Question about Hyundai Vehicle Parts & Accessories
Replacing oil pan gasket - Hyundai Vehicle Parts & Accessories
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
You gotta drain the oil then drop the oil pan clean old gasket off and oil replace the gasket and reinstall oil pan put oil back in and after checking the oil level or changing oil you are ready to go
Posted on Sep 09, 2014
How do I remove oil pan on a 2001 gmc Sonoma pick up truck to replace gasket
1993 GMC SONOMA 2.6 CYL V6 NOT 4x4 OIL PAN ...
? 2:31
https://www.youtube.com/watch?v=1KsRTlnW7Cg
Sep 27, 2011 - Uploaded by JohnSmiths8379858
trying to reomove the oil pan to this truck has been sitting for about 6 ... 1993 GMC SONOMA 2.6 CYL V6 NOT 4x4 OIL PAN REMOVAL "HELP!
Oil Pan Gasket: How to Change Oil Pan Gasket for 2001 ...
www.2carpros.com/questions/2001-gmc-sonoma-oil-pan-gasket
Mar 18, 2011 - How to change oil pan gasket for 2001 sonoma, can i get away with just raising the engine two inches to ... 2001 GMC Sonoma • 4 cylinder 2WD Automatic • 150,000 miles ... You need to remove the engine to get the sump off.
Nov 28, 2015 | GMC Cars & Trucks
How to replace oil pan gasket dodge caravan 2005 3.3l
jack up on jack stands, drain oil, remove all pan bolts, clean pan, use new gasket, replace bolts to torque specs do not over tighten it will tear the gasket. DO NOT USE GASKET SEALER OR PERMATEX IT MAKES GASKET SLIP
Mar 09, 2015 | 2005 Dodge Caravan
How do you replace an oil pan gasket on a 1991 buick skylark custom
remove the oil pan,clean off the old gasket with a scraper,clean off all of the old gasket from the oil pan and the engine,mild solvent works pretty good.using gasket adhesive put nice even beed all around the edge of the oil pan,place the new gasket on top of the beed of adhesive,place the oil pan back against the engine replacing the bolts from the oil pan,tighten the oil pan bolts back to torque specs. of the manufacture.
Dec 24, 2012 | Buick Vehicle Parts & Accessories
Need to replace oil pan gasket for 1996 Ford F-150 2wd, I-6
Yes you can do it yourself.
Its not very easy,but with basic Auto repair tools the task can be easily completed.
There are few help links with solutions to complete these task.
I suggest you to refer these links and view its procedure.
Click the link below:----
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
KIA Sportage leaking oil from oil pan?
Go to Newly Launched
FREE Car repair gu
obyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html" http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html
Oil pan Gasket on 1998
Toyota Tercel?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
VALVE COVER GASKET REMOVAL GUIDE http://technoanswers.blogspot.in/2012/06/valve-cover-gasket-removal-guide.html
--------- Car oil leaks from valve cover gasket? http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
How to replace Oil Pan on 2008 Honda Odyssey?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on 2008 Honda Odyssey?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
2004 Chevrolet Express Van: Oil pressure sending unit replacing? http://whoisbyme.blogspot.in/2012/06/2004-chevrolet-express-van-oil-pressure.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
HOW TO RESET OIL CHANGE INDICATOR? http://whoisbyme.blogspot.in/2012/07/how-to-reset-oil-change-indicator.html
These details will help.
Thanks.
Nov 25, 2012 | Cars & Trucks
What all has to be taken off to get to to the oil pan gasket
Oil Pan REMOVAL & INSTALLATION
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain the crankcase.
  3. Remove or disconnect the following:
    • Negative battery cable
    • Oil level indicator harness connector, if equipped
    • Exhaust Y-pipe, if needed
    • Transaxle assembly from the vehicle.
    • Oil pan bolts and the oil pan
    To install: NOTE: The oil pan gasket is reusable unless it is damaged. Do not remove the gasket from the oil pan groove unless gasket replacement is required.
  4. Thoroughly clean the inside of the oil pan and the cylinder block contact surface. If the oil pan gasket is being reused, be careful not to damage it. Do not expose the gasket to cleaning solvents.
  5. If a new gasket is being installed, start the gasket into the oil pan groove and work the gasket into the groove in both directions. Once the gasket is exposed to oil, it will expand and no longer stay in the groove without wrinkles. If this condition exists, replace the gasket.
  6. Install or connect the following:
    • Oil pan. Torque the bolts, in sequence, to 89 inch lbs. (10 Nm).
    • Oil level indicator connector, if removed
    • Transaxle assembly, if removed
    • Y-pipe, if removed
    • Flywheel cover, if removed
    • Oil pan drain plug. Torque it to 15 ft. lbs. (20 Nm).
  7. Refill the crankcase.
  8. Run the engine and check for leaks. Fig. 1: Oil pan bolt torque sequence 7922vg08.gif
Jan 01, 2011 | 2002 Cadillac Deville
How do I remove the oil pan gasket from my 1999 Cadillac Deville Concours
Nov 05, 2010 | Cadillac DeVille Cars & Trucks
How to replace oil pan gasket on 2002 deville
Oct 29, 2010 | 2002 Cadillac Deville
Replace oil pan gasket 2002 chrysler 300m
The owner of the car should be able to locate and replace oil pan gasket .prepare the equipment to be used .Drain the oil from the oil pan ,spill it to an empty big can that can carry the oil from the oil pan.Then twist the bolts that connect the oil pan to the engine.After removing the bolts then you have take the old gasket off to the oil pan.After taking off the old gasket then you have to replace it with the new oil pan gasket.then return the oil pan with the new gasket. twist the bolt back until the oil pan that connect the oil pan with the engine.And return the drain plug twist until it will not spill.
Sep 30, 2009 | 2001 Chrysler 300M
Help
not oil pan but gasket remove oil pan scrape off all old gasket and put on new one the best thin to do is glue it on the oil pan first and let dry with bolt holes in line the glue it to block but this might no be the problem headgasket could leak oil pump gasket valve cover gasket
May 31, 2009 | 1994 Mercury Tracer
Gasket needs replacing
then you need to replace the gaskets drain oil from oil pan take all bolts out and drop the pan as far as valve pan covers buy rubber gaskets not cork they are a lot more pliable and less prone to leak
May 22, 2009 | 1994 Ford Aspire
Vehicle Parts & Accessories Logo
76 people viewed this question
Top Hyundai Vehicle Parts & Accessories Experts
Lawrence Oravetz
Colin Stickland
Colin Stickland
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
