Code for sony kdl42w805abu led tv - Televison & Video
What are RMT-B118A Insignia codes
Unfortunately, Sony did not elect to include Insignia codes in their remote control, so it is incompatible with Insignia TVs.
Sep 06, 2012 | Sony RMTD187A Remote Control
My universal vizio remote needs to be reset to my sony t.v. i have no clue on how to reset it and i dont have the code any more can you help me please?
Hello
Setup code for Sony TV with Vizio Universal remote control is [ 0000 ]
The reomote control is pre-programmed to work with all esisting Vizio TVs. If you want to set up it with Sony TV, do the following.
1. Manualy turn on the TV.
2. Press the [TV2] button on the remote control.
3. Press and Hold the Setup button until the LED light flashes twice.
4. Enter (0000) using the number buttons. If the code is accepted the LED flashes twice after the last digit is entered. If the LED does not flash, repeat steps 2 through 4 once again.
5. Point the remote control at the tV and press POWER button. The TV will turn OFF.
Other four digit codes to check for Sony TVs are: 0128/0013/0002/0071 & 0380.
If code [0000] does not respond with try other codes. Repeatsteps 2 through 4 once again after entering each code listed. The code listed with Vizio universal remote control with Sony TV is [ 0000 ].
OK.
Aug 29, 2011 | Televison & Video
I have a sony 29'' crt tv . model no kv 29xr m80.when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 8 times .then the tv goes in stand by mode .which section...
Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Mar 28, 2011 | Sony KV-XR29M61 TV
Looking for codes for my 32 inch sony Bravia flat screen
The code for your remote is "0000" Press "TV" and then "Set" while holding "TV" wait for the LED to blink twice then release both buttons enter code "0000" the LED will blink twice again to confirm. Press "power" to test. That's the only Sony code for your remote. Hope this helps
Jan 24, 2011 | One For All URC-4880 Remote Control
Sharper Image jumbo remote will not accept codes
Your best bet is to use the auto-search function of the remote to run through all the choices in the SAT category for the Direct TV box. I know it is more of a cable box, than a satellite box, but there are many code choices for direct TV under the satellite code listings. I think you will be out of luck for the Bose Cinewave. I am surprised that the Panasonic TV codes didn't work for you using the auto-search.
Here are the codes I have handy for Direct TV set-top boxes (SAT button) : 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216 & 217.
And for Panasonic TV's: 003, 054, 055, 062, 070, 148, 170 & 171.
And for Sony DVD's: 009 & 174.
To program your remote to the TV by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
As I mentioned, try substituting SAT for the Direct TV box, and of course DVD for the Sony player.
I hope that helps.
Dec 31, 2009 | Innovage Jumbo Remote Control
Jumbo Control Code
The codes for this remote are different depending on whether you are trying to control a Sony TV or a Sony DVD player. Please post again with more information, or use the auto-search function of this remote.
  1. Turn on your TV.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Nov 18, 2009 | Innovage Jumbo Remote Control
How do I program my Innovage Jumbo Remote control to my Sony TV
To program your Innovage Jumbo Remote to control your Sony TV, these are the codes: 002, 006, 071, & 128.
This is the procedure:
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
I hope that helps.
Sony tv code from urc-3021gb1
To control a Sony TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0000, 1100, 0810
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
Hope that helps.
Oct 21, 2009 | One For All URC-3021 Remote Control
Code for TV / Sky+remote
Problem: Need Sony manufactures code for the Sky remote.
Solution: Your TV Code for Sony is 0000
1. Turn on your TV.
2. Ensure that the front of your Sky Navigator is closed.
3. Press "tv”.
4. Hold down "select" and the red button together for about two seconds, until the red LED on the Sky Navigatore flashes twice.
5. Press "tv" again.
6. Key in the four digit code for your brand of TV. The LED on the Sky Navigator will flash twice. If the LED illuminates only once, re-check the code for your brand of TV and start again at step 5.
7. Press the standby button on your Sky Navigator. If your TV switches off, press "select". The LED on the Sky Navigator will flash twice. If your TV does not switch off, press "tv", then press the standby button.
Repeat this (press "tv", then standby button) until your TV turns off,
then press "select".
If you are still experiencing problems, please telephone for technical
assistance. you will find the "Technical Help" telephone number by
pressing "services" and selecting "Telephone Numbers".
The help given is based on information taken.... Hoped this has helpd you
Jan 13, 2009 | Televison & Video
Setting tv to channel 3
When the led blinks twice it is telling you that the remote accepts the code, but that does not mean the tv accepts the code. If the tv does not power on after programming the new code then you must try the next code in the sequence, until you find one that powers on or off the tv.
Aug 25, 2007 | Radio Shack (15-2147) Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
