Question about Nordic Track NordicTrack A2350 Pro Treadmill
Enclined to 10 will not come down - Nordic Track NordicTrack A2350 Pro Treadmill
HELLO, THERE'S AN OPEN HUM NO MATTER WHAT THE VOLUME IS SET AT. INTERCONNECTS AND PREAMP ARE NOT THE CAUSE. THERE IS NO REMOTE , I JUST WANT TO USE THE UNIT TO PLAY CD'S. THANKS.
Without knowing more details, I would be enclined to suspect the power supply has a bad capacitor, which is a sign of bad filtering. Bad ground or bad capacitor!!! My guess. Hope it helps.
Sep 21, 2013 | Adcom GDV-850 DVD Player
Tip
You are awesome, thank you so much. I knew it had to do with a sensor but i am...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Aug 02, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
1995 mercury cougar cranks but not start
There are a lots of things that could cause that. specially if your car has a ECU (Electronic Control Unit). A 1995 should have it. There are many sensors that can stop the fuel or spark to the engine.
If you are enclined to test it you can check if you have spark to the plugs. Or fuel to the injectors.
good Luck
Jun 30, 2011 | 1995 Mercury Cougar
My 2005 Nissan pathfinder warning lights come on and my speedometer dosent track my speed.
You need to replace the speed sensor. It is on the transmission, and you can get the part from Nissan. If you are not mechanically enclined, then you may want to have them do it for you.
Mar 18, 2011 | 2005 Nissan Pathfinder
Top end on 2005 crf80f
Unless your technically enclined. Sell it. Otherwise buy a manual or find a good pit bike mechanic.
Jul 29, 2010 | 2005 Honda CRF 100 F
2004 SANTA FE, NEED R&R INSTRUCTIONS FOR HEATER CORE
Heater cores are a big job. You will almost always have to remove most
of or the whole dashboard. I wouldn't recommend this, if your not a
mechanic, or very mechanically enclined individual. Good luck.
Mar 29, 2010 | 2004 Hyundai Santa Fe
2002 Jeep Liberty left rear taillight bulb blown. Do I have to take interior panel off to get to the replacement of the bulb?
Yes,It's actually pretty simple, if your somewhat mechanically enclined.
I've only had to replace one or 2 bulbs in my 02' liberty within 95K miles.
The interior trim will either pop out or you have to twist these big plastic
hold downs to get access to the bulb holders. Pretty easy stuff. just
make sure you replace the two filiment bulbs with the correct ones and
vice versa with the single filament bulbs. Good luck.
Mar 22, 2010 | 2002 Jeep Liberty
Turns off about 2 seconds after turning on
If you are enclined,check for cold solder joint on heat sinks
Aug 07, 2009 | Sony KV-40XBR700 40" TV
Window won't go up
yes, ur cable on the drivers window regulator is binding , stretched , and or broken(krinkle noise)..i use to own a c.l 3.0 v6 with the same problem...replaceing the regulator and motor assembly fixed the window...
Apr 20, 2009 | 1997 Acura CL
2003 mazda heater core removal help
if you are mechanically enclined to due to budget going to do this yourself, the best advice anyone will ever give you is to pick up and hayes or chilton manual from your local autoparts store. they are less than 20 dollars and a mechanic will refer to these as the bible for your vehicle. they basically break down each car and make an easy to follow repair manual for the everyday person to go by.
Jan 27, 2009 | Mazda Protege Cars & Trucks
Nordic Track NordicTrack A2350 Pro Treadmill Logo
18 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
