Question about Garden
How to light the pilot light on the gas fireplace
  • 6 Answers
SOURCE: Propane fireplace insert won't light
Gas apliances have safety features built into them so you don't blow yourself up. The pilot heats a thermocoupler which tells the gas valve there is a flame, open the main gas to the burner. If you can see the flame area of the pilot look for a round post about 3/16 inch in diamiter. This should be directly in the flame, if not bend the bracket so it is in one side of the pilot flame. The thermocouple is attached to a mounting bracket. This will be held in place by a 1/4 inch hex screw. remove the screw and the capilary tube leading to the gas control valve. Before you do anything, close the main gas supply to the fireplace and disconnect the power to the fan. You may need to semi dismantle the fireplace to get the thermocouple. The gas valve end is a brass 1/4 pipe thread plug. Turn the outer nut and remove without twisting the tube. Reverse this order to install a new one. Besure not to twist the capilary tube, tighten brass nut 1/4 turn past hand tight. Your better heating supply house will have these in stock. Restarting the pilot will take a few tries because the gas was off. Your gas suplier would charge about $75 to fix this. if you don't have the proper tools and it dosen't look pretty stright forward don't do it. You could get dead.
Posted on Dec 02, 2008
SOURCE: I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Posted on Jan 03, 2010
SOURCE: gas fireplace won't light up even when pilot light is on
Check for how clean the bottom of the unit is. I know it seems small but when dealing with these amounts of electric current they are just that "small" and the dust can be shorting out the unit and not allowing the gas valve to release the gas. Its a safety thing, they dont want gas around an electrical short "go figure" lol
Posted on Jan 05, 2010
SOURCE: Need timer switch for millivolt gas fireplace
These guys are a division of Monessen, a gas fireplace manufacturer, and have a variety of millivolt switches, remotes and thermostats.
http://www.ambienttechnologies.com/
Posted on Jan 17, 2010
  • 2602 Answers
SOURCE: On my gas fireplace, the pilot light used to burn
needs blowing out remove pilot tube from pilot remove injector and clean it out then replace it all test joint with soapy water to check for leaks
Posted on Jan 21, 2010
Testimonial: "Thank you. I'll try that...hopefully the pilot tube and injector are easy to locate so I can remove and clean out."
Lighting the pilot, starting the fireplace
Turn on the gas, hold the pilot flame button down and light the pilot flame, continue to hold the button for at least three min's, release the button pilot should stay lighted.
Jan 06, 2017 | Majestic Heating & Cooling
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
https://www.youtube.com/watch?v=Moa7eGlKCr4
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
https://www.youtube.com/watch?v=dRjX5m0zHUU
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
Download MARCO GAS FIREPLACE MANUAL PDF ...
? 0:16
https://www.youtube.com/watch?v=lJyHdPywr0M
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Dec 07, 2015 | Heating & Cooling
Gas fireplace won't light
Your fireplace does have a pilot. It is either millivolt, where you manually light the pilot and use a remote or wall switch to light the logs
or is IPI where it still has a pilot light but the reote or wall switch lights the pilot first then the logs. The second version has a non-standing pilot. In either case, it sounds like a pilot assembly issue. When you "throw the switch", do you hear clicking inside the fireplace? If so and it does not light, you may have a pilot assembly issue. If there is no sound at all, then you may have a bigger issue with the control module. The only sure way to know which is the culprit is to have a certified technician come oput and examine your fireplace.
Feb 02, 2014 | White Mountain Hearth Empire Tahoe 36...
Pilot light
I have a heatalator gas fireplace and the pilot light goes out after 2 to 3 day
Jan 05, 2014 | Mr. Heater Mr Heater Portable Buddy...
Hearthmaster fireplace shuts itself off
So the main burner does fully ignite, but after a minute everything shuts off including the pilot? May just need the pilot cleaned
Sep 12, 2017 | Heating & Cooling
Procom pilot light wont light
Make sure the gas valve is on. The thermocouple may need to be cleaned in order for the pilot to stay lit.
Nov 26, 2013 | Procom Heating & Cooling
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Problem lighting gas fireplace
my fireplace lights up for a short time and goes out after 5 or 10 minutes, please help with this problem.
Dec 08, 2009 | Heating & Cooling
Help troubleshooting an FMI GL-850E Gas Fireplace
It sounds like the Ignition Control Module went out, as I've heard the vibrating noise you speak of just before the module "dies." You most likely have the gray Robertshaw control module box located under the fireplace connecting the power to the gas valve. You will need to have a Certified Gas Fireplace Specialist look into this issue and replace, if necessary.
Dec 07, 2009 | Heating & Cooling
Dec 01, 2008 | Heating & Cooling
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
