Question about Troy-Bilt Chipper Shredder
Removing wheel how to remove wheel on cs4325 chipper shredder
4 Suggested Answers
Dolfoff
  • 148 Answers
SOURCE: looking for manual for craftsman chipper
The manual can be found HERE.
On the left side of the page, under "Browse Subcomponents" you can use your RIGHT mouse button to open each page in a seperate window. This reduces the use of your BACK button, and personally, I find it more convenient.
Hope this helps.
Dolf-
Posted on Oct 10, 2009
  • 243 Answers
SOURCE: I have a troy built 250cc chipper shredder.. it
hi yes you can. when you take the back off you can reach the cuttingwheel and clean everything. after that its ready to use again.
Posted on Feb 17, 2010
Testimonial: "Thanks for your help ... My neighbor actually unclogged it for me ...but I don't think he took the back off . It's working fine now.."
  • 113 Answers
SOURCE: replacement blades for Troy-Bilt chipper-shredder
The knife kit for the 47042 and 47044 Tomahawk Pro chipper is part number 1772231MA.
There are several for sale on Ebay or from a Murray dealer
Posted on Aug 18, 2010
Why won't the pull cord budge?
My first idea is that the engine was shut off before the chipper or the shredder had not finished. First remove the spark plug. Next remove the covers on the chipper area and the shredder area. Now remove all material from both areas.Replace all covers, put the sparkplug back and try it.
Sep 28, 2015 | Craftsman LEAFWACKER 3-Way Chipper...
Sharping the blades
I dont think you need to remove the fly wheel to sharpen blades. Remove the housing an the blades are visible an removed that way. Not a hard job at all.
Mar 24, 2014 | Central Machinery 5-1/2 Horsepower Chipper...
I need to sharper the blades. How do I remove the fly wheel
The flywheel takes a puller, but you should not have to do that just to sharpen the blades.
How to remove tire on Troy Bilt chipper shredder
there is either a clip or a cotter pin that needs removed , then slide the wheel off .
Nov 19, 2013 | Troy-BiltĀ® Briggs and Stratton Chipper
Cub cadet chipper shredder starter coil is locked - will not pull
REMOVE THE SPARK PLUG. You now can safely take apart the unit to remove the covers over the chipper and shredder blades and remove the material stuck in the blades.
Aug 23, 2013 | Cub Cadet CS2210 - 2" 208cc Tow-Behind...
How do you change the cutter blade on the TB Chipper?
I just did one!
There are two opposing threaded holes next to the shaft.
Screw in bolts and use a wheel or gear puller to remove.
You can use a socket that fits in the center bore for an extention of your gear puller.
auttozone or ayto supply rents for free w/deposit
May 22, 2010 | Troy-Bilt Chipper Shredder
Jan 30, 2010 | Troy-Bilt Chipper Shredder
Troy-Bilt shredder model 204 tire problem.
Put a ratchet strap around the tire and tighten it up until you seat the beads enough to get some air in it and then you can fill it back up from there. hope this helps you
Oct 26, 2009 | Troy Bilt Walk Behind...
Chipper Maintenance
Maintenance (excluding the power plant) Your primary maintenance concern with chippers and shredders is their knives. You can re-sharpen chipper knives, whereas you can reverse shredder flail-type knives when dull but you can not re-sharpen them. You must sharpen chipper knives with special sharpening equipment because they are made of high-carbon steel. Maintaining sharp knives can lengthen their life and the life of the machine by keeping power requirements low. An over-dulled or chipped chipper knife will need extensive sharpening, which will remove a large portion of the blade. This obviously will shorten its life. As soon as a blade is slightly dull, you should sharpen it to minimize the amount of blade-material that you remove. All knives need sharpening at the same time to keep them in balance-even if only one is worn or chipped. Also, you must use matched sets to keep the knife the same distance from the anvil for proper chipping and feeding. After removing the knives, clean the area where they are fastened with a wire brush to make sure they will align correctly. Be sure to torque the knife bolts to their proper specifications. You will need to examine the anvil and be sure it maintains a good, square edge. Occasionally, you may need to remove and sharpen it.
Aug 27, 2008 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Troy-Bilt Chipper Shredder Logo
75 people viewed this question
Top Troy-Bilt Heavy Machinery Experts
quennie732
Mike
cwradio73
Are you a Troy-Bilt Heavy Machinery Expert? Answer questions, earn points and help others
