Question about Watches
Suunto Yachtsman watch - I have noted that the Barometer function seems stuck at around 900mBar...this cannot be correct! Is there a way to reset this device...is the reading mechanism for pressure blocked in some way?
  • iainmack Jun 18, 2009
    hmmm thats a good question!
    i had a battery replacement a while ago and wonder if this could 'LOCK' the readings?
    so there is a way to unlock this and the watch may perform again?
    Iain
    that could be the case.....howvever im in yemen at the moment!
    the barometric pressure is related to altitude and sea level but at a temperature outside around 45 degrees i would have thought 1000mbar +
    now it says 899mbar and i have reset to '0' from '-3' the 'trend' arrows seem to be working but im not so sure about the barometer still. is there a way to test it, like leave it in shade for 15mins and see what the barometer reads? the temperature should increase with ambient where i am
    thanks
  • 334 Answers
Have you made sure you did not lock it?
Posted on Jun 18, 2009
  • 2 more comments
  • seth veloso Jun 18, 2009
    guess my post didn't go through sorry. try this sequence mode=> mode=> select=> mode. see if that works
    man i'm out of it today, after you hit select set the diff to zero
    hey, I should have asked first, how long has it been at 900, have you been in different locations and still reading 900? 900mBar would be the normal reading of an elevation of 1000 meters or 3300feet above sea level. So in other words, if you are not moving elevations much and it is only moving up and down a little bit and your elevation is around 100 meters, you should be good to go
  • seth veloso Jun 19, 2009
    hey man not sure if you were able to correct your problem or not, I've been busy. Below is a link for the service manual for the watch good luck
    seth
    http://www.suunto.com/media/suunto/manua...
Suunto Core watch - my watch is locked in the compass mode. How to I get it unlocked
RTFM
Suunto Core User Guide
ns.suunto.com/Manuals/Core/Userguides/Suunto_Core_Userguide_EN.pdf
This User Guide explains the Suunto Core features, how they work, and how ... nearest watch store to get the needed adjustments correctly done for you.
How to Set Up a New Suunto Core - YouTube
? 6:49
https://www.youtube.com/watch?v=_zywJcNNowU Jun 13, 2015 - Uploaded by Wearable4U
Great tutorial, clear and precise (beats reading the manual) many thanks ;-) ... Hi there. Just bought a suunto core ...
SUUNTO CORE USER MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core user manual online. Suunto Core: User Guide. Core Watch pdf manual download.
SUUNTO CORE QUICK MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core quick manual online. Suunto Core: Quick Start. Core Watch pdf manual download.
[PDF]Quick Guide - Trekkinn
www.trekkinn.com/images/pdf/especificaciones/eng_suunto_spec_10086.pdf Suunto Core brings together an altimeter, barometer and an electronic compass ... Please refer to the User Guide for detailed information on setting these. Suunto Core watch Google Search
Jun 17, 2017 | Suunto Watches
Suunto t3-changed battery and Suunto t3 is displayed at the bottom of the dial but no functions work.
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.
Aug 07, 2013 | Watches
I have a Suunto X-Lander and i dont get along with the barometer/altimeter. The barometer always shows about 2 mbar below the nearby airport homepage. Can i by myself calibrate the sensor? This even...
Erik, the altimeter uses barometric pressure to determine changes in elevation. Rule one is whenever you know the elevation for a fact, adjust it as the barometer is changing often and therefore affecting the altimeter reading. The only sure way to avoid this is use GPS. Altitude is derived from locating 3 or 4 satellites in a geo syncrohnus(SP?) orbit. Pilots always reset the altimeter before take off and you should too. Find elevations on road signs, maps, etc.
May 24, 2011 | Watches
The ascent reading seems to be very inaccurate and the battery shows low after only a couple rides after installing a new battery. Anyone have a solution for the acent issue?
You need to send the watch into Suunto for service. The watch is obviously having an issue if it will not hold charge with a new battery and the Altimeter is not working correctly.
The Altimeters are Barometric pressure related and occasionally something goes wrong.
My experience is that Suunto is very good about fixing and/ or replacing when this issue arises.
Jan 24, 2011 | Suunto T6c Heart Rate Monitor and Fitness...
Locked screen , need button combo for suunto core
If you enter the following into your search engine, you will see a list of instruction manuals.
www.suunto.com/en/Support/Download-Center--User-Guides/
Download the one for your watch.
Feb 18, 2010 | Suunto Core Wrist Top Computer with...
I'm trying to reset the altimeter and sea pressure but the watch. I've followed the instructions but the watch more often that not reverts back to default settings or does not respond to the calibrations...
http://www.suunto.com/en/Products/Outdoor_Sports_Instruments/Suunto-Vector/Suunto-Vector-black/#Manuals
If you continue to have problems with your watch, and the instructions in the user manual don't resolve your problem, you may have to return the watch to Suunto.
Your watch must be registered with them, you'll need the serial number of the watch, which is located on the back case. You'll have to get an RMA from Suunto in order to send it back to them.
Here's their warranty info: http://www.suunto.com/en-us/Support/Warranty-information/
Oct 11, 2009 | Suunto Vector Wristwatch
Changing metric to Imperial on Suunto Vector
It's in the manual. I did it on mine.
Dec 25, 2008 | Suunto Vector Wristwatch
Adjusting meteo function
Yes, Sir. But remember when pilots reset their altimeter with the local altitude, the pressure value matches the moment wheather pressure. It will be wrong anyway, if you reset you altitude, but the pressure readings are still wrong. Im my case it is happening. The altutide is correct but the pressure of the watch does not match the local pressure. It is 20 hpa over it. By the way, I am an airline pilot.
Mar 05, 2008 | Tissot T-Touch T33759851
Watches Logo
82 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
