Question about Hitachi Le39h316
Backlight board for hitachi tv le39h316 - Hitachi Le39h316
Hitachi LE55A6R9A has sound but no picture. Passes flashlight test. No LED backlights appear visible at all. Trying to determine whether to start replacing boards or LED strips first.
The led driver may be on the main board or on it's own board. Led strips don't fail all at once so if you had a dark area of the picture then I'd suspect a led strip. TV Parts Universal TV Stands DLP Chips ShopJimmy This is the place to get parts.
Feb 13, 2018 | Hitachi Televison & Video
How do I repair the backlighting on a Hitachi LE49A509 TV?
A LED is a diode if one shorts the entire set goes out or on some sets there are 2 supply lines and one the top half may light and the bottom be dark or other way around
Oct 27, 2017 | Hitachi Televison & Video
Sound but no image on Hitachi 42pd5000
Two things need to be checked. The ballast board and the T-con board. Shine a flashlight on the screen with the TV on...If you see a faint picture moving, then the T-Con board is OK. The ballast board for the white backlight is bad. If you don't see a faint picture, then the T-con board is bad. You can get parts here: www.shopjimmy.com TV Parts Universal TV Stands DLP Chips ShopJimmy
May 23, 2017 | Hitachi Televison & Video
What cause hitachi flaatscreen tv to black
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
May 12, 2015 | Hitachi Televison & Video
Hitachi 42pd6800 black screen when turned on, got sound no picture
Is this a plasma or an LCD TV? If it's an LCD TV then I would check the backlight inverters. If it's a Plasma TV then The Sustain boards there are two sustain board.
You can get parts for this TV at www.interliquidparts.com
Feb 29, 2012 | Hitachi Televison & Video
I have a Hitachi P50T501 plasma tv. The screen went blank while watching it. We have been unable to watch tv or dvds. The power light is blue.
Tries unplug,replug about 1 hour later,if doesn't work,than Ur main video backlight board it dead,must replaced.
Nov 20, 2009 | Hitachi P50T501 50 in. Plasma HDTV
48 inch Hitachi rear projection tv picture goes out.
Backlight main video board is going,video board must change,about $500 with labors.
Oct 10, 2009 | Hitachi 50UX57B 50" Rear Projection...
My tv shows a picture for about 10 minutes then no more picture but sound remains. what could the problem be? thanks
One of two problems:
1) You have a problem with your power board/inverter. This is most likely the result of busted or bad capacitors on the power board. If you know what you are doing, you can try opening up the TV and taking out the power board and replacing any bad capacitors using a soldering iron. If not, take it to someone you trust.
OR
2) Your LCD backlight panel is going bad. The backlight is the light that shines through the LCD to show your picture. This can be fixed by 1 of 3 ways, you replace the whole LCD panel and backlight (expensive), you can get your hands on a broken LCD of the same size with a working backlight and swap out the backlights (takes time and knowhow), or you can actually repair the backlights themselves (much harder and somewhat dangerous).
The fact that it happens consistently or after 10min implies that it might be an issue of the backlights overheating until they shut off or power board overheating to the point where it can no longer provide enough power for the backlight. Try keeping a fan on at the side or back of your TV and see if it makes a difference. It may or may not make a difference, regardless of the issue.
Aug 15, 2009 | Hitachi Televison & Video
Hitachi Le39h316 Logo
101 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
