Question about Rheem 2.5 Ton 13 Seer / Ruud Heat Pump System - RPNL030JAZ - RHSLHM3017JA
Rpnl-030jaz condenser fan not turning - Rheem 2.5 Ton 13 Seer / Ruud Heat Pump System - RPNL030JAZ - RHSLHM3017JA
  • 60 Answers
If the fan does not run then it could be a bad motor or just the capacitor is bad. usually I check the capacitor first. it usually goes bad before the motor
Posted on Mar 10, 2016
NEED TO KNOW THE TONNAGE ON THIS UNIT
2 1/2 ton. home is about 1200-1400 square feet ?
Apr 18, 2016 | Ruud Matching Split Air Conditioner
Ruud UAKA-030JAZ fan spins, not blowing cold air
there are 3 things to be considered,first,if the compressor motor `s connectors are having loose,it gives a hi ampere to your RELAY that can cause to its contacts being fried,second,the compressor motor itself is gaining a hi ampere already i.e. having unusual sound that can cause heavy friction inside the turning mechanism and third the last but not the least,maybe this time,the tubes or the compressor itself having very small holes that causes to the refrigerant to escape and it doesn`t gives off cold air.
Apr 17, 2014 | Ruud Heating & Cooling
Air conditioner condenser and radiator fan stays on in 1999 honda accord
It is normal (required) for the condenser fan to continuously run while the ac is operating. It is like that on almost every vehicle.
Mar 15, 2017 | 1999 Honda Accord
Rheem RPKA-030JAZ MAKES A HARD KNOCKING SOUND
sounds like it's running backwards. possibly need a time delay in the condenser. make sure your drain line is clean.also inspect low voltage wires for bare/ chew spots near outdoor unit.
Oct 12, 2017 | Heating & Cooling
Condenser fan motor for upmd-030jaz
see the w .diagram behind your unit for specification.
or your must open the condenser unit for to see in the plate motor the specifications.Or cal the customer support for get help
God bless you
May 09, 2012 | Ruud UBHC Air Conditioner
Replacement for 20yr old A/C system
I you have a 2.5 ton condenser on a 3 ton coil, and he gave you an estimate for a 1.5 ton condenser only, he missed something, or you need a second estimate. Now if give you an estimate for a complete system, with a 1.5 ton condenser/evap, coil, your ductwork will/may be oversized for that unit. Need a second estimate. You've been happy with a 2.5 ton cooling capacity in the past, don't settle for anything less, unless you've completely updated with new doors, windows, insulation, ect.... I'd call around and ask for an estimate, with a load, and then ask for the cooling tonnage and furnace BTU's from that load, when they call with the price. Most reputable companies will/can prove a proper load calculation and my city just made it mandatory to prove a load was achieved when a permit is pulled due to the Dept. Of Energy passing laws on this subject in 2015. Ask if its mandatory for a load calc. if they pull a permit. And they are supposed to pull a permit in city limits I'm sure. It's not a good practice to miss match systems with current designs. 20+ years ago it was, but now there are codes against this practice. And also shortcuts to try to make more money with less invested may not be considered GOOD PRACTICE. Hope this helps!
Mar 13, 2017 | Heating & Cooling
I have a ruud model # UAMB-030JAZ.The outside compressor kicks on when I push the high pressure reset button but the fan doesnt kick on. How do I test the capacitor and the fan motor if those may the...
you would need a multi meter.check resistance on motor windings for continutity. check microferets make sure it matches data on capacitor to be good
Aug 29, 2009 | Heating & Cooling
I have a Rheem Model # RAMB-030JAZ that the fan will not come on when the A/C is turned on and does not produce cold air. Is there a common electrical problem for this model that would prevent it from...
The unit has a fan relay that sometimes goes bad. Check to see of fan is hot or tryimg to start. Might be bad capacitor. Fan relay or relay boards are easy to change.Russ
Jul 30, 2009 | Heating & Cooling
Evaporator fan turns on. compressor and condenser fan do not turn on.
Sounds like low on refrigerant charge. Low pressure switch keeping the compressor and condenser fan from running.
Jun 05, 2009 | Carrier Heating & Cooling
Condenser fan stoped after about 45 min of running
your condenser fan is over heating. you need to replace your condenser fan and make certain you replace you capacitor as well.
May 05, 2009 | Heating & Cooling
Rheem 2.5 Ton 13 Seer / Ruud Heat Pump System - RPNL030JAZ - RHSLHM3017JA Logo
80 people viewed this question
Top Rheem Heating & Cooling Experts
jeff5may32
billconfused
Lawrence Oravetz
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
