Question about GE Profile PFCS1NJWSS Stainless Steel French Door Refrigerator
Pfcs1njwa ss How do you remove the water dispenser
2 Suggested Answers
SOURCE: Dss25kser Ss water is slow coming out of dispenser
replace water filter
Posted on Jul 18, 2012
Model GSS25TSRE SS Water dispenser does NOT work, but the ice dispenser does dispense ice. Looks like the freezer compressor is NOT working. Help!
Most likely you main control board is bad.... Replace it and your troubles will go away... It is located inside back panel of fridge on the right hand side if you are looking at the back. Sometimes if you unplug power and remove board you can see burnt spots on the back of it but not always.
Nov 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Profile refrigerator model PFSS5PJXA SS, French doors with bottom freezer and water dispenser, no ice, on right door. A small rubber disk fell of from behind the paddle that the glass is...
I removed the control panel (2 tabs under the front edge) removed the 4 screws holding on the paddle assembly and removed the assembly. The disk is glued on the back( I used super glue). If it happens in the future I would try to glue it on without removing everything. If you use a mirror you can see the detent where the disk mounts to the paddle and glue it back on. The disks function is to push on the switch that is located behind a gray rubber panel behind the paddle.
Aug 06, 2010 | GE Refrigerators
GE PSS26GRE SS not dispensing ice
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Terrible Plastic After-Tast in Dispensed Water (Refrig)
If indeed it is stagnant water you have to find the water source tap off of your water supply. Then trace out the routing of the feed water line to your refrigerator. Turn off the tap, remove the line at both ends. You can abandon the existing line. Reroute the new line. or you can remove the old line and follow the same route. Reconnect the tap and refrigerator ends.
Jul 14, 2009 | Refrigerators
Makes ice fine but doesnt dispense
Sounds like the dispenser auger is frozen up or stuck. The lights dimming happens because the voltage drop from the stuck auger's motor when you try to use it. Remove the ice machine and clean it. Do not try to take it apart!
Sometimes, the ice machine will fill too much with water and get stuck. Often, it's because the cabinet isn't level.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
PSS26PSTA SS - Only dispenses crushed ice.
Remove the ice dispenser bucket. You will see a square hole at the back wall with a horizontal rod in it. You should be able to move it up and down with you fingers. If not, it may just be frozen. Warm it with a hair blower and try again. If still no luck, the WR62X58 dispenser solenoid may be burnt out / melted and need to be replaced. It is attached to the metal just above and behind that square hole. The removable tray at the bottom of the dispenser recess is a part number WR17X12133 for a PSS26PSTA SS. Contact any GE servicing dealer or general appliance servicer near you to get one. You can get parts direct from GE also, but the won't be any cheaper, and you may pay more shipping and handling.
Nov 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PFCS1NJWSS Stainless Steel French Door Refrigerator Logo
22 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
