Pressure wash outside of house - Computers & Internet
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 5 Answers
TEN MINUTE SEMI-AUTOMATIC TRUCK WASH
WINDSOR-ESSEX COUNTY'S FIRST STATIONARY TRUCK WASH! http://mammothtruckwash.com/
Visit this site for more service.
Truck Wash Windsor Coming Soon! - With low prices, short wait times and industry leading service quality Mammoth Truck was will soon be the easy choice in full service wash solutions for trucks, boats, RV's, buses and and any other large oversize vehicle.
Posted on Sep 29, 2016
I have a Rheem Stella 850 series 360 L which is one year old. I have noticed the last few days that the hot water pressure is dropping and water flow is fluctuating in and out.
Did you do back flow? Suggest you perform back wash via the hot water outlet of your heater by plugging a hose. What is the tubing size that flows thru the heating elements? If it's small, maybe you need to apply higher back pressure to remove the soil. Does it have a built in pump? If it has, check the ******* strainer, maybe it's cloaked up with debris, you never know what's in the line.
Jun 21, 2016 | Rheem Water Heaters
Why is my fisher & paykel washing machine leaking into the drum from the nozzle spr? I have replaced it once and it quit leaking for about a week, but is leaking again.
Barring another bad water inlet valve, one train of thought is that the PRV (Pressure Regulator) Valve to your house is bad.
Go to the hardware store and buy a water pressure gauge. Screw it on to an outside faucet (where you hook up your garden hose). Then turn the outside faucet on and check the pressure reading. It should be between 30 and about 70 psi. If it is above 75 psi, your PRV valve to the house is bad and needs to be replaced by a plumber.
Oct 13, 2014 | Fisher Paykel EcoSmart GWL15
What kind of prep work do I need to do before I paint the outside of my house?
Not sure how this pertains to a car or truck.....but you should scrape or high pressure power wash the entire outside to remove any dirt, contaminates, or loose paint. Then a coat of quality primer and finally a good coat of quality paint. Done correctly with quality materials you should end up with a paint job that will easily last 10 years or better.
Jul 26, 2014 | Cars & Trucks
Yearly routine maintenance of outside unit-central air.
Clean the coil. If you are a bit mechanical, Switch off the unit at the box on the side of the house. Remove the top cover with the fan attached. Have a helper hold it out of the way, and pressure wash the coils from the inside of the unit out or back-flush the coil. That is about all there is to the maintenance of the outside unit.
Sep 18, 2011 | Weather King Heating & Cooling
Loud vibrating sound coming from hot water heater. Had gas company change meter and regulator. At first was losing hot water while in the shower. Went through check list after it coded out at #12, all...
Can't address other issues, but WATER pressure should be 40 to 80(I'd say 70)lbs. tester at home D for $10-15. Goes on hose Bibb outside, or at washing machine cold valve.
Mar 18, 2017 | Rinnai Water Heaters
I have purchased a Procom ventless heater (ML250TPA) and need to know if I have to put a low pressurer reg. on the system outside or will this model heater reduce the propane pressurer coming from my 500...
This heater is designed to work with LP gas. You will need a regulator from the tank to the heater set at 11"wc .that's standard for any LP gas system. Your existing piping system should have a regulator already outside of your house before the gas inters your home .If it does not then you will have to install one. The regulator can be inside but you will have to run a vent line in copper from the regulators vent to the outside of your house.
Hope this helps ......
Nov 23, 2010 | Heating & Cooling
High ampere compressor
not clear on this post. If you are stating that the compressor is pulling high amps, you probably need to clean your outside coil. Shut the unit off, remove the housing, and use a regular garden hose to wash all of the dirt out. DO NOT USE A PRESSURE WASHER.
Oct 04, 2009 | Dometic Rooftop RV Air Conditioner
Replaced pump and presssure vessel, water outside
If your like me your house has a pressure regulator to keep the pumps high cut out pressure from blowing your lines. Also a lot of domestic wells have a filter at the house to keep sediment out.
Sep 06, 2009 | Plumbing
Samsung washer
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 28, 2009 | Samsung WF337AA Front Load Washer
Washing machine water shutoff valve can't close
what you need is a pressure pliers tool , that will do the job, thanks AJ
May 10, 2008 | Kenmore Elite 45986 Front Load Washer
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
