Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Paper not feeding correctly
The paper is being fed unevenly. The printer seem sto grab the paper on the right side, pulling it down so that is gets jammed and crumpled.
Need help asap please.
Regards
GH
  • 41 Answers
Sounds like there is a piece of ripped paper in the printer
Posted on Jun 18, 2009
When the paper is fed it is pulled in w/ the bottom right side of the paper going in but not the left side, it becomes uneven and ends up jamming - what would be the reason it would grab and pull the right...
The most likely cause of the problem is an obstruction on the left side of the paper path - most likely a shred of paper from a previous jam. You can estimate where to look by how far the paper goes in before it starts to twist to the side. Sometimes I've had to use a dental pick to snag a shred buried deep inside as an alternative to dismantling the printer. You may find it helpful to use a small mirror to look underneath or behind rollers while you search for the culprit.
Another possibility is one side of a dual pickup roller (two rollers on a single shaft) is worn out. That is unlikely; except for large format units most printers use a single pickup roller.
Jun 06, 2011 | Epson Stylus CX9400 Photo Printer
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
Paper is pulled into printer unevenly causing paper jam
Look closely at the "path" that the paper takes through the printer -- you probably have a small piece of paper stuck somewhere, that is causing the paper-feed to get "skewed".
Failing that, take the printer to a qualified technician.
May 26, 2010 | Dell V313w AllInOne InkJet Printer
Paper is being fed through the printer crooked. Almost like the paper feed wheel is not working properly, being pulled down in the right side, but not on left = big mess
You probably have a piece of paper stick in the pickup carraige. Get a flshlight and a tweezers and see if you can CAREFULLY pull out any pieces of paper...
Feb 16, 2010 | Canon MP610 Photo All-In-One Printer
Canon pixma ip 1600. paper feed mechanism faulty. will not grab paper and feed through or takes it through at an angle
You said that the paper is fed on one side. Am I right?. If it so,it seems that another material is present inside your printer.
Please check this post for more information
Nov 29, 2009 | Office Equipment & Supplies
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon ip90 printer wont grab paper
The most likely culprit is that the rollers that pull the paper are dirty. Use the steps below to clean the rollers.
1) Confirm that the printer is powered on.
2) Remove any paper from the printer.
3) Press and hold the <Resume/Cancel> button.
4) Release the <Resume/Cancel> button after the Power lamp blinks three times.
Note: The Power lamp will blink and the paper feed roller starts cleaning itself by revolving.
5) When the Power lamp lights in green, repeat Steps 3 and 4 up to two additional times. (Please wait approx. 30 seconds for paper feed roller cleaning to complete.)
6) To confirm whether cleaning has been performed properly, set a blank sheet of plain paper (8 1/2 x 11 Letter size) in the sheet feeder or cassette.
7) Press and hold the <Resume/Cancel> button and release it when the Power lamp blinks three times. (The paper set in the printer is picked up and fed.)
8) Repeat the process as necessary
May 12, 2008 | Canon PIXMA iP90 Mobile Printer
Paper Feed Error
Your saying the printer grabs the paper on the one side more than the other?
Nov 13, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
242 people viewed this question
old marine
old marine
