Question about Toshiba 32A41 32" TV
How to get audio on the tv from DVD player
I'm trying to hook up a brand new DVD player to the TV and although we have a picture we don't have sound. I bought an audio converter and splitter and have tried again but still no sound..
SOURCE:
snakehead
  • 1074 Answers
SOURCE: No sound
If the tv does not have sound with out connecting the dvd then you are having a problem in your audio circuit have a tech look at it.if its only when you connect the dvd then you could have connect cables wrong.you cannot route a dvd through a cable box.any dvd s compatible with tv so long as the connections are there. goodluck.
Posted on Mar 23, 2007
  • 77 Answers
SOURCE: Toshiba CF36G40 36" TV (picture snowy)
you have a bad tuner you can replace it or use vcr if you still have one around. hook it up with av cable like your ps2 and hook your cable to it and use it to change channels. If you want to replace the tuner it will require soldering and you will have to order it somewhere. i would try partsore.com. The tuner is the metal can the cable goes into inside the tv.
Posted on May 12, 2007
SOURCE: No sound on my toshiba television
Go to the setup menu and turn the TV speakers back on.
Posted on Feb 16, 2008
yambo
  • 230 Answers
SOURCE: Toshiba 36AFX61
Just Connect signal to tv and run autoprogram. Or use video input jacks from converter to tv ( yellow,white and red video in ) and select tv/video on tv pannel front ( don't need remote control) I hope this work for you.
Posted on May 11, 2008
ebrus
  • 30 Answers
SOURCE: connecting VCR to TV
If you have the original remote controller, try to switch inputs. It must be on the f-connection ( coaxial) at the moment. You need to switch it to RCA or S-Video Inputs.
Posted on Oct 15, 2008
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
We are trying to connect our Sony DVD player to our Toshiba Tv We plug it according to the diagram. We get no sound or picture although the power is on to the DVD player. We have the TV on Channel 3 ....
Make sure the connections are correct according to the Diagram.Sony DVD player Video Out and Audio out should be connected to Toshiba TV ,AV1 or AV 2 Etc. don't forget to switch the TV from TV mode to Video mode (Input mode)
Jun 13, 2011 | Televison & Video
Just moved, hooked up DVD player to new TV. Sound
if you have a picture on the tv from normal channels and/or cable, then i would suspect the scart lead may have a bent pin at one end or both or is not inserted fully.
Feb 20, 2010 | GPX D1816 DVD Player
I can't get a picture on tv when turn on dvd player why? brand new, never used before.
have you connected the DVD into the right plugs, also are you using the correct AV channel on the TV?
RED WHITE YELLOW yellow is video red is L sound White is r sound. check both TV input and DVD output
Aug 14, 2009 | RCA DRC8335
Connecting dvd to tv
It sounds like you may have a connecting cable problem, although it could be the player itself is bad. Make sure you haven't gotten the video and audio connections switched around if you are hooking the player to the TV that way. If you are using an RF connection to the TV's antenna input, be sure the TV is on the right channel (3 or 4) to match the player setting.
Nov 21, 2008 | Televison & Video
Lightning mcqueen tv and dvd set-up, won't play, have direct tv hook-up
i guess there a built in dvd player on the set and it could play most DVD format.
but if you wish to use another dvd player
hook up the dvd on the tv
video output (DVD) to video input (TV)
audio output to audio input
the find the auxiliary button from either the tv or dvd
Oct 30, 2008 | Disney DTD1363-CAR 13" TV/DVD
Hooked up dvd and vhs player good picture no sound please help
look carefully whether you jacked the audio out from DVD and audio in into the TV
> the TV is having a Audio out and in jacks
>if you jack a the audio out from DVD into Audio Out in TV you wont have audio
May 08, 2008 | NEC MultiSync LCD4010 40 in. Television
Trying to hook up dvd player with sanyo tv. Also hook this up to satellite and surround sound. No picture, just audio.
Well are you ready for this I hope you can under stand if not maybe I can draw a diagram. Starting with your stereo take the component video out and goto component on the back of your tv to component in then the stereo coaxial in to the digatl audio out on the DVD player then DVD player anntena out to TV anntena in then DVD anntena in to reciever anntena out and Sat cable to reciever. also s-video on Dvd componet to s-video on TV DVD player Audio out to Audio in on TV. Set Stereo to TV and DVD player to channal 3 or do auto scan and TV will work on 3 with the reciever and also TV works with Video 2 I hope this works for you good luck
Jan 03, 2008 | Sanyo DS31590 31" TV
Hdmi not working
You need to set up the out put of your DVD player. First hook up a non hdmi output to the tv, either component or coax. You don't need to hook up the audio. You should get a picture from this connection. Then you can go into the menu and set your hdmi output to match your tv, probably 1080i. You may have to turn your volume up higher when using the hdmi cable than not. I hooked my audio up directly to a surround sound and don't use the tv's speakers.
Dec 01, 2007 | RCA DRC-285 DVD Player
Toshiba 32A41 32" TV Logo
15 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
