (GB) of available space on the hard disk ? CD-ROM or DVD-ROM drive ? Keyboard and a Microsoft Mouse or some other compatible pointing device ? Video adapter and monitor with Super VGA (800 x 600)or higher resolution ? Sound card ? Speakers or headphones The minimum hardware requirements for Windows XP Professional include: ? Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended) ? At least 64 megabytes (MB) of RAM (128 MB is recommended) ? At least 1.5 gigabytes (GB) of available space on the hard disk ? CD-ROM or DVD-ROM drive ? Keyboard and a Microsoft Mouse or some other compatible pointing device ? Video adapter and monitor with Super VGA (800 x 600) or higher resolution ? Sound card ? Speakers or headphones
Aug 29, 2007 | Computers & Internet
Open Questions:
The smartest way to keep your business files secured on online cloud backup You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Online Cloud Backup services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Computer Data Backup Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Business Server Data Backup Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Aug 21, 2018 | Best Computers & Internet
See all IBM 300PL (PC 300 PL 733) PC Desktop Questions
IBM 300PL (PC 300 PL 733) PC Desktop Logo
1,936 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
