Question about Dryers
Kelvinator ED 56 Dryer
The dryer was working fine last time I used it in the week. I think the settings might be muddled up because one of my children tried to dry her school shirt this morning and the dryer just would not go. I don't know what I have done with my manual as I have not had to use it since buying the dryer about 5 years ago.
The orange light near the power switch and the timer button flickers and the dryer just would not start. Please advise.
  • Dryers Master
  • 8,220 Answers
Reach inside and see if the drum turns real easy. It should turn real easy even wth wet clothes in it. if it hard to turn then the motor aint gonna get going gonna run hot and quit.
Posted on Jun 28, 2017
SOURCE: Maytag neptune dryer won't start
This also happened to our dryer recently(our dryer is 6 yrs old). My husband replaced one of the capacitors along with a resistor(I think that's what it's called). If you don't know what you are doing then you can purchase on new board on ebay. My husband checked on there and they run about $90.
Posted on Sep 15, 2007
  • 164 Answers
SOURCE: Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Posted on Nov 01, 2007
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Posted on Nov 25, 2007
SOURCE: Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Posted on Jul 12, 2008
  • 410 Answers
SOURCE: Dryer runs but no heat
.I am not a repair professional. I am a 78 year old man
who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you go to where they have very good step by step trouble shooting and repair information on washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Dec 01, 2009
Electric dryer repair no heat
Does it spin, does it heat on any of the time settings? If not may need to be replaced. May want to have someone come back out to see if it can be fixed. Sorry if this doesn't help. Went through two dryers due to children and CRAYONS!!!
Mar 14, 2014 | Kenmore Dryers
Kelvinator dryer
Sounds like motor, capacitor, or inverter is going out.
May 06, 2013 | Fisher and Paykel Dryers
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
Gas line had to be disconnected to house last week for a gas leak repair. Everything is fixed and gas is back. Now gas dryer will not heat up. It runs fine, just no heat. Is there something I have to...
most gas dryers have what is called a ignitor on them that will glow when the unit is turned on and after they get red hot then a milivolt signal is sent back to the gas valve to open and fire up... i would check to see if the ignitor is glowing first... you will have to gain access to the bottom of unit in order to see this. you will have to remove front of dryer and most likely the tub,some of the newer maytags have a bracket that will hold the tub in place while working on it... before i did al this though it is possible there is still air in the line and will require bleeding the line at dryer... alot of people are afraid of gas but if common sense used you will be fine... you should have a gas stop at dryer gas supply line if not you need to install one. either way take a wrench and remove gas line at one of the closest connections to dryer and on purpose bleed a small amount of gas out.this will do 2 things (1) it will bleed any air in line going toward dryer and (2) confirm you still have gas pressure and gas going to dryer after your disconnection last week nothing happened to line.then reconnect and try again. if you ran dryer for an extended time it would eventually bleed the line also. not sure how long you ran it,but this will prove you still have gas at dryer . if after that no cure check the ignitor on unit to see if it is working if it is and no flame the gas regulator may be faulty after the disconnection last week/.... good luck to you
Feb 10, 2011 | Kenmore Dryers
Went to try on the dryer and nothing! worked fine the last time I used it last week. what could be wrong?
main thermal fuse in the rear of the machine, if this tests good,, check the safety switch on the door itself you can hold it in and turn the machine on,, if it works,, replace the plunger shaft that turns it on
Aug 02, 2010 | Hotpoint NBXR463EBWW Electric Dryer
Buzzing every 30 seconds
you can remove the buzzer its a small black round peice with a small hole in the middle on the main ic .p.c.b bord but if its buzzing there might be a problem if the unit is working fine then just snap the buzzer off the curcuit bord
Jul 07, 2010 | GE DBXR463GD Gas Dryer
Thermal limiter stops dryer; replaced multiple times. Dryer dead.
I think you are working on the wrong end. Check the fan and inlet ductwork of the dryer, if the air isn't moving properly, it will not move enough to keep the coils and limiters cool and they will fail after working properly a few times.
Sep 03, 2009 | Frigidaire Dryers
Another Whirlpool Cabrio Sensing issue
Hi-- none of the solutions I've read here are working. Same problem, dryer not starting, it says "Sensing..." and then "Wet" and does nothing. It worked fine on the last load, except I noticed it read 11 minutes for a very, very long time (I think it got stuck). New load? "Sensing..." etc.
Mar 29, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
could be the door interlock is not functioning therefore prventing the start
Mar 11, 2009 | Roper REX3614KW Electric Dryer
Dryers Logo
465 people viewed this question
Top Dryers Experts
