Question about Directed Dei Valet 561r Remote Start/Keyless Entry
How do i program my dei valet 552t remote? - Directed Dei Valet 561r Remote Start/Keyless Entry
4 Suggested Answers
  • 171 Answers
SOURCE: my dei your valet remote start turns the engine
Check tack wire it has to be programed
Posted on Jan 07, 2010
partyd
  • 141 Answers
SOURCE: Have had a Dei valet 561r remote on my Honda van
sounds like your car battery was also replace or it die
believe it or not the remote start needs to be reprogram again
find the valet switch, this what you are going to do
make sure ac radio and any other accesorie are off
start the car with the key within 2 seconds or less press and hold the valet swith, and way until the
led turns on and the parking lights on the vehicle flash about 12 seconds
no turn off the car close the door and start the vehicle with the remote good luck
Posted on Nov 21, 2010
logosc75
  • 625 Answers
SOURCE: I recently replaced my ignition
Your bypass module has to be reprogrammed if, you have the type that is programmable. If you have relays with inline resistors then they have to be replaced with new resistors. If the ignition switch was swapped out for a new switch, with a new key, the resistance is no longer the same. If the entire ignition harness was changed then the remote starter has to be re-installed at the switch(behind the radio).
Posted on Nov 24, 2010
Need to program rpn471t but I don't have a valet button in the car
Hello Lacey,
The only way to program an additionally remote on one of there systems is with a valet button. I would recomend that you contact a local install shop like Best Buy that works with DEI products. They likley will be able to program the remote for you.
Oct 27, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Tip
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
on Jul 29, 2010 | Car Audio & Video
I need to know how to program remote
To program a new remote to the system; open door, turn ignition on, press and release valet switch one time then, press and hold valet switch. System will respond with a chirp. Now press lock button on remote. System will respond with a long chirp.Turn ignition off. Test system. Repeat for additional remotes.
Sep 28, 2012 | Dei 7641v Responder Remote 160xvl 7641
Remote starter instructions
First, locate your valet/programming switch. Once you have located the switch, turn the ignition on, press and release said switch then press and hold. Now, while holding the switch, press the lock button on the remote. the vehicle/alarm should respond with a chirp/horn honk. Release the valet switch, turn the ignition off, test the system.
Jul 25, 2012 | Vehicle Parts & Accessories
I lost my keyless for my remote started valet 561r now i bought the keyless and i don't know how can i program it can you help me with that....??? Thanks you....
turn the key to ON, then press and release the valet/program button once, then press and hold. The 561R LED will begin to blink. While you're holding down that button, press and release lock on the remote. Turn ignition off and try it out.
Mar 06, 2011 | DEI Valet Keyless Entry System
We just realized that the previous owners of our vehicle had already installed a Python 1400XPL remote start system, but did not provide the remotes. I was going to try to program my spare remote from my...
Any valet switch will work. Then simply program your remote. As long as you have a DEI remote there should be no problem unless you are trying to program a two way remote (pager) to a one way system (non pager)
Jan 10, 2011 | DEI Python 1400XP Remote Start/Keyless...
Lost Transmitter
I had a remote that didn't work and I found the 561r complete remote start system on ebay for $32.00 including shipping so I bought that and within 2 minutes had the new remote programed and now I have the main unit in case mine goes out also.
May 16, 2010 | Directed Dei Valet 561r Remote...
I have a 471t model remote starter, it fires up
Could be one of a couple of things. Tach not programmed properly or wire not connected correctly. Or the immobilizer bypass is not programmed or working properly.
Oct 18, 2009 | DEI Valet Keyless Entry System
How would i program the valet 473t remote for a 2003 dodge ram 1500
Call DEI customer service at 888-425-8890. They make this remote.
Here'a a link to the Valet 561R user manual (which uses this 473T transmitter) too but it just gives basic operation info:
http://www.directeddealers.com/manuals/og/valet/G561R_07-05.pdf
Jul 02, 2009 | Directed 473T Remote Control
Directed Dei Valet 561r Remote Start/Keyless Entry Logo
118 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
