Question about Cub Cadet Street Sign- tractor lawn riding mower parts
When cutting with pto on and going into reverse and forward again the pto cuts off
  • 376 Answers
That is a safety feature. When the blades are engaged and you go into reverse, they will shut off until you get out of reverse and turn the blades on again.
Posted on Jun 18, 2009
Why does my oto shut off when engaged and motor shuts off but motor will keep running if pto is turned off
You have a bad safety somewhere, heres a few places to check, your seat switch if thats bad it thinks theres no one on the the mower and it wont let you cut grass, reverse switch some mowers wont let you cut in reverse in case kids are around, brake switch which should be working since your able to turn on the mower, check your pto switch as well could be bad but my guess is the seat switch let us what you find
May 17, 2016 | Garden
Why will a cub cadet lawn mower cut grass a few mi. then stop cutting?
Sounds like the electric PTO clutch is bad and needs to be replaced.The straps within the clutch brake causing it to get out of position and the clutch keeps disengaging. You can buy the clutches on line cheaper but they don't last as long.
Apr 22, 2015 | Cub Cadet Garden
Case ih tractor.mx135
your pto pump you have a good mower replace pump about 200.00 but think how old is it whats the possiblty with other stuff breaking down you and exspencive mower hard to make desission me i would have pump put on it also slight very slight be bad check valve but dont bet on it yea hold old how exspenssive is it worth it id replace pump my self it would be worth it
Sep 02, 2014 | Agri-Fab Garden
Poulan 300ex does it cut while in reverse
Most riding mowers do not cut in reverse. If PTO is on and you put in reverses a safety switch will turn PTO off.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 09, 2013 | Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Pto cuts off while mowing
check the safety switches start with the one on the seat then the one on the clutch/brake pedal then the reverse cut out switch bypass them one at a time with a paper clip to test them also look for a loss connection at all the same switches
May 23, 2012 | Garden
MY CRAFTSMAN DYT4000 RUNS GOOD WHEN THE PTO IS INGAGED WHEN GOING FOWARD WORKS LIKE A CHAMP, BUT WHEN PUT IN REVERCE THE ENGINE WILL DIE, UNLESS I DISINGAGE THE PTO PLEASE HELP ,, GOT THE MOWER USED...
It sounds like your mower is equipped with a reverse safety switch. This switch will prevent you from mowing in reverse by killing the engine, like any safety switch. You just need to investigate it and decide if you will disengage the blades to back up or if you will disable the safety switch. You mentioned that there were wires cut. Do you know what they were? How many were cut? I suggest that you trace them out to see what they are, where they go. The previous owner may not have wanted to deal with the safeties for a number of reasons.
In regards to the reverse safety switch, many mowers do not have them. As in they do not come on all mowers, historically. I do not know if they are designed into all the newer ones or not. I work on older mowers and whether or not they are on a mower seams to depend on the manufacturer (on older mowers). My seven or eight year old Craftsman does not have one, while a twelve year old MTD may.
I hope this is helpful for you.
Aug 22, 2011 | Husqvarna Mcculloch Riding Lawn Mower 185...
My Husqvarna YTH21K46 start's up good, But will no go forward or reverse. Iwas cutting grass for about 15 minutes, then the clutch pedal began shaking, but still going forward and reverse. i decided to...
There should be a pulley that the brake/clutch petal pulls against to disengage. You could have a problem with that. You will have to turn it by hand to check and see. Check the main drive belt while you are in the area. It may be helpful to remove the deck so you can slide up under there get a good look.
I hope this gets you going.
Aug 11, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Hi...I have a 2005 Cub Cadet 2042. With the switch in ''normal'' and the PTO engaged, when going forward cutting the grass the PTO will disengage for no apparent reason. You have to push the PTO knob in...
In the cub cadet, the PTO power is maintained via a latching circuit that includes a reverse switch and a reverse relay. Locate the reverse switch that senses whether the tractor is in reverse -- either it's come loose, become misadjusted, or it's failed, or the wiring and connections are loose. You could bypass the switch to confirm this as the problem.
Jul 10, 2010 | Cub Cadet Garden
Cub Cadet LT1018. When I go into reverse the
the safety switch on the pto lever is not activated (lever is not back all the way)
this unit should not cut in reverse
Aug 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
318 people viewed this question
Top Cub Cadet Garden Experts
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
