Question about AT&T EP5962 Phone
Cordless base does not charge any more, already replaced battery in phone
4 Suggested Answers
SOURCE: cordless phone does not connect
You may need to reset the Telephone Answering System. Complete the following steps to reset the Telephone Answering System:
Step 1: Disconnect the power to the telephone base.
Step 2: Wait a few minutes and then reconnect the power to the telephone base and charger.
Step 3: Set the day and time.
Posted on Apr 03, 2008
  • 4 Answers
SOURCE: cordless phone wont work properly
Unplug The Base than take batteries from the phone after 15 seconds power it back on, viola you should have it working
Posted on Jun 12, 2009
SOURCE: Cordless phones display searching for base.
Same problem: registering base ID on cordless get T23 PD error and subsequently, Searching for Base
Posted on Sep 29, 2009
How to return product KX-TG9333T purchased Premium Store.com. Item is same as already have. Thought it would be an upgrade.
The hand set never worked since I bought it. All other hand sets work as well as the base. I would like you to send "free of charge" a replacement hand set as well as the base for the hand set Hand set which never worked has #OGBXBO61363 UNDER THE BATTERY COVER. wE TRYED REPLACING BATTERIES SWITCHING BASES ETC.
Oct 17, 2011 | Panasonic KX-TG9333T Trio Cordless Phone
How do i recharge my uniden phone battery
Phone's "Status Light" Not Illuminating or Battery Failing to Charge
  • 1.Check that the base unit's AC adapter is plugged into the both the base unit and electrical outlet firmly.
  • 2.Wipe the base unit's handset holder's connectors and the connectors on the bottom of the handset with a soft cloth/rag or pencil eraser to remove any loose dust and dirt from the metal connectors.
  • 3.Place the handset firmly in the base unit holder until the "Status Light" illuminates, indicating the battery is charging.
    4.Replace your Uniden cordless phone's battery, by purchasing a compatible battery from an electronic supply store or directly from Uniden. Turn your phone's handset unit over and remove its battery door. Lift the phone's battery pack up and gently unplug the battery's wire connector by pressing in on the connector's side and pulling the connector free from the phone's circuit board. Battery installation is the reverse of removal.
    Read more: Troubleshooting a Uniden Cordless Phone ' eHow.com http://www.ehow.com/how_7252483_troubleshooting-uniden-cordless-phone.html#ixzz1Wkmk0pxX
    Sep 02, 2011 | Uniden Cordless Phone
    Getting msg 'PILE FAIBLE' on my GN7170 Cordless phone. What does it mean?
    Pile Faible is french for 'low battery'. This indicates that either your base station is not charging the phone or the rechergeable batteries need replacing. Is there an indicator light on the base station that shows charging is taking place? If that does not light when you replace the phone on the base try cleaning the contacts on the phone and the base with spirit (methylated spirit or other pure alcohol - vodka will work!)
    Jan 04, 2011 | GN Netcom GN-7170 Cordless Phone (GN7170)
    My phone is display out of range
    1. hi..
    2. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
    3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
    Jan 03, 2011 | Uniden Cordless Phone
    I have a panasonic KX-TG5431and for a cordless i have no link to base and the cordless off. the battery is slow after charging. Thanks
    Hi, I have the same problem. My set is Panasonic KX-TG6522C. Please let me know how you fixed this issue (if you already have)
    Dec 13, 2010 | Panasonic KX-TG5431 Cordless Phone
    My mother-in-law has a uniden phone (with four cordless) and all 4 of the phones show low battery even though the have been sitting in their bases charging. Any thoughts? Thanks in advance
    are the charging bases plugged in and turned on? If they are..try replacing batteries on one and see if it works....if so replace all batteries
    Jun 15, 2010 | Uniden Cordless Phone
    How do i put the ring tone back in the handset
      Does the Phone Power Up?
    1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
    2. Does the Battery Hold a Charge?
    4. Listen for a Dial Tone
    5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
    6. Listen for Static
    7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
    8. Verify Your Handset is Registered
    9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
    10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
    11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
    12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
    Nov 17, 2009 | Uniden Cordless Phone
    Thomson GE DECT 6.0 28213 Cordless Telephone
    I finally find a way to stop this problem from occuring : never leave your phone on the charger with the battery isnt empty !
    I know this sucks because what best place to put your phone at night than its base. But try it and it will work (unless your battery is already damaged). In the morning when i go to work, I charge it for 8 hours, then when I come back, I take it off the charge until next morning.
    I used to put it on the charge for all night and all day until I read an interesintg post :
    http://en.allexperts.com/q/Telephony-Clecs-Long-2450/Cordless-phone-interference.htm
    Since I have been doing this, I didnt get any more problems with my phone.
    May 28, 2008 | Thomson GE-28115FE1 Cordless Phone
    Motorola MD760 dies after 5 minutes of use-- from being charged for days on base
    this is a battery prob replacing battery will solve this prob hope this solves your prob make sure the battery connectors are conected propery securely first before replacing if ok then replace batt and prob should be solved check then conectors are clean where the phone sits on base and check phone sit on base properly if it does then it is def the batt replace.
    Nov 15, 2007 | Motorola Mobility MD761 Cordless Phone
    AT&T EP5962 Phone Logo
    Top AT&T Lands Phones Experts
    george  peters
    george peters
    Paul C.
    Level 1 Expert
    Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
