Question about Brother XL-5130 Mechanical Sewing Machine
I have no idea how to use this thing. Instructions ****.
How do i thread the lower thread my new sewing machine. Trying to understand instructions but it doesnt make sense. I need a step by step guide. I have the thread in there but how do i get it to come up.
  • Anonymous Mar 29, 2014
    I cannot get beyond step 5. I have looked in my instruction book, but I cannot make out the directions from there.
    President:
  • 987 Answers
I have a white speedy lock serger model 7340. I completely pulled all threads out and now trying to re-thread new thread. I have tried around 15 times. It will not loop. Threads don't interlock at all
Be sure that you are threading each thread in the correct order. The manual should have those instructions.
ALWAYS RAISE the presser foot when threading the machine!!!! For most machines, the upper looper is threaded first, the lower looper second (the lower looper thread finishes by draping OVER the top of the upper looper and then pulled toward the back of the machine), then thread the needles. Give each thread an extra little tug when threading the tension disk to make sure it is seated completely.
Even if you are unable to locate a tutorial for your particular machine, most models from the same era will thread the same.
Don't be surprised if it doesn't work the first, second, or even the third try. It took me most of a day to get mine threaded correctly the first time!!! Patience!
How to Thread the White Superlock 534 Serger Serger Machine Series Ep 2
How to thread White Superlock serger
Sewing Machine Instructions White Speedylock Differential 1800
You can search YouTube for other videos.
Jan 06, 2017 | Sewing Machines
I'm in trouble deep-I was trying to fix an old
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Toyota SE-06 Mechanical Sewing Machine
I can't get the bobbin to thread correctly. i followed the instructions but i don't understand why it is not working. the "b" opening on the instructions are not working.
I am not clear on your problem, are you pulling your thread through slot b and leaving a tail? Please explain by the b slot not working. If, you still do not understand, go to anyplace that sells sewing machines, such as JoAnn Fabrics and have them show you, Or go to your dealer who sold you the machine,
Apr 14, 2011 | Singer 7426 Mechanical Sewing Machine
How do I thread my bobbin to my brother xl-5130
Here you are....download the manual for free.
http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL5130
Mar 24, 2010 | Brother XL-5130 Mechanical Sewing Machine
Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
Feb 19, 2010 | Juki MO-734DE Mechanical Sewing Machine
I don't understand the instructions!!
You need to have a small white pencil looking object about 2 inches long this is like and extension for the unit take off the bobbin and put the pointed end in its place then but the larger thread on and replace the plug end.
LOL
Jan 11, 2009 | As Seen On TV Handy Stitch Mechanical...
New Sewing Genie doesn't sew
they are not accurate, but also this machine is not the greatest with all types of thread, try using rayon or polyester thread when trying to wind a bobbin (cotton thread on these machines are typically sometimes hard) let me know and if this does not work ill send over what I have as far as directions
Jan 20, 2008 | As Seen On TV Sewing Genie Mechanical...
Brother XL-5130 Mechanical Sewing Machine Logo
183 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
