Question about Craftsman 48" Cut Riding Lawn Mower Deck Belt 174368
Craftmen drive belt DTY4000 - Craftsman 48" Cut Riding Lawn Mower Deck Belt 174368
Craftmen gt 5000 pto will not ingage
need to check the deck --bent or damaged--blades,mandrel,pulley,pto cable,tentioner and belt pop
May 05, 2017 | Cars & Trucks
Craftsman dty4000 24hp. installed new motor and now when you let out the clutch the motor dies. why?
Micro switch issue, usually the seat switch, also check the block connecter onto the switch it needs to be firmly pushed home, if not they have a fail safe in the block lest it comes off the switch.
Jun 20, 2012 | Craftsman Garden
I just cleaned the carberator and new sparkplug it sounds like it not getting fuel when i put alittle gas in the carberator it starts and obviously stops? on my craftmen weedeater
if it is an older one, the gas lines like to rot away. you can usually tell by looking down inside the gas tank. you can also check to see if the primer is moving the fuel through the lines as you prime it
Jul 07, 2011 | Craftsman 25cc Gas Line Trimmer
Craftmen key pad will not open garage but will close it
If the battery is good your keypad may just have a weak signal and needs to be replaced.
Aug 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a 12.5hp Craftmen riding mower with the
The battery or check cut off switch under seat if it disconected it won't run.
Jul 06, 2010 | Craftsman Garden
How do I reprogram my wireless keypad?
Locate the smart/learn button on the rear of the motor unit just to the left of all those white wires. Press and immediately release this and then walk over to the keypad and key in your 4 digit PIN and press enter.
Sep 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftmen mower doesn't cut well on right side
Sounds like you may have made a common mistake, getting one or both of the blades upside down.
Jun 28, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftmen dyt4000
the manufacturers fluid recomendation should be written on the fluid cap or in your owners manual. if not most reecomend a 10W-30 synthetic blend
Oct 24, 2008 | Craftsman Garden
Craftsman 48" Cut Riding Lawn Mower Deck Belt 174368 Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
