Question about Dell Computers & Internet
Hp d530 sff dg782a
I have a simple p4 processor i want to change my processor into dual core or core to duo is it possible?
    Genius:
  • Dell Master
  • 1,056 Answers
You would need a different motherboard, along with the CPU and most likely new RAM so that all components match
Posted on Jun 02, 2016
marked
  • 6487 Answers
SOURCE: uppgrade of a processor
The processor upgrade defends on your motherboard if it supports a processor like Core2Duo, because it all depedns on the motherboard if you can upgrade processor and RAM ,if you buy a new processor and its not supported by your motherboard it will be a wast, but if your computer manufacturer told you that your motherboard can supports a processor like Core2Duo go ahead upgrade to it , that will definitely make teh computer faster and better sicne Core2Duo is a high end processor right now..
Hope that helps...........
Posted on Sep 18, 2008
bunnydawg
  • 5158 Answers
SOURCE: Uppgrade to a faster processor
to decide cpu compatability we would know the model of the motherboard.
Robert
Posted on Sep 22, 2008
Mervinh
  • 13 Answers
SOURCE: Uppgrade to a faster processor?
Hi
Pentuim D is a processor that has 2 x cpu in one and a core 2 duo has 2 cpu's plus 1 smart core bigger cache
you can only upgrade to a E2140 or E2180 processor on that motherboard
OR replace the board with a newer type
If you want to work the actual speed for the processor of a dual core take the speed for example dual core 1.8 x 2.1 =3.78 GHz
Core 2 Duo  1.8 x 2.4 = 4.32 GHz
Posted on Sep 24, 2008
  • 38 Answers
SOURCE: Uppgrade of processor!
looks like that mobo can only suppoport up to 53 mhz front side bus for a celeron d processor
wht tht means is tht u can get any cpu tht has the front side bus up to 533mhz with the 775 socket forur motherboard
and forpentium 4 its 800mhz and agian any cpu with up to 800 mhz front side bus and 775
so ur best cpu for tht mobo would be the SL7RR it supports hyperthreading
here a direct link to intel'ssite
http://processorfinder.intel.com/details.aspx?sSpec=SL7RR
SL7RR
3.40 GHz
800 MHz
109.6 W
66
512 KB
2 MB
775
0.13 µm
yes
pls rate my answer if i helped u
Posted on Sep 26, 2008
XOUSS
  • 48 Answers
SOURCE: difference betweeen intel celeron,core duo, mxx
Hello , Intel processors come in all shapes and sizes so I'll try to be brief by discussing only the ones that are current on the market. The market for intel processors are currently divided into 2 sides. One side if for single core processors while the other is for multi-cores. Single cores: Pentium 4, Pentium M, Celeron, Core Solo (Not very common) These cpus are single cores meaning that they only have one processor. They are relatively cheap compared to multicores. The difference between these are clock values, hyper threading, 64 bit support, and FSB. Pentium 4 and Celerons are cores found in desktops while the M is found in laptops. Single cores generally have low FSB but high clock speeds. Think of it as having a lot of water pressure but only a straw to dispense it. That's how fsb and clock values work. So single cores should provide you with a lot of raq power but they're not good at multi-tasking or jobs that requires it divide it's attention. Games like Crysis will be better with multi-cores because the pc has to generate so many different things at once while focusing on countless calculations and processes. the hyperthreading support does help the single core pentium 4s with multi-tasking but it's not as much as multicores. So if you're just looking for something with a lot of raw power. These are for you. Multi-Core Core Duo, Core 2 Duo, Core 2 Quad These are multi-core processors developed by intel. They are used in both laptops and desktops except for the quad. It's used in desktops only. The first 2 processors are dual cores while the last is quad cored. These processors have a high FSB rating and generally lower clock speed. So you have to be careful when looking at these. The high fsb means that the system does really really well with dividing and transferring it's processing power, but if you get a low clock speed then there's not enough power to begin with for the assignment. Example you may have a large hose but if you have low water pressure.. it's useless. That's why multi-cores are great for the modern pc user who multitasks way too much but if it's under 2.0ghz in clock speed. You should be worried about not having enough raw power to get you through intensive work. Multicores generally cost a lot more than single cores since they're relatively new technology. Btw the Core 2 Duo is faster than the Core Duo by about 7%. Meanwhile the quadcore is the ultimate in processor goodness but costs $400+. I hope these facts helped.
Posted on Jun 12, 2009
What is the main difference between dual core and core 2 duo? processor
1. Dual core is the generic name given to processors that have 2 cores on the same chip 2. Core 2 Duo is the second line of dual core processors from Intel 3. Other dual core processors aside from Core 2 Duo are the Core Duo from Intel and the X2 series from AMD 4. All Core 2 Duo processors are dual core but not all dual core processors are Core 2 Duo
For more info visit the link below
http://www.differencebetween.net/object/difference-between-dual-core-and-core-2-duo/
Nov 22, 2010 | Computers & Internet
I am havimg a p4 processor.iwaan replace it by core 2 duo.will it be possible with D101GGC
This motherboard only supports the folloing processors.
  • Intel® Pentium® D processor 820, Intel® Pentium® 4 and Celeron® D processors in the LGA775 package
  • Supports Intel® EM64Tφ
  • Jul 07, 2010 | Intel D101GGC Motherboard
    CPU FAN SPEED IN HP Compaq d530 Small Form Factor Desktop PC
    The fan/heat sink on these models get plugged with dust very easily, use an air compressor or can of air to blow the dust out of the heat sink and fan. In extreme cases the thermal paste gets dried out and needs to be re-applied to properly cool the processor.
    Dec 01, 2008 | HP Compaq d530 SFF PC Desktop
    Hi
    Sep 23, 2008 | Computers & Internet
    Upgrade
    In order to upgrade processors you will need a new mortherboard (if you want to use a core2duo). If your running a computer like that you will probably need a new case, memory, and an adequate power supply to run it and maybe another fan if your running a lot of stuff in there. You may need a new video card as well.
    You could check at some used computer stores and see if you can upgrade your celeron processor to something faster. Compaqs are know to be trouble when you try to upgrade them.
    Jun 22, 2008 | HP Compaq d530 SFF PC Desktop
    Upgrade
    Hi, my pc is hp compaq d530 sff, the processor is celeron, is it possible to upgrade it to a higher processor like core2due, if not what are the other possibilities
    thanx.
    Jun 20, 2008 | HP Compaq d530 SFF PC Desktop
    Cpu enquiry
    There really is no difference, there are differences in the E numbers though. Those are specificallt about it's GHz's, it L1 and L2 cache.
    Though Intel Core 2 Duo is the same as Intel Dual Core. It's just a different name. This confusion is caused because of Intel changing the names of it's processors series. The Pentium brandname for example is gone. Intel Pentium Dual Core is now called Intel Core 2 Duo.
    I hope this answered your question.
    Greetings,
    DarkNeogen.
    Jan 25, 2008 | Intel Core 2 Duo E6600, 2.4 GHz E6600...
    Computers & Internet Logo
    216 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
