Need manual to see hose hook up to pump
SOURCE: Eurotech MA66 front loader user manual
Click on washing machines (below FIXYA )on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line. If available that is.
And rate me pl if helped............
SOURCE: How do I get a repair manual for my Kenmore front loader
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: my ge front end loader washer won`t spin water or
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
SOURCE: How do I clean the
please go through this
http://www.youtube.com/watch?v=x7rJkWE0nN0
Examine if there's a problem with the filter. If the machine isn't draining, spinning or agitating, the washer pump filter may be clogged, and you should clean the pump filter. Other giveaways that the filter may need cleaning include the washer performing an incomplete cycle, the timer not advancing or the washer just not running Clean the filter with your fingernails, removing all loose debris. Wash the filter under running water until it is clean. Replace the filter. Insert it back into its housing, turn it clockwise and close the door.
Instructions:
i hope this helps you ,thank you
