Question about Olympia Startype 3 Typewriter
Code I must have hit a combination of keys to mess myself up. Every time I try to type now I get symbols and wrong letters and numbers. How do I fix this?
    Problem Solver:
  • 19 Answers
Re: Code
Look for a key with a coloured symbol,ie,indicating "keyboard 1",or something similar. Hold the code key down and at the same time press your selected key. Order should be restored. If not,look up an Olympia dealer and they will help you over the phone. One thing for sure ,you have inadvertely selected a 2nd or 3rd keyboard setting to accommodate an other daisy-wheel/language. Good luck!
Posted on Nov 03, 2007
0 characters
3 Points
What do I do when my typewriter types different letters and symbols than the keys being hit
Turn the machine off then on or hold down the "code" key and hit Q "reset" key to get the machine to type the correct keys. This usually happens because something interferes with the free rotation of the printwheel. Check to be sure the ribbon and corredtion tape are installed correctly and check to be sure none of the "fingers" on the printwheel are bent outward. If a finger is bent, bend it back. If everything looks okay, the board or power supply is going bad.
Feb 23, 2015 | Brother GX-6750 Typewriter
When typing numbers a strange symbol appears in it's place, not a code symbol or a cap symbol.
Hmm, I have a sd 670, and I have a button called KD II, and it makes symbols appear. If you have that key, hit code then hit it. That should bring you back you back to normal.
Jan 29, 2014 | Smith Corona SL 580 Electric Typewriter
Letters on the keybords are all wrong
i thing you software is not working you have to chack your manual
May 28, 2010 | Nakajima AE-830 Typewriter
IBM personal wheel writer 2, wrong letter is typed
Try code "L" it will get you out or the language mode
May 11, 2009 | IBM Typewriters
Wheelwriter 3500 KYBD 099
Check the ywo keyboard connectors to be sure they are plugged in fully, if they are then press & hold the code key, press & rel the "L" key type 001 then release the code key.
This will put you into the english keyboard mode. To cure the problem you need a keyboard.
Oct 06, 2008 | Lexmark Wheelwriter 3500 Typewriter
Keyboard 99 is Laten supplemental. Try holding down the code key and pressing the x key it should reset the keyboard.
Jan 25, 2008 | IBM Wheelwriter 30 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Cannot type letters.
Your T/W neads a new keyboard membrane, you cannot clean this type membrane so you will have to replace it.
May 26, 2007 | Brother GX-6750 Typewriter
Olympia Startype 3 Typewriter Logo
231 people viewed this question
Top Olympia Typewriters Experts
James Cagle
James Cagle
Jim Keysor
john archer
Are you an Olympia Typewriter Expert? Answer questions, earn points and help others
