Question about Toshiba MK5076GSXN - Hard Drive 500GB 2.5" SATA 5.4K
Root cause found system volume on disk is corrupt
Laptop will not start up and when running auto system repair it never completes
3 Suggested Answers
  • 479 Answers
SOURCE: im having trouble with my lap top. it just that
This might be an issue with the HDD.Please try in safe mode otherwise you will have to format the machine.
Posted on Aug 13, 2009
  • 1481 Answers
SOURCE: Windows fails to start. Startup repair is unable to repair.
insert a WinXP Cd in the CD rom drive and restart and let it boot from the disk, let it install the OS again...format the HD (u will lose all data there but ur machine will come back)
Posted on Feb 19, 2010
Can Drivers-Utilities reinstall disc be used to stop Endless Loop Start and Repair found root error Registry is Corrupted. Repair Action Registry Roll Back successful.
Doubtful... You'll need to use a OS Install disc to repair System/Registry files. If you have the System Install Disc, put it in your optical drive while your PC is already up and running. When the Auto-Run prompts, allow it to run, but rather than starting a fresh install, select the "Repair" option... It should then scan your system & settings and replace any missing or broken files. However, if your system can't start at all, place the OS Install disc into your optical drive while it has power then shut down your system. Wait 10 seconds and restart. Boot from the CD and then select the "Repair" option as mentioned.
Good Luck on fixing your system :-D
Apr 05, 2015 | Dell Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Laptop loops Start Up Repair
your HDD is corrupted ... take out your HDD and check another HDD .... if the new HDD is working then your HDD is corrupted.
Aug 15, 2013 | Sony VAIO Computers & Internet
There is a popup message frequently stating taht "Windows detected a hard disk problem. backup your files immediately to prevent information loss, and then contact the computer manufacturer to determine if...
Click on "Start". Click on "Computer" Right click on "C" drive. Click on "Properties at bottom of menu. Click on "Tools" Click on 1st of 3 options available, check both boxes to scan complete hard disc, this will run a 5 stage correction program upon reboot.
Dec 18, 2012 | Toshiba Satellite L505D-S5983,...
Root cause found, System volume on disk is corrupt
You can try formatting with a Microsoft CD if its still corrupt replace the hard drive
Aug 23, 2011 | Sony Computers & Internet
My laptop will just randomly turn off...it will run well for a few minutes and then just turn off and everytime i try to start it over it turns off even quicker...within a minute or two...i realy need help...
Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Nov 02, 2010 | Acer Aspire 5315 Notebook
Laptop wont boot up
Chek whether your system volume is infected. viruses or trojans may be the root cause. I also think that your system software is corrupt.
Aug 09, 2009 | Computers & Internet
I have a acer aspire 7730 and when it boots up it is going to start up repair it then scans to repair then says the root cause is system volume on disk is corrupt.please help someone. thanks Rob.
That's a hardware problem, the file system is munged and the hard drive cannot be loaded. Often times, this is only resolved by recreating the system volume and starting from scratch. Boot from the DVD and try running a chkdsk /r from the recovery environment (choose the
command prompt option), see if it can fix the drive. Otherwise, you may have to go the long way 'round. Hopefully you backed up your data on a regular basis.
Yellow Machine volume disappeared.
The reason the drive won't mount is because the RAID is corrupted. It may require manual intervention. You would have to log in through root on the box. How long did you wait before trying to mount a partition. Trying waiting 2-3 hours (if you see lots of disk activity they are going through a repair). If you see none then you have to go the manual intervention route as root and run the "md" commands to identify the root cause and repair the volume.
The unofficial support website is: http://www.yellowmachinesupport.com/
You would need to use the RAID tools on the linux os loaded on the unit in order to repair.
Good luck,
David
Feb 17, 2009 | Anthology Solutions Yellow Machine P400...
Did you ever get this fixed?
Good luck,
David
Apr 01, 2008 | Anthology Solutions Yellow Machine P400...
Toshiba MK5076GSXN - Hard Drive 500GB 2.5" SATA 5.4K Logo
18 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
