Question about Magic Chef MCWC30MCG Compact Wine Cooler
My MCBC580DBT only gets cool not cold, anymore.No codes are displayed. Do I take off the back lower panel to investigate or the panel inside the fridge at the top??
On my refrigerator has a code er 1 f
What do I need to do to fix my refrigerator
Nov 15, 2012 | Kenmore Refrigerators
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
I have a Ruud 90 plus Achiever heating and cooling system. The blower is working. I can hear the ticking noise as if it is trying to ignite. When it does start it blows cold air. I cannot see any blockage...
This unit has a diagnostic center located on the circuit board. The unfortunate thing is that if you take off the lower panel to get to the circuit board, it opens up the door safety switch and erases the code. Look for a small viewing port on the lower panel maybe under a sticker. Read the number of blinks of a light. Open up the lower panel and read the wiring diagram for a code chart. Get back to up with the info.
Dec 21, 2009 | Heating & Cooling
My ge side by side fridge is not working properly please help me. the freezer side does not freeze anymore it's about as cold as the fridge side what can i do and what is wrong
Check the inside back lower wall inside the freezer. If it has ice built up on it, you will most likely have a defrost problem. This will most likely be a bad heater. You can remove the panel and use a hair dryer to melt ice. The heater is wrapped around the coil inside.
Nov 17, 2009 | GE Refrigerators
Refrigerator isn't working anymore
Try to completely defrost it, then if the freezer works but not the fridge change the thermostat
May 31, 2008 | Kenmore Refrigerators
Magic Chef MCWC30MCG Compact Wine Cooler Logo
Top Magic Chef Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
