Question about Acer Computers & Internet
Acer aspire one second display monitor blue
Hello hope you can assist,just added a second monitor to my acer but the screen stay blue no text showing,when i boot up i can see the same imformations as the acer but then the second display stay blue,any ideas why?thanks
  • photosin2art Jun 18, 2009
    ho dear second display stop workin completely am better off using vista so much easy,anyway when on the subject anyone know if i could use an acer rescue disc to load this laptop with vista ?am in the uk,thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
Look onto your keyboard. There is a key that looks like 2 oval one shaded the other clear. Press FN and that key with the symbol on it. It will turn off your LCD and put it into the other. Then hit it again, both screens will have power, but slightly dim, press it once more to turn it off.
Good Luck
Posted on Jun 18, 2009
Black screen when power on my acer laptop
hi
try to isolate using external monitor,
check connection of lcd cable
replaced lcd panel
Apr 07, 2014 | Acer Aspire 5241 5251 5332 5334 5338 5516...
I have got acer aspire net book size is 8.9 inch. Ca i connect it to external monitor
Hi.
Sure you can with a standard VGA video cable.
Maybe you will have to change your screen resolution to get the best display layout.
Hope it helps!
Feb 10, 2011 | Acer Aspire One AOA150-1784 Netbook
Hello when booting my ACER Aspire ax3400 it doesnt show any display, just a dead black screen. I have no idea how far into the boot it gets. The blue power light stays constant fro a while and then...
Have you tried to remove and re install the video card also try and move it another bus slot on main board. Do you get anything at all on the screen when it first boots
Dec 30, 2010 | Acer Aspire X3400 PC Desktop
Acer Aspire One notebook model zG5, i hear the hard drive come on, but screen is blank and the keyboard does not respond.
connect the laptop to an external monitor, turn it on see if the monitor will display.
If the monitor displays, then it means your screen inverter or screen bulb is the cause of the laptop screen being blank.
Also if the monitor does not display anything, the maybe the graphic card is the cause of the problem.
This would involve you taking the laptop to a repairer
Take care.
Apr 15, 2010 | Acer Aspire One PC Notebook
How to repair and remove blue screen in Acer Aspire M5641
The resolution depends on *why* you're getting the blue screen. Start by disconnecting all of the drives, USB devices, and other peripherals. Connect just the monitor, power up, and see if it blue screens. If that works, next add just one RAM module and see if it blue screens. Then, add just the main hard drive and see if it blue screens. Keep adding one device at a time until you find the one that's causing the blue screen error. Once you've identified the bad part, get back to us, and we can discuss diagnosing or replacing it.
Oct 31, 2009 | Acer Aspire M5641 PC Desktop
Acer aspire one power button comes on but screen doesn't come on.
1/ Take a close look at the display in bright light; can you see anything there? (If so then the CCFL (or its power supply) needs replacing on the display
2/ hook up an external monitor and see if that works (or at least if the light stays green on the monitor)
3/ Any boot beep? any "Windows sound"?
4/ try removing the battery and (using only external power) see if it starts.
4/ remove the battery AND the external supply, hold the power switch in at least 30 seconds. Hoojk it up again, try it.
JOAT
Oct 16, 2009 | Acer Aspire One PC Notebook
Acer Aspire 6530G black screen
There's no point getting a crisis program if you cannot see the screen in the first place.
The problem could be anything from a faulty graphics, faulty motherboard or loose cable or inverter board.
To test this connect an external monitor to the laptop and use the keyboard toggle to switch screens (hold down Fn and press the F key that has a monitor icon on it)
If the external monitor has a display on it then the problem is the inverter, inverter cable or the screen itself which if faulty.
If there is no display on the external monitor you maybe looking at a new laptop.
If you have no external monitor to test then look very close at the laptop screen, if you can just make out an image then its the inverter.
Post back if you require any more assistance.
Regards.
Sep 02, 2009 | Acer Computers & Internet
Monitor issues Acer 5610-4621
sounds like a bad video card honestly. I doubt the monitor was bad.
May 29, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5050 screen is blank
Hi, if it works with an external monitor it's more likely an LCD problem. When you push the power button, noting comes up on the main LCD screen? not even the Acer logo etc.?
Did you set your video card to use an external monitor and disabled the primary LCD? If so, you need to go to display settings, advanced and go to ATI Display and make sure that the notebook monitor is on.
Apr 02, 2009 | Acer Aspire 5050 5430 Laptop
ACER ASPIRE 3690-2940
check the display on the external monitor by connecting it through the vga port of the laptop, check whether the display is coming or not, if coming then its the problem of your screen
Oct 14, 2008 | Acer Aspire 5100-5022 Notebook
Computers & Internet Logo
285 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
