Question about Kirby Vacuums
Makes squealing noise
The fan shaft squeaks after I vacuum then in a hour it don't squeak
  • Kirby Master
  • 1,886 Answers
Dirt behind or ballbearing are you shure its the fan ? , the carbon brushes can also made sometimes a noise on the collectors of the commutator circuit if ingrained on the armature.
Posted on Nov 02, 2015
3 Suggested Answers
  • 190 Answers
SOURCE: Flair Cleaner makes squeaking noises
There are two items that could squeak:
If it squeaks when pushing/pulling it on carpet, WHILE NOT RUNNING, then the wheels are squeaking when they rotate on the wheel shaft. If so, one drop of oil at the shaft would fix it.
If it squeaks WHILE RUNNING, mostly while pulling backwards on carpet, then the belt is slipping. You may wish to set the nozzle height setting for a higher pile carpet, or could replace the rubber belt.
Posted on Oct 26, 2009
bissellcs508
  • 315 Answers
Life Inspired Cleaning Innovations
    Verified Fixya Pro
    SOURCE: makes a squeak noise some times.
    I'd have a qualified technician at a BISSELL Authorized Service Center inspect your machine. Here's a link to locating one.
    http://www.bissell.com/service-centers/?cid=ccsocial
    Posted on Dec 05, 2012
    How can I stop the squealing noise in the motor on my Sanitaire wide track commercial vacuum? It's making a squealing the minute I turn it on
    Is it the motor or the brush roll? Remove the brush roll and belt and see if it still squeals. If not clean or replace the brush roll and get a new belt. Inspect the fan to insure there is not something stuck in it. If it's the motor you can try to clean it, make sure there is not something stuck in the motor causing the noise.
    Jan 23, 2017 | Vacuums
    How do I fix a squeak in a hardwood floor
    squeeks in a hardwood floor most times are caused by the hardwood separating from the underlayment (board) and hence it piviots on a nail and you got a squeak !! , there are a few ways to fix this "
    if the squeak is located in a spot that is accessible from under the floor , see if you can determine what hardwood and underlayment thickness is , look around behind a floor casement or around a doorway trim with flashlight , find a wood screw that is 1/8 less than this number (two added together ) also locate a drill that is just size of screw shaft you found , drill hole from under the floor (underlayment) just deep enough to penetrate the underlayment (3/4 inch or so) use tape on bit as a gauge , don't drill into hard wood then drive wood screw into hole , the idea is that screw will pull hardwood down to underlayment , screw cant grip underlayment due to hole so this is piviot point . a shot of wood glue on screw threads helps it from coming out too !!
    now if space under squeak isn't accessible this is a bit harder but not impossible to do , there are a few special items to get first , one is a glue injector needle !! this typically is used making wood furniture but I have seen a meat basting syringe used in a pinch too, locate the spot close to squeak from top , using a small drill dril down at seam (not in middle of board) just deep enough to hardwood Not underlayment , load up your syringe with wood glue and force it down into hole with needle takes some force to do this , wipe off spilled glue and set a heavy object on this spot for 24 hrs object can be a lg pile of books or I use cement blocks (4) set on a piece of butcher paper (not cardboard) after 24 hr remove blocks and ck for squeak if none use hard setting tinted wood filler to plug hole you made and top off with a dot of varnish to seal it when dry and flat if you still detect the squeak then move over a board or two and repeat process till squeak is gone
    Jan 03, 2017 | Vacuums
    Vacuum squeaking loudly!!!Help!!!!
    Most likely has a bunch of hair wrapped around the beater bar. Get some scissors, razor knife and some needle nose pliers. Turn the bottom up and remove the cover and start digging the hair out. You may need a new drive belt too.
    Nov 07, 2015 | Vacuums
    If squeaks really loud, when I am vacuuming. Why is this happening!?
    probably fond the blades in the impeller have come loose and need a new unit
    contact a vacuum service center and have a diagnosis done
    may be cheaper to get a new unit if that is the case
    Why is dryer squeaking,belt sprayed but still squeals.
    If the belt is to lose it can slip and squeal. worn out belts do the same.
    Jul 12, 2014 | Eureka 431BX Bagless Upright Vacuum
    How to fix squeaking and bag full sign lit on the sebo x4 extra upright vacuum?
    Check the main "kitchen roll" filter isn't clogged which is on the left hand side of the bag when the bin door is opened. There could be a clog, either behind the pick out metal grid below the filter roll, or the roll filter requires to be replaced. Can you add more info about the squeaking though? Is it a high pitched squeal all of the time or just intermittent and where it seems to be coming from - it could be excess air escaping from a pierced hose or a drive belt issue.
    Oct 30, 2013 | Sebo X4 Bagged Upright Vacuum
    Makes a squeak noise some times.
    Dec 01, 2012 | Bissell Powerforce Bagless Upright Vacuum...
    Oct 25, 2009 | Hoover Vacuums
    Rainbow SE makes Squealing Noise when switching it On/Off
    http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=528929
    Rainbow SE makes Squealing Noise when switching it...
    Posted by ray_s51 on Apr 20, 2008
    My Rainbow SE works and runs strong but when I switch it on and off for approx. 20 to 30 seconds the motor makes a loud squealing noise. Do I need to oil something or what? Nothing smells, it does not make the noise all the time, but it does more often than not. Thanks
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum.
    The Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit. Watch out… the repair of the Rainbow may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. The separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    The Rainbow / RexAir Factory phone number is listed below:
    http://rainbowvacuum.com Customer Service
    1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
    Thanks, Don the Vac Man
    Go Ahead. Use Us.
    Apr 20, 2008 | Rainbow E series Canister Wet/Dry Vacuum
    Vacuums Logo
    69 people viewed this question
    Top Kirby Vacuums Experts
    Jim Parker
    Jim Parker
    Richard Agent
    Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
